Aulmighty capacitors
  • Digital Technophile
    revrse engineer
    • May 2011
    • 144
    In my ongoing effort to recap the various electronic devices featuring 'lytics, I came across these "Aulmighty" caps in a Siemens Gigaset SE567. The board is a hodgepodge of cap makers, ranging from Nichicon (VZ) and Panasonic (NHG) to G-Luxon (SM) AND Aulmighty "CD268" & "CDSL". I was able to find their website, but their datasheets are for shame (see 6973542 & 5346311 PDFs below). However the CD268 seem to be a series from more than one cap manufacturer (see CD268 & cd268-2 PDFs below). Perhaps they are Chinese government issued design? The 6.3v560uF CDSL cap is bulging and will be replaced; the (5) 25v1000uF CD268 caps aren't but will be replaced regardless. I'm using Nichicon VZ and Panasonic NHG caps as a baseline for replacements as they are quite similar to each other. From the datasheets I've found for CD268 caps, they seem close to VZ and NHG caps in ripple (no value for Z/ESR). The question is the CDSL cap; it's right next to a choke coil, so I suspect it's doing filter duty (which is why it's probably bushy-failed). I'm thinking it would be good to replace this cap with a low-ESR cap?
    So:
    Does anyone have "real" datasheets for Aulmighty CD268 and CDSL series capacitors?
    Is the CD268 a common series among manufacturers (Chinese)?
    Do you think the CDSL was meant to be low-ESR?
    I know the answer, but do you need pictures?
    Were you laughing at the Aulmighty website too? Or just their datasheets?
    If you voted for Obama in 2008 to prove you weren't a racist, you'd better vote for someone else in 2012 to prove you're not an idiot!
  • lti
    • May 2011
    • 2551
    Re: Aulmighty capacitors
    Electronic meter long life electrolytic capacitors with high frequency We are Nantong Tianli Electronics Research Institute,/ Nantong tianzhili Electronic Technology Co., Ltd., specializes in producing high-grade aluminum electrolytic capacitors, we are the designated supplier Siemens. Although the days of power companies do not, but the quality is definitely first class Days of power management concept is: not the biggest, but the best; others do not have, people have my spirit; your needs, our pursuit of We look forward to the opportunity of co-operation, we will sincerely serve you In order to meet international market demand, I launched a full range of environmentally friendly aluminum electrolytic capacitor to satisfy the export demand for voltage: 3V ~ 500V, capacity: 1UF ~ 1F Look forward to your visit! Firmly believe we will win tomorrow!
      revrse engineer
      • May 2011
      • 144
      Ha, ha, ha would you like some white porcelain with your capacitors??? Thinking maybe they should work on their Engrish! In fact I was making an attempt to understand the company name which I've come to the conclusion they meant to spell it "Alumighty" (as in aluminum electrolytic), but instead their Pinyin pros misspelled it Aulmighty.
      To read the PDFs, you have to install Acrobat's "language pack" to view. Ironically, once I did, I discovered there weren't any Chinese characters to be found. Did you try looking at the ones I posted??
      I'm fairly certain the CD268s are similar class to VZ and NHG series caps (albeit with slightly less ripple handling ability), but I was most curious about the lone CDSL cap on this board because it is right next to an inductor (or choke coil, which ever you like). That seems to suggest it's being used as a ripple filter, which would suggest the possibility of it being a low-ESR cap.
      And I know that 2 letter series descriptors like SM across brands coincidental, but CD268??? I've come across several brands with a CD268 series. Odd?
      • lti
        • May 2011
        • 2551
        I didn't want to instal the language pack. The two you posted require the language pack as well.
        A lot of Chinese cap brands use CDxxx series numbers.
        I ththought the brand namewas supposed to be "Almighty."
        Try using a low ESR cap to replace the CDSL. All the site says is that it is rated for high frequency filtering.
        • PCBONEZ
          Grumpy Old Fart
          • Aug 2005
          • 10661
          The 'old name' for capacitor was condenser and the old name is still used in some parts of the world.
          CD268 just means Condenser [CD] - model/series 268.
          That naming convention is not too uncommon from small companies.
          If they cross from brand to brand it's just by chance. - Don't count on it.
          Mann-Made Global Warming.
          - Dr Seuss
          • RJARRRPCGP
            • Jul 2004
            • 6304
            "Windows Internet Explorer pro"
            WTF? Looks like some scum-tampered Internet Explorer.
            There's no such thing as "Windows Internet Explorer pro". Not genuine.
            ASRock B550 PG Velocita
            Ryzen 9 "Vermeer" 5900X
            Arc A770 16 GB
            eVGA Supernova G3 750W
            Alienware AW3423DWF OLED
              revrse engineer
              • May 2011
              • 144
              • pfrcom
                Oldbie
                • Jun 2006
                • 1230
                Presumably referring to the attachment from LTI in post #2
                better to keep quiet and be thought a fool, than to open your mouth and remove all doubt
                • b700029
                  Banned
                  • Sep 2010
                  • 640
                  I think there is at least some similarity, for example CD17 is always Photo Flash capacitor series:
                  http://www.jianghaius.com/Pe/CPML1.htm
                  http://www.js.cei.gov.cn/jsmeio98/0600008/entdrqcq.htm
                  https://cdn.badcaps-static.com/pdfs/...50849d2066.pdf
                  • lti
                    • May 2011
                    • 2551
                    The rest of the title was cut off. It is actually "Windows Internet Explorer provided by Qwest." The Qwest setup/diagnostic software changed the title. It isn't Internet Explorer Pro.
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      Yet in this brand they aren't even lytics.
                      - Dr Seuss
                      • Ady2017
                        Are there any datasheets available for Elna RJG capacitors?
                        by Ady2017
                        I have a 2007-era Panasonic VHS combo that is full of of Elna RJG capacitors. I am trying to test the capacitors to diagnose the machine and then select replacement capacitors but I can not find any datasheets for them. I did find a Elna catalogue from 2007-2008 but there is no mention of this capacitor series. Where these specially made for Panasonic and so not made available to the public? Any ideas what to find out what the ESR values should be without the datasheets? They are all between 10V and 50V and 47uF and 1800uF. None are leaking or bulged but I know that they need to be tested to be...
                        05-25-2025, 02:19 PM
                      • dragon3x
                        After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                        by dragon3x
                        Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                        power on.
                        Here are some examples :
                        (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                        switching supply area).
                        (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                        than 6.3 V.)
                        1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                        I replaced capacitors with aluminum-polymer.
                        3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                        03-21-2025, 02:46 PM
                      • slybunda
                        AA and AAA battery charger capacitors?
                        by slybunda
                        hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
                        it has inside:
                        2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
                        2 x 470uf 16v LZ105c branded as G.Luxon
                        not heard of these brands are they any good?
                        iv attached photos of the charger and the board inside for an idea on the type of...
                        12-24-2023, 04:41 AM
                        by sam_sam_sam
                        After all of...
                        07-13-2024, 08:14 PM
                      • ctroxtell
                        Samsung UN70tu7000wxza no standby light, do I have bad capacitors?
                        by ctroxtell
                        I picked up a 70" Samsung UN70TU7000WXZA. The original owner said they were watching it when the power surged and knocked it out. I pulled the back off the TV and disconnected the main board from the power board, and the LED backlight came on, which I was told meant the power board was good. When everything is plugged in the standby light will not come on, looking at the main board BN94-17775A with a thermal imaging gun I can see one of the chips labeled 3202 is 251 degrees F just sitting idle. I found a replacement board, BN94-16115X; this board has the same symptoms, except it is a different...
                        01-03-2025, 08:57 PM
