Trying to locate this connector
  • repair-it
    • Nov 2020
    • 116
    • US
    I know this is a long shot..trying to find this socket, which appears to possibly be custom made. It was damaged and has 9 pins missing. It is part of a control board for a local pharmaceutical company. It is a 20 pin socket that measures: 11.75mm (W) x 4.9mm x 6.6mm(H) The manufacturer as expected, was not helpful.
  • truclacicr
    • Apr 2019
    • 355
    • australia
    Try this resource:
    http://connectorbook.com/identification.html
    • repair-it
      • Nov 2020
      • 116
      • US
      thank you.
      • Tomylee
        No LCD image after connector replacement – lifted components and damaged resistor (Nintendo Switch Lite HDH-CPU-02)
        by Tomylee
        Sorry for the person who’s going to read all this !
        I'm on a Nintendo Switch Lite, motherboard HDH-CPU-02.
        While replacing the left joystick, I had to remove the motherboard to access the connector underneath. When I lifted the LCD connector latch, it broke (the plastic had become brittle over time), so I replaced the entire connector.
        During the desoldering of the LCD connector using hot air, three small components located just below the connector (likely 0402 capacitors) came off and remained stuck to the bottom of the...
        07-11-2025, 11:52 AM
      • 5mall5nail5
        Help identifying connector for ASUS 4090 Strix RGB LED connector
        by 5mall5nail5
        Hi All -
        I had replaced my ASUS 4090 Strix cooler with a waterblock and put the stock cooler on the shelf. Was moving it and snagged my sweater on the connector and pulled the wires out of the pins on the RGB connector. I tried to get them back on but its too small so I opened the stamped pins and tried to solder but its not a good repair and the wire broke on reinstallation.
        Looking to replace the connector on the cable side and get pins to crimp onto a new cable. Bought random JST and such but nothing is correct. Can anyone help identify the connector and possibly matching...
        05-04-2025, 07:47 AM
      • bussincaps
        MacBook Pro Mid-2014 A1398 Retina LED Controller Connector [First Repair (Disaster)]
        by bussincaps
        Hello All,
        tl;dr: minimal electronics experience and my first repair, lifted 8 pads off the laptop display LED controller board when attempting a connector replacement, options are attempting pad repair or jump wiring.
        Laptop Model: MacBook Pro 15 Mid-2014 Retina, A1398 MGXA2LL/A
        eDP Display: Samsung LSN154YL01-A02, assembly sold as Apple part 661-8310
        Soldering Equipment: Hakko FX-888D w/ T-18 tips (Chisel, Conical, Bevel types)
        I needed to replace the 30-pin I-PEX Cabline connector (labeled J8300 in the Apple 820-3662 mainboard schematics),...
        08-03-2023, 12:57 PM
      • michhak
        Toshiba Satellite M50-A keyboard connector on LA-A481P motherboard
        by michhak
        Hi guys,
        i have a damaged keyboard connector on my older Toshiba Satellite M50-A laptop. I know there is LA-A481P motherboard. In attachment pictures there is a real looking connector and i also found a schematic to the connector. But i need help with finding a real electronic part to replace the damaged connector. e.g. on aliexpress (or different page).
        It is 34pin connector and the length from pin n.1 to pin n.34 is 26mm. So it means a pitch length is 0.764 mm. I have seen connectors with 0.5mm , 0.7mm , 0.8mm and 1mm pitch length. But not with 0.75. Is it some special custom connector...
        11-17-2021, 05:45 AM
      • m1ch43lzm
        70mai Dash Cam A510 - help identifying connector on camera module
        by m1ch43lzm
        Hi everyone
        I have a 70mai Dash Cam A510 which failed after about 3 months of being installed in my car, likely due to heat, i got it from aliexpress so no point in trying to return it for warranty (and shipping it back would cost me almost the same as a new one from ali)
        The camera would boot loop showing 70mai logo on the screen, sometimes it would boot fine then the live view would freeze or display purple lines
        I already took it apart, and found out that the camera boots fine if i unplug the camera module from the main PCB, sometimes "playing" with the connector...
        05-11-2025, 06:02 PM
