Could this problem be due to a bad cap? [pic included]
  • {RainmakeR}
    • Jan 2006
    • 10
    Re: Could this problem be due to a bad cap? [pic included]
    Originally posted by Chris1992
    Suntan? LOL. Is it low ESR?
    Apparently so.
    • Rainbow
      • Aug 2005
      • 1371
      Anything is better than GSC
      • Newbie2
        • Sep 2005
        • 885
        Suntan? That's the first time I heard about that. Seems to be low-ESR, since RainmakeR's cap is rated for 105 degrees, that's what it shows on the picture.
        My gaming PC:
        AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
        ASUS M4A77TD AMD 770 AM3 Motherboard
        PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
        G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
        TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
        WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
        ASUS Xonar DG 5.1 Channel PCI sound card
        Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
        Antec Three Hundred Mid-Tower Case
        Microsoft Windows 10 Pro 64-bit
        Microsoft Windows 7 Ultimate SP1 64-bit
        • mecha1166
          KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen.
          by mecha1166
          KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen. Already tried reset POWER/VOL-. Anyone else have this problem? Possibly bad T-Con RUNTK4244ZZ or panel? Could main or power supply cause this? There were 2 blown 560u 35v on power going to backlights but they were still working fine. Thanks for your help.
          11-25-2024, 05:22 PM
        • CapLeaker
          Dell ATX PSU won’t start, but forcing it works fine?
          by CapLeaker
          Got a case of something new weird at work. There is an old 2nd gen Intel i3 in an old “Pizza box” shell that has a small form factor power supply. Unfortunately I forgot to take pictures and model number off it.
          Anyway, I get to work and get to look at this computer. Standby LED on the PSU is on, but the computer won't start. Hmm o.k. take the battery out of the main board try again, nothing. O.k. then… unplug the power supply from the main board and put in a full size ATX PSU (yeeeesss! Exact that blown Powerman IP that I fixed a while back), plug it in and the old...
          10-28-2024, 06:59 PM
        • emil_t
          RTX3090 working fine but fans not spinning
          by emil_t
          Hello guys. I have a problem with a PNY XLR8 GAMING RTX3090 graphics card. The problem is that it displays and works fine, but the fans don't spin at all. The problem occurred when someone else removed the fans in order to clean it and broke one of the fan connectors. He replaced it himself and after that, it wasn't working anymore. I guess he damaged something else in the process. What i have done so far: I found 2 capacitors next to the connector that were in a bad shape, he must have touched them with his tools - they weren't shorted, but i replaced them with similar ones from a similar card....
          04-12-2024, 06:54 AM
        • edugimeno
          TD Systems K50DLP8F works fine on 1 HDMI, bad on others
          by edugimeno
          I have this TV set that I spent a long time fixing it.
          I finally found a shorted SMD capacitor near the plug from the PS at the main board. It was shorting one of the main voltages (can't remember which one)
          I removed that capacitor, and as it has another one in parallel, I left it with only one, checked it and it seemed to work fine. The solder near that capacitor was really delicate as I pulled apart one trace so I prefered to not mess much with it after I had to air solder one small thread of copper
          I didn't use that TV much at that time. Now that I'm using it,...
          10-06-2023, 03:00 PM
        • kamiewtype
          MPG Z590 No display output with known working GTX 1060/RTX 3070, works fine with GTX 1030
          by kamiewtype
          I have a customer machine on my bench right now that's stumped all the techs, so I decided to come here for help.
          The specs are:
          MPG Z590 Gaming Carbon Wi-Fi (MS-7D06)
          Intel core i9-10900kf
          2x16gb Corsair Vengeance kit
          BIOS ver is E7D06IMS.1B0, from 6/12/2023
          The machine was brought in because it would not POST after a GPU upgrade from a GTX 1030 to an RTX 3070. The customer also brought in the original GTX 1030, as well as a GTX 1060 that the machine also wouldn't POST with.
          I tested the 1060 and 3070 on my bench (ASRock X570 Phantom Gaming...
          11-01-2024, 10:52 AM
