Ltec Caps
  • NWArcher
    • Aug 2006
    Ltec Caps
    I have a few bad Ltec caps on my board. I did not see them listed in the bad or good cap section. I will be replacing them in any case. Anyone have any experiance with these?
  • c_hegge
    • Sep 2009
    • 5219
    Re: Ltec Caps
    Sorry to post in such an old thread, but I've been wondering the same thing myself. I've seen busted Ltec on motherboards. I've also seem some in PSUs which look OK. Does anyone know what they are like. Are they like GSC/G-Luxon (unreliable no matter where they are) or are they more like Teapo (unreliable on motherboards but sometimes OK in power supplies)?
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      Re: Ltec Caps
      LTEC = Luminous Town Electric Company. [China]
      They are bad.
      https://www.badcaps.net/forum/showpo...042&postcount=2
      Mann-Made Global Warming.
      - Dr Seuss
      • c_hegge
        • Sep 2009
        • 5219
        Re: Ltec Caps
        OK. I just replaced a few in a Hipro PSU with Chemi-con KZE and Panny FM. Looks like it wasn't a waste of time then. Oh, and that link doesn't work (404 error).
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          Re: Ltec Caps
          https://www.badcaps.net/forum/showpo...42&postcount=2
          - Dr Seuss
          • larrymoencurly
            • Oct 2004
            • 960
            Re: Ltec Caps
            My Asrock K7VT4A Pro Socket A mobo had about 15 Ltec LZPs, each 1,000uF, 6.3V. The one next to the North Bridge (ran hot even when brand new) and two for the 2.5V DDR memory power bulged, but none of the rest, probably all used for bypass, bulged or developed high ESR. That isn't to say I left any of those in place.
            • ant3202
              • Jun 2006
              • 275
              • Singapore
              Re: Ltec Caps
              LTEC, bad caps.....
              • bigbeark
                • Jan 2010
                • 661
                Re: Ltec Caps
                They are bad.
                Thanks for the confirmation.
                I was just working on an Asus A7V400 that used these around the PCI slots.
                The board would start up, then immediately throttle back, sounding like it was going to shut down, then recover itself.
                I replaced all the ones arounf the PCI slots with Rubycon ZLs that I have around, and the
                problem got much less obvious. It's still there a bit, but I havn;t replaced all the LTECs yet.
                I pulled the tall skinny OST 1500uf 6,3v and replaced them with MBZ caps.
                So my work is not fully done, especially as the other 1500s are Nichicon HM
                This board runs at 52C which I feel is too hot.
                • Krankshaft
                  • Jan 2007
                  • 2328
                  Re: Ltec Caps
                  With one exception they seem to live well in PSUs they're in my Antec Earthwatts built by Delta. They used Chemicons on the stressed rails through .
                  Delta also built the original X-box PSUs where they used them on the secondaries and those things were real hot inside. I believe they were used on the PS2s PSU secondary as well also built by Delta.
                  I had to fix upwards of 100 of both those units and never a bulged PSU cap.
                  • PCBONEZ
                    Grumpy Old Fart
                    • Aug 2005
                    • 10661
                    Re: Ltec Caps
                    About the same as Teapo there.
                    - Dr Seuss
                    • c_hegge
                      • Sep 2009
                      • 5219
                      Re: Ltec Caps
                      That's normal for a Skt. A CPU. My last Skt. A ran at 60C idle and 80C under load. And that was with 6 case fans and a 120mm PSU fan.
                      • fringeplayer
                        • Feb 2015
                        Re: Ltec Caps
                        I recently repaired a Delta power supply in a Dell Inspiron computer. I replaced two bulged capacitors. They were Ltec 2200uF 10V 105C electrolytic capacitors. I checked 11 capacitors of which 7 were Ltec. Only two were out of spec. I replaced them all with higher voltage rated capacitors. I reused one 2200uF 10V Ltec in place of a 2200uF 6.3V Ltec because the space allowed would not accommodate the bigger size of the higher voltage new capacitor. In most cases one would replace the whole power supply for less than $100 but a lot of the power supplies below $70 do not have the 4 pin 12V MB connector or amperage specs as the original.
                        • PeteS in CA
                          • Aug 2005
                          • 3583
                          • USA, Unsure of Planet
                          Re: Ltec Caps
                          Dell uses the "Inspiron" name for desktops?
                          Dell has nickled and dimed its power supply vendors - e.g. Delta and Lite On - to the point that they are using marginal parts in important applications. Delta's rep here, that I've seen, is that they seem to use Ltec parts carefully enough to get decent life out of them. My sample-of-1 experience with Lite On P/Ss is that they get mediocre life from Ltec.
                          I used to work for Delta in 1998-2001. I respect their quality, and I respect Lite On as well. While Delta and Lite On are building product for Dell with marginal parts, I put a lot of blame on Dell for nickling and diming their vendors so severely.
