Finding comparable ferrite beads on mouser/digikey?
  • mrkmpn
    • Apr 2022
    • 62
    I have an inspiron with "power rail failure" LED codes flashing, and have found a blown capacitor and ferrite bead (inductor, I guess...)
    I've found the replacement capacitor on mouser, but am unsure how to properly search for the ferrite bead. I have the schematics and boardview, so I have found the original bead part#, but the data sheet doesn't seem to include the information I need for the filters on mouser and digikey.
    For inductance, and a few other values it just says "Refer to standard electrical characteristics list"
    Here's the datasheet: https://cdn.badcaps-static.com/pdfs/...944368d175.pdf
    Any help finding an alternative would be appreciated, but tips on how to research this on my own would be even more appreciated.
  • mon2
    • 14657
    Re: Finding comparable ferrite beads on mouser/digikey?
    1) Post the details of what is mentioned for the part # from your schematic.
    2) Start with the physical size of the ferrite bead. This is a key parameter.
    3) The current rating should be equal or higher than what was used on the original board.
    4) The resistance is perhaps the last requirement - higher the resistance, the better the component to act like a filter at the specified frequency. You are wanting to block the noise with the higher resistance.
    These parts are more for EMI suppression so that the finished product can pass the FCC emissions testing. Not really a show stopper if you bypass the part but you may notice some extra noise in the room from such emissions which may cause bad WIFI / poor over the air TV reception, etc., etc. (kinda like my house).
    Post more details and can see if we can nail this down. BTW - There is also Digikey / Arrow for a supplier.
    • mrkmpn
      • Apr 2022
      • 62
      On the schematic is says this, just above the diagram for the inductor:
      EMC@ PL600
      HCB2012KF-121T50_0805
      The boardview also says it's an 0805, and according to the data sheet, if I understand correctly the part number is HCB (series) 2012 (metric for 0805 I believe) kf (material) 121 (impedance 120ohm) (T = Tape) 50 = 5000mA
      On the schematic above the inductor diagram, in a different font and color, it says "7.2*1/.9/9=0.89A", above another inductor (PL1000) that has the same part# it says "1.05*2.9/0.9/9=0.375A"
      "These parts are more for EMI suppression so that the finished product can pass the FCC emissions testing. Not really a show stopper if you bypass the part but you may notice some extra noise in the room from such emissions which may cause bad WIFI / poor over the air TV reception, etc., etc. (kinda like my house)."
      I thought it might be something along those lines. The schematic shows the ferrite bead bypassing the open jumper on the board near it.
      "Post more details and can see if we can nail this down. BTW - There is also Digikey / Arrow for a supplier."
      Yeah, I had digikey in the title and had tried there, but my lack of knowledge still prevents me from narrowing down a replacement I know will work. I think I can get the original part from aliexpress, but I'd rather not as long as it would take to receive.
      • mon2
        • 14657
        Here are a few options for you:
        https://www.mouser.com/ProductDetail...CTHSPH1g%3D%3D
        https://www.digikey.ca/en/products/d...21Y00/10508702
        https://www.digikey.ca/en/products/d...ER121V/2575017
        These are very low cost (aside from perhaps the shipping fee) - so best to source them locally in USA rather than offshore. Sometimes, you do not know what you are really purchasing as the vendor can bait and switch. As a manufacturer, we purchase directly from the factory and for ferrite beads / inductors, we prefer MaxEcho (0603 / 0805 ferrite beads) and King Core (EMI filters for our USB designs).
        • piernov
          • Jan 2016
          • 4439
          • France
          That's the impedance (@100MHz) not the resistance. The resistance (DC) should be as low as possible.
          • mrkmpn
            • Apr 2022
            • 62
            Thanks for the information guys. It looks like my biggest mistake was looking in the wrong category. (inductors rather than emi filters).
            I realized I had the correct capactior replacement on hand so I replaced that, and jumpered the connection for the ferrite bead and the laptop works fine as Mon2 suggested. So now I'll get that bead ordered.
            Thanks again
            • swerg
              Part selection for possible blown inductor on ASUS GX531-GW-AB76 laptop mobo
              by swerg
              Hey everyone,
              I'm a novice trying to repair my laptop. The LCD screen has an image, but no LED backlight for the image. It also produces an image when connected to an external monitor.
              I have found what I believe to be a blown inductor labeled "L4502" and "120 Ohm" in the schematics (zoomed in image, blue arrow to blown component). I have included an image of the general area of the mobo and an excerpt from the schematics as well.
              I am having trouble selecting a replacement component, which I believe to be a 120 Ohm ferrite bead, from the components...
              06-06-2024, 03:39 PM
            • ajdrenter
              Picking caps for Antec SU-380
              by ajdrenter
              In my search for a proper 5v heavy ATX power supply, I selected an old Antec SU-380 that I've had in storage for a long time. Opening the power supply reveals a couple bulged capacitors. I removed all the caps and made a map for myself. I found the datasheet for the PCE TUR series in this thread:
              https://www.badcaps.net/forum/showthread.php?t=14159
              It says these are general purpose, so I assume I can replace them with any general purpose capacitors, but I don't really know anything about power supply circuits or reading capacitor datasheets. Despite this, I've been shopping for replacements:...
              05-13-2023, 10:40 AM
            • H H
              3090 FE Part Confirm/Identification
              by H H
              I'm hoping someone could help me confirm if I have identified the following parts correctly.
              Apparently the DP cable became stuck inside the graphics card and was yanked out. This caused some sort of short which burned the DP contacts and blew some resistors and ferrite beads.
              The parts needing replacement are on the back of the board behind the HDMI input.
              I have identified the parts as the following:
              C6037: MLCC 0.1uf/16v(0402)x7R W05
              R6016: RES 499 OHM 1/16W (0402) 1%
              LB10911: Ferrite Bead (0402)...
              02-16-2025, 01:09 PM
            • jordanaudio1
              Samsung TV UN60KU6270F power supply
              by jordanaudio1
              Trying to learn electronics repair as a hobby. I have no formal training in electronics, circuits, etc. Everything I know, which isn't much, has been learned from watching youtube videos, reading books, forums, etc. This means, sometimes I have a hard time understanding and interpreting what's important when I look at datasheets, and such.
              My brother has a TV that I'm working on now. He said he was watching it, he heard a loud pop and it went off. I used my DMM to check the fuse, it was blown. From watching lots of hours of electronics repairs on youtube, I figured that was just a...
              07-07-2025, 07:38 PM
            • mrkmpn
              Need help replacing blown ferrite inductor (I think)
              by mrkmpn
              After installing a replacement screen, the backlighting went out and I discovered what I initially thought was a blown fuse. I reconnected the cracked screen and bridged the "fuse" with tweezers and the backlight came on, so I tried the same thing with the replacement screen and the tweezers just sparked, no backlight came on, and the "fuse" was damaged even more. (And yes, the screens were the same model number. I have received an RMA for the screen already)
              The reason I think it was a ferrite inductor is that 1st, it didn't look like a fuse I'd seen before,...
              06-07-2022, 03:52 PM
