9800 Pro Broken Cap
  • stefmeister
    • Jul 2006
    • 4
    9800 Pro Broken Cap
    Hi, I recently brought a Radeon 9800 Pro from Ebay. I brought it knowing that it was damaged. The guy who owned it before me said he had broken off a cap while removing it from his case.
    Now having looked at the card i think fixing it should be reletively easy however i need to know what to replace it with. The missing cap is the same as the one which is next to it & that one has the following written on it (470 jFK 3Q7).
    Like i said if i could find out what i need to buy i don't think it should be too difficult to fix.
    Here is a picture of the part of the card:
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    Re: 9800 Pro Broken Cap
    You need a 470uF electrolytic cap. A 6.3v will likely be just fine, but in an 8mm can such as that, most you'll find will be 16v, which is fine also. It looks like the PCB is also drilled as well as having the solder pads, so just clear out the holes and use a low-ESR electrolytic. It'll work fine if thats all that's wrong with the card.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • kc8adu
      • Nov 2003
      • 8832
      • U.S.A!
      its likely a 470@4v solid polymer cap.good chance the card will work fine after replacement.
      its jobs like this that keep me heatgunning the polymers off of otherwise scrap mobo's.
      a leaded part will also work just wont look original.
      edit.
      this is a panasonic type fk and iirc j=6.3v
      lack of vent threw me at first.
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        it is a panasonic FK chip type surface mount cap
        470uf
        the j indicates 6.3v, the FK indicates the FK series
        the 3Q7 we ignore, it is the lot number only
        • kc8adu
          • Nov 2003
          • 8832
          • U.S.A!
          dammit ya got me mid edit:-)
          • willawake
            Super Modulator
            • Nov 2003
            • 8457
            • Greece
            lol i had it almost ready a while ago....if people would stop calling on the goddamn mobile i wouldnt be so slow
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16958
              You guys are too kind...nice info!! I'd have stuck a radial low-ESR lytic in there and called it good
              Team : 49813
              Join in!!
              Team Stats
              • stefmeister
                • Jul 2006
                • 4
                Many, many thanks for all the help. Does anyone know a place in the UK where i could find a replacement?
                Maybe a place Online also.
                • Topcat
                  The Boss Stooge
                  • Oct 2003
                  • 16958
                  There ya go:
                  https://www.badcaps.net/forum/showthread.php?t=613
                  Team : 49813
                  Join in!!
                  Team Stats
                  • willawake
                    Super Modulator
                    • Nov 2003
                    • 8457
                    • Greece
                    can you confirm that the position indeed has thru holes. you will see two on the back of the card at the same position if it does. show a pic if possible
                    • stefmeister
                      • Jul 2006
                      • 4
                      There are holes on the back but from the look of them i don't think the original cap had anything going through them. Directly under where is where i have marked with a green arrow on the pic below.
                      From what i can tell the original cap was just fixed to the top of the card not going through the cars like a lot of the others on the card.
                      • arneson
                        • Sep 2005
                        • 1267
                        Cleaning up those pads and soldering in a new cap with a fine tip looks very straightforward.
                        Nice if you can find that cap, if not sub.
                        Jim
                        • willawake
                          Super Modulator
                          • Nov 2003
                          • 8457
                          • Greece
                          it is quite busy on the rear of the card. i do not see thru-holes there so you may not use a radial capacitor unless you do a ghetto hack and just solder the leads on to the front of the pcb only.
                          so if we consider the old cap which is a 6.3v 470uf Panasonic FK, looking at the specs it has a diameter of 8mm, impedance of 0.16 ohm, ripple of 600mA and endurance of 2000h.
                          in order to replace the cap correctly we should equal or exceed the above specifications and we want an 8mm cap or smaller.
                          since you are in the UK i have looked at RS and Farnell but whilst RS has the FK caps they do not have the correct values. Farnell is similarly crappy although they do have the sanyo oscon svp 470uf 6.3v at the expensive price of pounds 1.91, Order Code: 4310366. that SVP cap has 0.015ohm esr and 4210 ripple so is greatly superior and really overkill for replacement. but i have seen them used on many graphics cards
                          while the cap is 8mm like the FK, the case size is E12, whilst the FK has case size F? can anybody explain this please, cos i am not so hot on smt components.
                          so if we look at ELFA they have the sanyo CV-KX at 1000uf 6.3v with 600 ripple and 0.15ohm esr, case size 8x10.2 at 0.70 euro ex vat. practically identical specs to the FK, just a little less esr.
                          i will check the case dimensions later to see if it would be ok.