                          PeteS in CA
                          • CapSwapper
                            • Feb 2014
                            • 69
                            Re: Ltec Caps
                            Ltec is garbage junk caps. if you remove them all and test them they will be way out of spec.
                            • RJARRRPCGP
                              • Jul 2004
                              • 6304
                              Re: Ltec Caps
                              Not as likely as "KM" caps.
                              ASRock B550 PG Velocita
                              Ryzen 9 "Vermeer" 5900X
                              Arc A770 16 GB
                              eVGA Supernova G3 750W
                              Alienware AW3423DWF OLED
                              • coreAngel
                                • Oct 2014
                                • 124
                                Re: Ltec Caps
                                I hate to respond to an old post but I have to ask ...I have a antec earthwatts green 380d 380 watts all of the amps are distributed evenly on 3.3v 5v and 12v however when I opened it up the the main capacitor is a samxon which is adequate but every single other cap about 15-20 of them are ltec and that has me worried ...should I replace it. Since I'll never use more than 80% of the wattage would those ltec caps last longer its only 380 watts and a delta build but it looks well built so is ltec that bad i n such a low wattage option...
                                Yes i love Nichicon MUSE Audio Capacitors...they would look awesome all over any motherboard
                                • Pentium4
                                  CapXon Be Gone
                                  • Sep 2011
                                  • 3741
                                  Re: Ltec Caps
                                  How old is the psu and how much use has it seen? 80% of the load will create a lot of heat inside the filtering capacitors. These LTEC caps will fail after 5 years even if the psu never saw higher than 30% of its rated capacity. At the minimum, i would replace the ones on the 12v rail and 5vsb rail. Depending on your revision, there might already be some good caps installed in those sections. Ideally, you should replace them all, oil the sleeve bearing fan, and it will last essentially forever because yes, delta designs very good units
                                  • coreAngel
                                    • Oct 2014
                                    • 124
                                    Re: Ltec Caps
                                    the psu is brand new never used bought it off of ebay (or flea-bay to some) it was removed from antec cases that featured this power supply according to the listing,still you can purchase it at newegg for 30 something dollars so i dont think it's discontinued model..
                                    • Pentium4
                                      CapXon Be Gone
                                      • Sep 2011
                                      • 3741
                                      Re: Ltec Caps
                                      It should be okay for a while then, but just be careful after a few years if you're going to be stressing the power supply to 80% we'd love to see pictures.
                                      • fringeplayer
                                        • Feb 2015
                                        Re: Ltec Caps
                                        I recently repaired the same power supply for a noisy fan. I replaced the fan with a new fan with ball bearings. The original fan had sleeve bearings and was sealed to be dust resistant and consequently could not be lubricated. I noticed that the one Ltec 2200uF 10V cap that I reused in a 3.3V location had bulged. I reused it because it measured to spec and was relocated from a 6V location to a 3.3V location where it would be less stressed. It was small enough to fit flush to the PCB where as any higher voltage replacement caps would not fit flush to the board. I replaced it with a 2200uF 35V United Chemicon cap with extended leads. I should have done that in the first place. Ltec caps are doomed to fail so to save yourself from future problems you should replace them even if they measure to spec.
                                        • eryjus
                                          by eryjus
                                          05-10-2023, 11:21 AM
                                        • Paxman_Swede
                                          by Paxman_Swede
                                          Hello!
                                          01-14-2025, 09:51 AM
                                        • captain150
                                          by captain150
                                          03-16-2025, 07:34 PM
                                        • Foetuss
                                          Gigabyte GA-6OXT :: caps question
                                          by Foetuss
                                          Good evening
                                          I recently aquired a rev 1.1 Gigabyte 60XT, and was suprised of the amount of leaking caps for a motherboard of the P3 era. Especially the way the 330µf caps seems like the housing discolored even.
                                          Now, there are some 3300µF 6.3V KZG series around the CPU. Would it be OK to replace them with something like EEUFR1A332 ? (Panasonic FR 3300µF 10V). Or was this board designed around very low ESR caps?
                                          But I was also suprised about the bigger boys, which are 330µF 25V.
                                          Could it be they used 25V caps because they were cheaper / available at that time?...
                                          02-11-2025, 12:22 PM
                                        • madscientist750
                                          Replacing electrolytic caps by solid caps on old motherboards
                                          by madscientist750
                                          I do have several old pc motherboards which i recapped 10 year ago and some of those caps are bulged now.
                                          I would like to upgrade them using solid capacitors. I do use them for testing and helping some alternative operating systems.
                                          I would like to ask if such an upgrade can be done, what should i have in mind when replacing electrolytic by solid caps and if such thing exist, if there are caps list for old motherboards. I would have to figure out what caps needs each motherboard and then prepare a list to try to ask for them on some electronics stores.
                                          10-19-2025, 06:10 AM
