Teapo capacitor quality
    • 31214
    Re: Teapo capacitor quality
    in hot country's or 24/7 builds,
    you want the psu fan doing what it's designed to do - move a lot of air.
    non of that wisper/thermal management shit - it's a psu killer.
    take the fan out and hook it to 12v - if it feels like it moves a lot of air - use it.
    if not ( most of the cheap 120/140mm fans are junk) then put something better in.
    antec have ball-bearings and good flow rate if yur buying from a computer place,
    or salvage a delta or a papst or some other decent fan from something else!
    • c_hegge
      • Sep 2009
      • 5219
      There's no way in the world I would do that. I hate fan noise, and if a PSU needs the fan to be running at maximum speed, then you're doing it wrong. Any decent PSU should be able to last 10+ years of heavy use with the fan staying silent
      • Wester547
        • Nov 2011
        • 1268
        • USA.
        More airflow isn't necessarily better. Think about the increase in dust accumulation with that amount of airflow over the years and how easy it would be for dust to amass and get "trapped" in between the heatsink fins, nullifying the point of more airflow to begin with (I know it's easy to occasionally clean the PSU, and that filters can allay that problem, but still). I think it's much more important to make sure the existing airflow is properly cooling the power supply (keeping certain that there's ample room for airflow, trying to avoid having wires and large inductors blocking airflow to the secondary, making sure the passage of airflow is as straight as possible to avoid hot spots, etc). Bottom mounted 120mm/140mm fans aren't necessarily better than traditionally mounted 80mm fans. The larger fans suffer greatly in terms of static air pressure and much of the airflow has to be either blocked or redirected 90 degrees.
        As for Teapo's capacitor quality... I have been among the fortunate and have not seen that many failures from them myself, but given the amount of failures I've read from others, I'd say Teapo capacitors are terrible, like any other 'mediocre' Taiwanese brand. Of course, no 'lytic lasts forever and heat is the ultimate enemy of even Japanese lytics, especially aqueous ones.
        EDIT: Momaka observed that Teapo SZ fail very very often on motherboards. I doubt they're reliable by any stretch of the word.
        • Pentium4
          CapXon Be Gone
          • Sep 2011
          • 3741
          24/7 is better for PSU's, especially the cheap ones with really hot 2 transistor stand by
          • mockingbird
            • Dec 2008
            • 5484
            Originally posted by mockingbird
            I have been looking at quite a few FSP units (SPI "ATX-350-PN") from systems that are a few years old... They use all Teapo caps, some low-ESR "SC" series and some general purpose... So far, they all exhibit the same two bloated +5VSB Teapo "SC" caps (Which is probably because of overstressing, not lack of quality). None of the other Teapos are ever bloated (I re-cap them all anyways), and I would be very curious to check them if they are indeed in spec...
            So I suspect that Teapo are generally OK in PSUs... I've even seen Compaq P4 towers that have Teapos scattered throughout, they seem to do ok as long as they're not in the VRM, and they don't arbitrarily bloat like KZG/TK/OST caps do.
            Just an addendum, since this thread has been resurrected... On certain FSP models (FSP300-60THN), instead of two 1000uF Teapo SC caps on the 5VSB, there is one 1000uF SC and one 1500uF SZ... In these supplies, the 5VSB does not fail because neither the SZ nor the SC bloat (Whereas where there are two SC caps, failure is imminent).
            SZ is similar enough to Nichicon HM to be used on CPU VRMs. I wonder if they were/are a reliable series.
              • 31214
              there is no dust in a machine designed for 24/7 use.
              you presurise the case with more fans pushing in than sucking out and fit filters on them.
              i have lost track of the number of dead machines i'v fixed because they didnt use filters & the cpu heatsink got clogged-up.
              • BigTroll
                • Sep 2010
                • 1317
                • LAMBDA SOND
                #27
                Originally posted by capacitorguy
                I had good experince with Teapo capacitors I wont say they are excellent but in my friends old computer had teapo caps he had the system running much of the day for 8 or so years before the motherboard chipset went bad, I have the PSU (HIPRO) running in my computer now which is going well... nowdays he has another machine it has a coolermaster unit it is running windows 7 it was one of the last windows 7 stock machines before they went to 8 and i used the rest of his old system for parts. but still those caps just keep on going they could die tomorrow or they could die in 5 years or keep on ticking longer... then again im using it for daily internet and using a old AMD athalon 64 which is well for internet so light load will be fine on the thing
                yeah teapo is like wal-marts great value brand, you get great value.
                My Computer: AMD Ryzen 9 3900X, Asrock X370 Killer SLI/AC, 32GB G.SKILL TRIDENT Z RGB DDR4 3200, 500GB WD Black NVME and 2TB Toshiba HD,Geforce RTX 3080 FOUNDERS Edition, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 Pro
                • mockingbird
                  • Dec 2008
                  • 5484
                  #28
                  Hey, don't knock Great Value. We get their soda crackers imported from you guys to Canadian Wal-Mart and they are much better than Canadian soda crackers.
                  • BigTroll
                    • Sep 2010
                    • 1317
                    • LAMBDA SOND
                    #29
                    got a 1982 4 switch atari 2600 and it has all original old school teapos in it, runs like a champ!
                    • Heihachi_73
                      • Jun 2012
                      • 713
                      My 1984 Atari 2600 (PAL) has Wang's caps (enter penile jokes here). The board is stamped 1 JUL 1983, but the chips are later, one being from 1984. Not only that, they are socketed rather than soldered straight to the PCB. Not a surface mount component to be seen!
