Could this problem be due to a bad cap? [pic included]
  • {RainmakeR}
    • Jan 2006
    • 10
    I have a little Soltek QBIC 3701M SFF PC (circa 2003) used as a media center PC in my living room. Being small form factor, it's expansion options are limited, and it only has one PCI slot and one AGP slot. The PCI has a digital TV card in it, and about a year ago I got a Leadtek FX 5900 XT to fill the AGP slot. Well, the card worked OK but there was some glitching when changing channels with the digital TV card.
    I thought it must be power because at the time it only had a 200W PSU, and when I tested the system with an external 350W PSU plugged in to the GPU, the glitches seemed to go away. So I set out to find a higher power replacement PSU, which turned out to be an extremely long and difficult exercise since it uses a very uncommon long thin form factor of PSU (FLEX-ATX).
    Eventually (after many months of searching and e-mailling) I discovered that the Shuttle Silent-X PSUs, although 4cm or so longer, would fit in place of the Enhance 200W, so I ended up putting in a Shuttle PC40 250W PSU recently, which works well. However, when I put the 5900 XT back in, it wouldn't work correctly -- as soon as Windows loads the drivers, it hangs or BSODs. It boots up fine, BIOS works and *most* of the time, safe or VGA modes work of Windows, but as soon as it boots proper, tries to load (or even install) any of the ForceWare drivers (I tried 6x.xx, 7x.xx and 8x.xx series), it crashes. Sometimes Windows will almost load the "Welcome" screen but it hangs after a moment and you see some display corruption (odd pixels here and there). So I purchased another card, an XpertVision 6200. It had exactly the same problem, yet both of these cards worked fine in another system. Oddly, an old GF4-4200 worked fine.
    Interestingly, ATI cards seem to work fine also - a 9800 Pro, a 9600 and a 9550 have all worked fine in this PC (yet, all of the cards that work correctly have terrible quality TV-out compared to the nVidia, and since this is used primarily for digital TV through s-video, it's kinda a backwards step). It seems modern nVidia cards refuse to work on this box, yet the 5900 XT *DID* work in the past, even with the 200W PSU -- which I tried again in place of the 250W -- it just refuses to work *now*.
    I tried everything, and I mean everything to try and get the cards to work, formats, reinstalls, different drivers for GPU and chipset, older service packs, bios settings, mobo jumper settings, removing hardware, IRQ settings, removing/reseating/swapping RAM... nothing works. Eventually I wondered if I might have a bad cap issue... I looked over the board carefully with a flashlight, and it seems most caps appear to be Sanyo with a K vent and are not bulging, and I also could not see any leaking electrolyte. However, there is one cap with an X vent wedged in between the AGP and PCI slots that looks very suspicious to me, I cannot see any leaks at the top or underneath, but it definately looks like it's bulging... I can't quite see the make of it but it also looks like a Sanyo?
    Here is a detailed pic:
    OK... so, does that cap look bad, and could it be causing my problems? (and if so, why is it only modern nVidia cards that are failing yet ATI cards -- including 9800 Pro -- work fine?) What do I do now? :\
    System specs:
    • Soltek QBIC EQ3701M, circa 2003
    • SL-B7A-F motherboard
    • Athlon XP 2500+ Barton core
    • nForce2 chipset, on-board GF4MX with TV-out
    • 2 x 256MB Corsair PC3200 Twin-X dual channel RAM
    • Nebula Electronics DVB-T card (PCI)
    • Seagate 7200.7 120GB HDD
    • LG DVD-RAM drive
    Kind regards,
    {R}
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16958
    Re: Could this problem be due to a bad cap? [pic included]
    OMFG, the Holy Bible!! J/K
    From the pic, there's no doubt about the bad capacitor though. Replace all 1000uF and up.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • {RainmakeR}
      • Jan 2006
      • 10
      Hahaha, sorry, it's been quite an ordeal I've been through, I had to share. ;(
      So you think it definately looks bad and that it could be causing my probs? All the other caps look ok, it's just that one... I spose I could try to replace it but I do suck at soldering - maybe I should find someone else to do it who is good at it.
      • Per Hansson
        • Jul 2005
        • 5895
        • Sweden
        That capacitor is definitely bad.
