Help me
  • v b chil-n
    • Dec 2005
    • 32
    Re: Help me
    Originally posted by PCBONEZ
    Are those KZE original because they are laying on SMD parts and don't look like they should be there.
    Also doubt that board has 50v on it anywhere.
    I'm thinkin' someone used whatever they had laying around.
    Looking at it I think for the caps you asked about I would try the LXZ.
    http://search.digikey.com/scripts/Dk...me=565-1875-ND
    The KZE's are not original but the original caps were in the same location. There is actually nothing below them just a few near by resistors, the originals were leaking hence the replacements.
    I know the unit uses at least 24V AC where the power is distributed is beyond me. I will check out all the suggestions thanks for the assist.
    • brad2157
      Decon SH PET Capacitors for “Klipsch The Fives”
      by brad2157
      I’m working on re-capping the power board caps on a Klipsch The Fives audio speaker system. I can’t locate a replacement for these original caps that are labeled “Decon SH PET”. I have three of these on the board with the electrolytics. They are supposed to be a film type capacitor, but they look like a radial mount electrolytic. Everything I find they look completely different, usually a square type body. The two values I need are 16V 470uF and 35V 47uF. I’ve got all the other caps in my cart already from Mouser, so if there’s a replacement there, I would prefer to order from...
      10-21-2024, 09:47 PM
    • PennyLane
      Trying to locate a capacitor for a Skytec Crossover filter
      by PennyLane
      Hi
      I'm trying to locate what i believe to be Radial Electrolytic Capacitors 100v 82uf Non-polar for a Skytec Crossover filter.
      02-19-2025, 06:47 AM
    • mrkmpn
      Finding comparable ferrite beads on mouser/digikey?
      by mrkmpn
      I have an inspiron with "power rail failure" LED codes flashing, and have found a blown capacitor and ferrite bead (inductor, I guess...)
      I've found the replacement capacitor on mouser, but am unsure how to properly search for the ferrite bead. I have the schematics and boardview, so I have found the original bead part#, but the data sheet doesn't seem to include the information I need for the filters on mouser and digikey.
      For inductance, and a few other values it just says "Refer to standard electrical characteristics list"
      Here's...
      10-12-2022, 01:54 PM
    • gica69
      Need help to identify and to locate a 0.33 ohms fusible resistor for power supply
      by gica69
      I have a quad charger that is split into 4 separate sections and one section doesn’t charge anymore. I have located what I think is a thermistor and on the shrink tube it says 125 degrees C. I cut the shrink tube and it's a 33 ohms resistor. It measures a little less than 1/2 inch in length. I am including pictures of it. Please help me identify it. So, it should test at 0.4ohms and probably go up in resistance with the rise in temp. On the board it clearly says R for resistor. But it has to be a special one.
      Resistor shows orange range silver gold and green lines.
      Thanks in adv...
      07-21-2025, 09:49 PM
    • jpreza
      Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
      by jpreza
      I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
      Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
      It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
      Looking at the card, it appears to be missing the following:
      1x 1.0uH inductor - orange square
      2x...
      11-01-2024, 10:54 PM