                      Unfortunately this console doesn't want to work properly (you'll find this machine on one of my early YouTube videos).
                      C21: 4.7uF 35V -> [in circuit]
                      C243: Wang's 2200uF 16V -> 2519uF, 0.04Ω
                      That's all of them on the entire board (I didn't bother opening the RF modulator section, as that would require desoldering).
                      I also got a low battery warning on my ESR70 just then and it turned itself off!
                      Code:
                      ** WarninΩ **
                      █ Low Battery █
                      Sure enough, the battery is now 9.87V. One original GP Ultra 23AE removed. I might try to zap this one back to life as they aren't that cheap, although alkaline batteries aren't supposed to be recharged (it never hurt any of my AA Duracells and Energizers I did over the years though).
                      • CapSwapper
                        • Feb 2014
                        • 69
                        Teapos aren't good for longevity. I'd say 5 years absolute maximum. I had a project where I had to replace hundreds of bad caps in psu's of cable boxes and all the bad ones were Teapos. the company was so cheap they gave us another cheap junk cap for the replacements. The cable company was Comcast
                        • linuxguru
                          • Apr 2005
                          • 1564
                          #32
                          Originally posted by Pentium4
                          With a lot more experience now, I can say that probably 15-20% of the Teapo caps I have encountered that failed, failed without showing any visible symptoms.
                          Yup, they often dry out or out-gas through the bottom bung, similar to G-Luxon. I've seen a fair number of failed Green/Gold Teapo SCs without any visible bulge - mostly from mobos. It's best to replace all Teapos on VRMs and Vcore rails at sight.
                          • Agent24
                            I see dead caps
                            • Oct 2007
                            • 5038
                            • New Zealand
                            #33
                            Stupid, but not surprising. What did they use for replacements?
                            -David VanHorn
                            • RJARRRPCGP
                              • Jul 2004
                              • 6304
                              My 2008 FSP PSU is still doing good, even with Teapo caps.
                              Nothing like that Deer 250 W PSU.....
                              ASRock B550 PG Velocita
                              Ryzen 9 "Vermeer" 5900X
                              Arc A770 16 GB
                              eVGA Supernova G3 750W
                              Alienware AW3423DWF OLED
                              • mockingbird
                                • Dec 2008
                                • 5484
                                #35
                                12.5mm and 10mm Teapo SC may very well be almost comparable to top tier brands in terms of longevity. I've stopped doing mandatory replacements of them in PSUs. The 8mm Teapo SC are replace on sight however.
                                • CapSwapper
                                  • Feb 2014
                                  • 69
                                  I forgot the name but it was a brand I never heard of. I remember it was just initials on the cap and it was shipped in yellow boxes with chinese writing.
                                  • CapSwapper
                                    • Feb 2014
                                    • 69
                                    you should desolder a few and check the readings. The 2200uF Teapos I was replacing daily were reading 10 - 20uF with no leaks or bulges
                                    • mockingbird
                                      • Dec 2008
                                      • 5484
                                      #38
                                      Interesting. Were these the 10mm Teapo SC, or Teapo SEK?
                                      • goodpsusearch
                                        • Oct 2009
                                        • 2850
                                        • Greece
                                        #39
                                        I 've never seen Teapo caps large diameter go bad without bulging.
                                        • Pentium4
                                          CapXon Be Gone
                                          • Sep 2011
                                          • 3741
                                          I have. 3300uF 16V 12.5mm Teapo SC read 0.33Ω ESR (was not bulging). But generally, yes the 10mm and 12.5mm ones seem to be more reliable
                                          • MORETTIGIAN
                                            by MORETTIGIAN
                                            Title:
                                            Description:
                                            Procedure performed:
                                            - Removed backplate
                                            - Reapplied thermal compound
                                            - Reassembled card
                                            09-18-2025, 12:14 PM
                                          • chth96
                                            Does WCAP-ATG5 has similar or better quality than smahwa capacitor?
                                            by chth96
                                            I want to replace samhwa RG 250v 1uf capacitor which has no ESR value and has capacitance less than 280pf.
                                            It is possible to purchase WCAP-ATG5 in local electronic shop.
                                            But I want to know that whether WCAP-ATG5 capacitor has similar or better quality than smahwa capacitor or not.
                                            Is there anyone who has experience to replace any bulge or faulty cap with cap from Wurth Elektronik?
                                            https://www.we-online.com/en/compone...ucts/WCAP-ATG5
                                            05-09-2024, 02:57 PM
                                          • Prolog
                                            by Prolog
                                            12-01-2024, 08:27 PM
                                            by momaka
                                            03-15-2023, 10:17 PM
                                          • bauto601
                                            KDM 480W PSU upgrade succes! (opinions?)
                                            by bauto601
                                            Back in 2020 i bought a (2nd hand) compact ATX psu to replace my current one. My PC case only fits very short ATX power supplies so i didn't really have the choice of buying a decent 80Plus unit. The current unit is a modded YoungYear unit that i made a thread about a while ago:
                                            A "nice" YoungYear unit? - Badcaps
                                            The "new" unit is a KDM-M6480 480W psu, the 480W number is a typical KDM bullshit claim of course, but the 24A rating on the 12V rail seemed reasonable and the "Active PFC" claim gave me a bit of hope that this was going to be decent-ish....
                                            12-26-2023, 03:05 PM