        And it is definitely not a Sanyo, I would bet on it being a GSC capacitor, I'm holding a GSC in my hand right now comparing with the pic you posted and it looks exactly the same, that logo on the stripe, the GSC name should be facing the AGP slot, and the farad and voltage rating should be facing the other direction (the white populated PCI slot)
        It is most likley the cause of the problem; either the other cards has better power filtering on their own or they consume less power which this bad cap is still able to provide...
        If the other capacitors are not of this make but Sanyo (which is a excellent brand) only swap this one out... But take the mobo out of the case and look it very carefully over so you do not miss another bad cap...
        BTW; That was an excellent photograph!
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16958
          That cap is definitely NOT a Sanyo. Sanyo/Nippons have a "K" vent. As mentioned, thats a GSC or a Lelon most likely.
          Team : 49813
          Join in!!
          Team Stats
          • Per Hansson
            • Jul 2005
            • 5895
            • Sweden
            Here is a high-res pic stolen from ixbt.com that shows that indeed all caps except that one between the AGP and PCI slot is a Sanyo... There are also 4 Panasonic T-Vent caps on the top of the board used for the input side of the VRM circuit that are most likley just fine too...
            The smaller caps below 500uF on the board can be pretty much anything but are probably fine too, just swap out that cap between the AGP and PCI slot and you should be fine again...
            http://www.ixbt.com/mainboard/images...7a-f-board.jpg
            EDIT; After washing my glasses I now see another crap cap right between the south and northbridge on the mobo...
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16958
              Originally posted by shoddy web server
              Forbidden
              You don't have permission to access /mainboard/images/barebones-2k3-jul/eq3701m/b7a-f-board.jpg on this server.
              Apache/1.3.34 Server at www.ixbt.com Port 80
              Team : 49813
              Join in!!
              Team Stats
              • Per Hansson
                • Jul 2005
                • 5895
                • Sweden
                Meh, I'll steal it for real instead of hotlinking then
                Image source
                • {RainmakeR}
                  • Jan 2006
                  • 10
                  LOL... good find... well there you go guys, that's my tiny mobo... I'll have to check that other one in-between the bridge chips closely. Hopefully it looks like there won't be that much to replace, I let out a sigh of relief when I saw most were Sanyo's. Wow this forum rocks, you guys got straight onto this and are obviously very knowledgeable, thanks!
                  P.S. I'm crap with a soldering iron so I hesitate to do the replacing myself... any ideas? I'm in Australia, perhaps I could find a local electronics tech that could do it?
                  • {RainmakeR}
                    • Jan 2006
                    • 10
                    Thanks, that was an excellent reply! It's amazing what a digital camera with macro turned on can do... took me a few tries to get it focused right but came out good... a picture speaks a 1000 words, in this case looks like it helped.
                    • Per Hansson
                      • Jul 2005
                      • 5895
                      • Sweden
                      Someone that has been into TV Repair or similar should be able to do it...
                      It is a bit more tricky though since it is a multi layered PCB so the vias must be taken care off, i.e. it must be very gently done...
                      Make sure that the new caps you put in are LOW or ULTRA LOW ESR and are rated for 105°C
                      EDIT; This is totally on topic... If you have Opera scroll up to {RainmakeR}'s first Pic in the thread and down your resolution to max 1152x864 so it coveres the whole screen. Then grab the pic with the mouse and fucus your eyes on the bad cap, now make a very small circular motion with the picture... Woo, being drunk for free!!! Weeee
                      Doctor in white clothing; Per, come here now, and why are you <THUD>
                      Per: Muahahahahaha
                      • {RainmakeR}
                        • Jan 2006
                        • 10
                        Ok, thanks heaps... any particular good brands to look out for (in terms of replacement caps)? I hear Rubycon is good, as well as Sanyo and Panasonic as mentioned above.
                        • Per Hansson
                          • Jul 2005
                          • 5895
                          • Sweden
                          I don't have the list, it's in one of the threads here at badcaps... All good brands and the types of caps they make listed from good to best...
                          • {RainmakeR}
                            • Jan 2006
                            • 10
                            Thanks, I will look for it. BTW, just a followup, I just looked at the board again with the flashlight, turns out the other dodgy cap in the motherboard picture above is actually a Panasonic T-vent cap on mine, and where the Panasonic T-vents are on the picture are actually more Sanyo K-vents on mine. So.... hopefully only one to replace then!
