FAKE "Rubysun" in spotlight led!
  • goodpsusearch
    • Oct 2009
    • 2850
    • Greece
    I bought 6 of those two and a half years ago and 2 months later they started to fail... I would just return the faulty ones and get new ones for free, but not anymore.
    So I disassembled 1 to see if I can fix it. There is a 25V 100uF Rubysun capacitor inside!
    Pics coming soon....
  • goodpsusearch
    • Oct 2009
    • 2850
    • Greece
    Re: FAKE "Rubysun" in spotlight led!
    The cap
    • goodpsusearch
      • Oct 2009
      • 2850
      • Greece
      And the recapped led light... Unfortunately it still flashes and then stops completely...
      • mariushm
        • May 2011
        • 3799
        I wouldn't call them fake... the font is different, they have their own series on them... don't see any intent to trick people into thinking they're rubycons...
        As for the rest... try each led separately, maybe one's shorted ... check the rectifier diodes (if that's what they are on the back), maybe one's broken and the chip doesn't like AC current coming in and that causes blinking.
        • Toasty
          • Jul 2007
          • 4171
          Can't find much on the SB42509. Appears to be the driver IC and that's the problem. Perhaps some research to find a 1A LED driver IC?
          Google turned up the attached file from:
          bbs.dianyuan.com/bbs/u/78/9871246109216.pdf
          Toast
          veritas odium parit
          • b700029
            Banned
            • Sep 2010
            • 640
            (Now defunct) manufacturer's site:
            http://web.archive.org/web/200502142...ce/3-chanp.htm
            And that would be a Silan SD42509 (which for some reason is not directly linked on their website but a little Google found the page):
            http://www.silan.com.cn/english/prod...94%B5%E8%B7%AF
            • goodpsusearch
              • Oct 2009
              • 2850
              • Greece
              They all die the same way. After some minutes of use they start flashing in long periods and then they stop lighting.
              There are 4 "S4" smd diodes forming a bridge rectifier and another one on the other side.
              Do you think that the IC is the one going bad or the diodes?
              Btw the Fake capacitor was not bad: 97uF 0.84 esr
              • Scenic
                o.O
                • Sep 2007
                • 2642
                Well.. you could easily test the diodes.. if they're fine, it's that strange IC
                • goodpsusearch
                  • Oct 2009
                  • 2850
                  • Greece
                  The diode mode of my multimeter says they are ok... But I tested them in circuit.
                  • Toasty
                    • Jul 2007
                    • 4171
                    ddddduuuuuhhhh stoooopid ANTI CAPS CRAP SCRIPT
                    Should be BANNED from a TECHNICAL FORUM!
                    AGAIN: SD42509 PDF
                    veritas odium parit
                    • kc8adu
                      • Nov 2003
                      • 8832
                      • U.S.A!
                      freeze spray on the ic would likely tell you.
                      but i bet one of the led's is opening up.
                      seems i have seen those same led's do that in cheap flashlights.iirc they are seoul semiconductor or edison opto.luxeon knockoffs.
                      • PCBONEZ
                        Grumpy Old Fart
                        • Aug 2005
                        • 10661
                        Those aren't fake Rubysun, they are real Rubysun.
                        Mann-Made Global Warming.
                        - Dr Seuss
                        • lti
                          • May 2011
                          • 2553
                          The Rubysuns are not fake, but they're crap anyway. I had some computer speakers from 1998 with Rubysun caps in the amplifier. The speakers kept getting quieter over the years, and replacing those caps made them nice and loud again... until the speakers blew.
                          • goodpsusearch
                            • Oct 2009
                            • 2850
                            • Greece
                            One of the leds was failing open and made all of them blink.
                            Now it is completely open. In fact, if I press the faulty led with my finger it lights, but then opens again.
                            I am wondering if I can solder a resistor in place of the open led and use the other 2.
                            Yes, it would not look nice
                            • kc8adu
                              • Nov 2003
                              • 8832
                              • U.S.A!
                              hmm looks like the board has pads for cree xlamp as well as luxeon style packages.
                              i would be tempted to upgrade.with all the progress made in the last few years and 100 lumem/watt parts around i would give it a shot.you might double its output.
                              • b700029
                                Banned
                                • Sep 2010
                                • 640
                                Bad soldering?
                                • goodpsusearch
                                  • Oct 2009
                                  • 2850
                                  • Greece
                                  Originally posted by b700029
                                  Bad soldering?
                                  No. There are 2 very thin wires that could possibly break due to heat...
