Resonator - quartz broken - how to find the same (same frequency) ?
  • corrize
    • Apr 2021
    • 288
    • France
    Hello, I have a Fujifilm hybrid camera with an issue : the time don't run. I set 12:00 and 3 min later, the same : 12:00
    I saw an obvious root cause : a broken quartz (resonator). But with the box broken, I can't read the marking code. Probably : 464… or A64…
    I found on the web a picture of the same camera board but with marking code very different. Probably : A7…5N
    I'm searching another one for compare…
    Do you have an idea or another way for find the frequency of this resonator please ?
    (I did not found the manufacturer of this component ? And I did not found the chip).
  • truclacicr
    • Apr 2019
    • 345
    • australia
    It's probably a Seiko-Epson 32.768 kHz crystal.
    https://www.google.com/search?q=32.768khz+fc-135&udm=2&sclient=img
    https://www.yangxing.hk/u_file/photo/20200107/FC-135-Datasheet.pdf
    • corrize
      • Apr 2021
      • 288
      • France
      Yes, you found it, exactly this one.
      And now I saw why marking codes are so differents : only the first letter « A » is usefull.
      Thanks you
      • truclacicr
        • Apr 2019
        • 345
        • australia
        Sorry, I messed up the link to the datasheet:
        https://download.epsondevice.com/td/.../FC-135_en.pdf
        • Vesko356
          by Vesko356
          08-11-2023, 03:27 AM
        • chth96
          Is it possible bridging tiny broken trace
          by chth96
          When I assembled dreamcast I mistakenly fastened long bolt and It resulted in
          cutting tiny trace.
          This tiny trace(Total width of white coating is 5.5mm) is between R337,R343 and IC101 and it is covered with white coating in the below screenshot.
          Firstly I tried to bridging tiny broken trace with my own eyes...But it is totally impossible..So a week ago, I ordered G1200 Digital Microscope and I magnified this tiny broken trace with it.
          But It seems that It is really very tiny trace So I plan to order 0.1mm coper wire from aliexpress in order to bridging...
          12-03-2022, 11:32 PM
        • danielgerman681
          ENCONTRAR DATOS DMI EN EL CHIP BIOS IDEAPAD5 15ITL05 / FIND DMI DATA ON IDEAPAD5 15ITL05 BIOS CHIP
          by danielgerman681
          Hi, Im trying to find the area on the chip that contains all of my laptops information, but I havent found it. The laptop won't turn on anymore. I was updating the BIOS, and it was supposed to reboot itself, but it wouldnt turn back on. I ve tried every possible solution, every alternative on Lenovo forums, everywhere; I ve taken it to technicians, and no one has been able to fix it. I've already read the chip that contains the BIOS (Winbond 25Q128JSVQ) and searched for my laptops data, but they're nowhere to be found. I only find scribbles and lines of text indicating errors. Has anyone had a...
          08-27-2025, 01:17 PM
        • corrize
          Where to find a very small fpc connector 0.3mm between 2 pins ?
          by corrize
          Hello, I search this connector (oxydated).
          It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
          I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
          I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
          Do you know how to find this connector please ? What is the exact name for find it ?
          08-06-2024, 05:25 PM
          Where can I find a DD3 128000 type memory but 32 MGB in one module because this laptop has only one slot
          by sam_sam_sam
          This Dell computer is a pain in the a** because of it only has one memory slot this computer only had 4 megabytes of memory and slower than shit I found a 8 megabyte memory module and it is better but still slow as shit the maximum is 32 megabytes of RAM but I was not able to find one I found some that are 16 megabytes but they are 1600/128000 type and I am not sure if this computer will work with this type of memory or not
          Dose anyone knows where I can find a 32 megabytes memory module for this computer because the battery still works fairly well still I would like to use it on my...
          07-07-2024, 02:34 PM