                            • linuxguru
                              • Apr 2005
                              • 1564
                              Considering the dodgy reputation that Soltek has, it's a bit of a surprise that most of the caps on this board are good caps - like the row of Panny FCs (?) on the high-voltage side of the VRM buck-converter. What are the values on these - 1000/16 ?
                              • {RainmakeR}
                                • Jan 2006
                                • 10
                                Well, I took the motherboard to a local electronics technician this morning (wouldn't trust myself to do the replacing), and seriously in less than a minute he had it replaced with brand new cap rated at 105C, 2200uF 16v:
                                Just reinstalled all the hardware, and guess what? VIDEO CARD WORKS ABSOLUTELY FINE!!! YAY!!!!!!!!!!!!!!!!! He didn't even charge me for the work, just 90 cents for the capacitor! He even used an air compressor to blow dust off the mobo while I went to get the capacitor from a supplier (he didn't have one thin enough for between the slots). To say I'm happy now would be an understatement.
                                • Chris1992
                                  • Apr 2005
                                  • 561
                                  What brand is the new cap?
                                  The great capacitor showdown!
                                  • MD Willington
                                    • Sep 2004
                                    • 702
                                    FYI, in case you guys were not aware, Soltek has left the mainboard business...
                                    Ya'll think us folk from the country's real funny-like, dontcha?
                                    The opinions expressed above do not represent those of BADCAPS.NET or any of their affiliates.
                                    • {RainmakeR}
                                      • Jan 2006
                                      • 10
                                      "Suntan", lol. Sounds dodgy but it does work, at least for now.
                                      • Chris1992
                                        • Apr 2005
                                        • 561
                                        Suntan? LOL. Is it low ESR?
                                        • mecha1166
                                          KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen.
                                          by mecha1166
                                          KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen. Already tried reset POWER/VOL-. Anyone else have this problem? Possibly bad T-Con RUNTK4244ZZ or panel? Could main or power supply cause this? There were 2 blown 560u 35v on power going to backlights but they were still working fine. Thanks for your help.
                                          11-25-2024, 05:22 PM
                                        • CapLeaker
                                          Dell ATX PSU won’t start, but forcing it works fine?
                                          by CapLeaker
                                          Got a case of something new weird at work. There is an old 2nd gen Intel i3 in an old “Pizza box” shell that has a small form factor power supply. Unfortunately I forgot to take pictures and model number off it.
                                          Anyway, I get to work and get to look at this computer. Standby LED on the PSU is on, but the computer won't start. Hmm o.k. take the battery out of the main board try again, nothing. O.k. then… unplug the power supply from the main board and put in a full size ATX PSU (yeeeesss! Exact that blown Powerman IP that I fixed a while back), plug it in and the old...
                                          10-28-2024, 06:59 PM
                                        • emil_t
                                          RTX3090 working fine but fans not spinning
                                          by emil_t
                                          Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
                                          04-12-2024, 06:54 AM
                                        • edugimeno
                                          TD Systems K50DLP8F works fine on 1 HDMI, bad on others
                                          by edugimeno
                                          I have this TV set that I spent a long time fixing it.
                                          I finally found a shorted SMD capacitor near the plug from the PS at the main board. It was shorting one of the main voltages (can't remember which one)
                                          I removed that capacitor, and as it has another one in parallel, I left it with only one, checked it and it seemed to work fine. The solder near that capacitor was really delicate as I pulled apart one trace so I prefered to not mess much with it after I had to air solder one small thread of copper
                                          I didn't use that TV much at that time. Now that I'm using it,...
                                          10-06-2023, 03:00 PM
                                        • kamiewtype
                                          MPG Z590 No display output with known working GTX 1060/RTX 3070, works fine with GTX 1030
                                          by kamiewtype
                                          I have a customer machine on my bench right now that's stumped all the techs, so I decided to come here for help.
                                          The specs are:
                                          MPG Z590 Gaming Carbon Wi-Fi (MS-7D06)
                                          Intel core i9-10900kf
                                          2x16gb Corsair Vengeance kit
                                          BIOS ver is E7D06IMS.1B0, from 6/12/2023
                                          The machine was brought in because it would not POST after a GPU upgrade from a GTX 1030 to an RTX 3070. The customer also brought in the original GTX 1030, as well as a GTX 1060 that the machine also wouldn't POST with.
                                          I tested the 1060 and 3070 on my bench (ASRock X570 Phantom Gaming...
                                          11-01-2024, 10:52 AM
