Panasonic FR or not?
  • selldoor
    Slow Learner
    • 7870
    Have just bought these from CPC/Farnell in a batch with others.
    My question is, is this all we get from Panasonic for FR - a noname cap?
    Vent and bung looks correct but there is not even an"M" to distinguish it from the crap. In the batch the others are all FMs and are gold and black and have
    the "M". Anyone know before I take them back to ask if I have been substituted.
  • joshnz
    • Feb 2011
    • 969
    • New Zealand
    Re: Panasonic FR or not?
    not fake just ugly.
    https://www.badcaps.net/forum/showthread.php?t=14047
    My pc
    CPU : AMD PHENOM II x4 @ 3.5Ghz
    MB : ASUS M4A89TD PRO USB3
    RAM : Kingston ValueRAM 16gb DDR3
    PSU : Cooler Master 850W Silent Pro
    GPU : ATI Radeon HD 6850
    • selldoor
      Slow Learner
      • 7870
      Thanks Josh - kicking myself now - never thought to use the search and I keep telling other people to use it.!! I guess I cant put it off now , I'll get the soldering iron heated up.
      • mariushm
        • May 2011
        • 3799
        They're genuine. Just how Panasonic makes this series...
        • c_hegge
          • Sep 2009
          • 5219
          They look identical to the FRs I got from RS components
          • BigPete
            Panasonic Heatpump Dryer Repair
            by BigPete
            I picked up a Panasonic NH-P70G2, though it would apply to the NH-P80G2, NH-P70G1 and NH-P80G1 models as well, as maybe some other models. This one was coming up with a H86 error. After lots of testing and googling it was an error with one of the thermistors in the condenser area.
            The attached French service manuals is incorrect, TH11 is gray and is a 95k thermistor and TH12 is black and is a 35k thermistor.
            In my case TH12 was bad. I was able to get a 35k thermistor on AliExpress. It's 6mm in diameter.
            Unfortunately the whole machine has to come apart to fix it.
            I have...
            11-01-2025, 06:40 PM
          • Andre Gilbert
            by Andre Gilbert
            Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
            Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
            11-20-2024, 08:52 PM
          • AquaMan Ua
            by AquaMan Ua
            05-17-2025, 09:40 AM
          • stecos
            Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
            by stecos
            Hi everyone!
            For my passion for technology I'm now collecting several...
            11-28-2022, 11:39 AM
          • aa10aa10
            Panasonic Toughbook CF-33 mk1 BIOS repair
            by aa10aa10
            Good day,
            I have tried to remove BIOS supervisor password from Panasonic Toughbook CF-33 mk1. Model number CF-33AENABTG, unfortunately I don't have any other info.
            I read the BIOS using afuwin, edited it and tried to flash new edited BIOS using afuwin. Unsuccessfully. Afuwin showed "Error: Problem erasing flash." starting with 0x00040000 and stoped. Then I tried many other options to flash BIOS from Windows without any luck. Finally i rebooted the device - and no post. Afterwards I have read the corrupted bios chip (MX25L12873F) using EZP2010 programmer....
            01-21-2025, 06:13 AM