                          problem is that if you order say 2 caps you will probably fall afoul of the minimum order quantities and shipping when divided per cap will be high. better to order caps for a few projects at once.
                          are these smt chip type caps easy to rework using only an iron? i see they have little tabs sticking out that it would be possible to solder to? anybody do that kind of repair before?
                          • stefmeister
                            • Jul 2006
                            • 4
                            I have a Maplins store not too far away frommy house, a mate of mine brought a cap from here for a Geforce4 we repaired a while back, is there anything there that woudl work?
                            http://www.maplin.co.uk/family.aspx?...ldid=3&doy=1m7
                            • willawake
                              Super Modulator
                              • Nov 2003
                              • 8457
                              • Greece
                              no
                              • gonzo0815
                                • Feb 2006
                                • 1600
                                Soldering elektrolytic smt caps is fairly easy. I have done it on a Motorla GP900 radio unit on board charger, wich has blown a 22uf smt cap during operation (the whole car smelled like ).
                                As long as there is enough space to reach the soldering pad with the solder tip this isn`t any harder than through hole soldering.
                                • stewart710
                                  • Jun 2006
                                  • 42
                                  I've been reading posts here for a while (but I don't think I've posted before), keep up the good work there is a lot of valuable information here. I have similar situation. One of the caps on my 9800 pro card broke off and I've rigged it so it works, but it looks pretty ghetto. The pins were too short to solder back onto the pads so I had to use some wire and extend them.
                                  What I would really like to do is replace the cap, but I'm having difficulty finding the part:
                                  a34r
                                  470
                                  6.3v
                                  I guess it is a surface mount cap, I was trying to order one through Newark, but I don't want to get the wrong one. if anyone could tell me what part # to order from them, that would help me out a lot. It is very similar to the one in Willawake's picture, but mine has a blue stripe on one side, not black. Mine also has only pads, not holes. Thanks in advance.
                                  • mecha1166
                                    KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen.
                                    by mecha1166
                                    KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen. Already tried reset POWER/VOL-. Anyone else have this problem? Possibly bad T-Con RUNTK4244ZZ or panel? Could main or power supply cause this? There were 2 blown 560u 35v on power going to backlights but they were still working fine. Thanks for your help.
                                    11-25-2024, 05:22 PM
                                  • chth96
                                    Is it possible bridging tiny broken trace
                                    by chth96
                                    When I assembled dreamcast I mistakenly fastened long bolt and It resulted in
                                    cutting tiny trace.
                                    This tiny trace(Total width of white coating is 5.5mm) is between R337,R343 and IC101 and it is covered with white coating in the below screenshot.
                                    Firstly I tried to bridging tiny broken trace with my own eyes...But it is totally impossible..So a week ago, I ordered G1200 Digital Microscope and I magnified this tiny broken trace with it.
                                    But It seems that It is really very tiny trace So I plan to order 0.1mm coper wire from aliexpress in order to bridging...
                                    12-03-2022, 11:32 PM
                                    HP Pavilion 570-p042ur Pavilion 570 A12-9800 Specification for Upgrade or Repair
                                    This specification for the HP Pavilion 570-p042ur can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion 570-p042ur boardview and Pavilion 570-p042ur schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                    09-12-2024, 02:00 PM
                                  • corrize
                                    Resonator - quartz broken - how to find the same (same frequency) ?
                                    by corrize
                                    Hello, I have a Fujifilm hybrid camera with an issue : the time don't run. I set 12:00 and 3 min later, the same : 12:00
                                    I saw an obvious root cause : a broken quartz (resonator). But with the box broken, I can't read the marking code. Probably : 464… or A64…
                                    I found on the web a picture of the same camera board but with marking code very different. Probably : A7…5N
                                    I'm searching another one for compare…
                                    Do you have an idea or another way for find the frequency of this resonator please ?
                                    (I did not found the manufacturer of this component ? And I did not found the...
                                    03-27-2025, 09:20 PM
                                  • edugimeno
                                    TD Systems K50DLP8F works fine on 1 HDMI, bad on others
                                    by edugimeno
                                    I have this TV set that I spent a long time fixing it.
                                    I finally found a shorted SMD capacitor near the plug from the PS at the main board. It was shorting one of the main voltages (can't remember which one)
                                    I removed that capacitor, and as it has another one in parallel, I left it with only one, checked it and it seemed to work fine. The solder near that capacitor was really delicate as I pulled apart one trace so I prefered to not mess much with it after I had to air solder one small thread of copper
                                    I didn't use that TV much at that time. Now that I'm using it,...
                                    10-06-2023, 03:00 PM
