Lowest ESR capacitors, preferably liquid electrolytics but polymer also welcome
  • Perry Babin
    • Apr 2024
    • 22
    • usa
    I'm looking for suggestions for electrolytics that are 10mm diameter and up to 25mm tall, through-hole radial capacitors with 5mm lead spacing. The value needs to be in the range of 330uF to 470uF. I typically use 35v caps due to their lower ESR vs 16v caps. Currently, the Panasonic FC is being used but the FM series is under consideration.
    This is for the primary side of a switching power supply in a car audio amplifier.
    Is there a way to calculate power dissipation in a capacitor to predict which will operate at a lower temperature? For example, a 470uF may have a lower ESR but will have greater current due to higher capacitance than a comparable 330uF. Would a 470uF with an ESR of 0.02 ohms operate at a lower temperature than a 330uF with an ESR of 0.025 ohms? Let's assume that the ripple will be about the same and largely determined by much larger amplifiers operating from the same 12v supply.
    • 31246
    the best panasonic would be FR/FS
    or rubycon ZLJ maybe ZLG
    the current is in the datasheets.
    • Perry Babin
      • Apr 2024
      • 22
      • usa
      Ordered and/or tested the FR and FS and both were better( as expected) than the FC. Settled (for now) on the FM. For the values I was using, it had a somewhat lower ESR. I may also try the 1000@35 FS. Thanks for the reply.
      • silver60618
        How to clean Liquid Metal from under CPU?
        by silver60618
        Hi all, Im working on a board, that my customer brought to another shop, and smeared liquid metal all over the board.
        The laptop powers on, then shuts off. I noticed traces of Liquid Metal near the edge of the CPU, but I fear some maybe underneath.
        Has anyone ever tried Ultrasonic cleaning, or compressed air to remove or agitate the liquid metal?
        07-11-2025, 01:47 PM
      • Hondaman
        Liquid cooling?
        by Hondaman
        I hope my computer does not randomly reboot while typing this. My main system is the AsRock 970A-G/3.1 motherboard with the AMD 8150 chip. I am experiencing FREQUENT and RANDOM reboots once the system is used for a couple of hours (sometimes it reboots before I even get to the Win7/Linux Mint dual-boot screen). The problem MIGHT be the DRAM controller chip (I recently upgraded to the maximum 64 GB RAM). It also might be the VRM chips. I am using a typical aftermarket CPU cooler, which does NOT blow air DOWN onto the VRM heat sink.
        (After previous generation hardware [Gigabyte] didn't...
        05-08-2025, 09:37 PM
      • kurland
        Strange liquid on damaged GTX1080 card
        by kurland
        I'm fixing a GPU card for a streamer, was sent to me by mail. A shorted cap on a power rail has severely burned the PCB.
        As you can see from the darkened PCB around the mosfets there are signs of liquid damage. But it's odd because the person says no water has entered the PC cabinet. If you spill something on a desktop you would know I guess...
        Funny thing is that the liquid is not only on the PCB but on top of many chips which are tightly covered by thermal padding under the heatsink, even on top of some of the RAM chips
        11-17-2020, 07:14 PM
      • mitchw
        MacBook Pro 16 M1 Pro Liquid Damage (820-02100)
        by mitchw
        Got a MacBook Pro M1 Pro 16'' to rescue immediately after liquid accident - I got it in less than 30 minutes after the spill.
        It got spilled from behind when the laptop was closed. It mostly affected the rear of the mainboard and the bottom of the LCD.
        I quickly took it apart and washed the liquid residue off the mainboard.
        The area around the UP800 had some light corrosion, but it just washed away with some IPA. Other areas looked undamaged.
        The mainboard got a thorough cleaning, as did the top case and LCD connectors / cables.
        Now the laptop...
        07-16-2025, 07:55 AM
      • Jane
        What liquid to use
        by Jane
        I would like to repair faulty backlight in Philips TV. In various videos, guys use a liquid before using a suction tool.
        Can anyone let me know what kind of the liquid is it? Or what liquid do you use?
        Thank you
        Here is a video
        https://www.youtube.com/watch?v=XzFT-o64jDQ
        02-15-2024, 05:51 AM
