Help me
  • v b chil-n
    • Dec 2005
    • 32
    Re: Help me
    Originally posted by PCBONEZ
    Are those KZE original because they are laying on SMD parts and don't look like they should be there.
    Also doubt that board has 50v on it anywhere.
    I'm thinkin' someone used whatever they had laying around.
    Looking at it I think for the caps you asked about I would try the LXZ.
    http://search.digikey.com/scripts/Dk...me=565-1875-ND
    The KZE's are not original but the original caps were in the same location. There is actually nothing below them just a few near by resistors, the originals were leaking hence the replacements.
    I know the unit uses at least 24V AC where the power is distributed is beyond me. I will check out all the suggestions thanks for the assist.
    • brad2157
      Decon SH PET Capacitors for “Klipsch The Fives”
      by brad2157
      I’m working on re-capping the power board caps on a Klipsch The Fives audio speaker system. I can’t locate a replacement for these original caps that are labeled “Decon SH PET”. I have three of these on the board with the electrolytics. They are supposed to be a film type capacitor, but they look like a radial mount electrolytic. Everything I find they look completely different, usually a square type body. The two values I need are 16V 470uF and 35V 47uF. I’ve got all the other caps in my cart already from Mouser, so if there’s a replacement there, I would prefer to order from...
      10-21-2024, 09:47 PM
    • Perry Babin
      Lowest ESR capacitors, preferably liquid electrolytics but polymer also welcome
      by Perry Babin
      I'm looking for suggestions for electrolytics that are 10mm diameter and up to 25mm tall, through-hole radial capacitors with 5mm lead spacing. The value needs to be in the range of 330uF to 470uF. I typically use 35v caps due to their lower ESR vs 16v caps. Currently, the Panasonic FC is being used but the FM series is under consideration.
      This is for the primary side of a switching power supply in a car audio amplifier.
      Is there a way to calculate power dissipation in a capacitor to predict which will operate at a lower temperature? For example, a 470uF may have a...
      10-16-2025, 05:20 AM
    • PennyLane
      Trying to locate a capacitor for a Skytec Crossover filter
      by PennyLane
      Hi
      I'm trying to locate what i believe to be Radial Electrolytic Capacitors 100v 82uf Non-polar for a Skytec Crossover filter.
      02-19-2025, 06:47 AM
    • mrkmpn
      Finding comparable ferrite beads on mouser/digikey?
      by mrkmpn
      I have an inspiron with "power rail failure" LED codes flashing, and have found a blown capacitor and ferrite bead (inductor, I guess...)
      I've found the replacement capacitor on mouser, but am unsure how to properly search for the ferrite bead. I have the schematics and boardview, so I have found the original bead part#, but the data sheet doesn't seem to include the information I need for the filters on mouser and digikey.
      For inductance, and a few other values it just says "Refer to standard electrical characteristics list"
      Here's...
      10-12-2022, 01:54 PM
    • repair-it
      Trying to locate this connector
      by repair-it
      I know this is a long shot..trying to find this socket, which appears to possibly be custom made. It was damaged and has 9 pins missing. It is part of a control board for a local pharmaceutical company. It is a 20 pin socket that measures: 11.75mm (W) x 4.9mm x 6.6mm(H) The manufacturer as expected, was not helpful.
      10-03-2025, 09:45 AM
