Heres the deal.
  • smason
    • 1652
    Re: Heres the deal.
    Originally posted by steve2
    If you know someone at the geek squad where you work, they may be able to solder it for you.
    Geek Squad, and solder? You can't be serious.....
    • marinesman215
      • Feb 2011
      • 33
      Re: Heres the deal.
      Sorry.. I may be lost.. So dont replace all 12...??
      • marinesman215
        • Feb 2011
        • 33
        Re: Heres the deal.
        They will be marked with ???UF which is the capacitance. They will have 85c or 105c for the temp range. Usually have a series FC, Fm , Hm, etc. You would want to try to match that series or upgrade it. Then you have the voltage rating which is how many volts it can handle. I didn't figure to take the whole tv in to geek squad. Just the board with the bad caps.
        I saw the 105c; GL 105c...
        • marinesman215
          • Feb 2011
          • 33
          Re: Heres the deal.
          Originally posted by Wizard
          I've already spotted these capacitors in that corner, replace just the bloaters with good quality capacitors, all you need are the uF and voltage info. Rest will last for long time.
          I have done this for a living.
          Cheers, Wizard
          Im still not sure what are bloated and which arent...
          • Th3_uN1Qu3
            Believe in
            • Jul 2010
            • 6031
            • Romania
            Re: Heres the deal.
            I assume you do have fingers, otherwise you couldn't type. If you bothered to put your finger on the top of the caps you would have realized which are bloated on your own (as if it weren't obvious with visual inspection only).
            A working TV? How boring!
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              #26
              Re: Heres the deal.
              thats a 15 minute job for me.
              use panasonic fm or equivilant.all the capxon's on the secondary side of the transformers gotta go.
              this is an incredibly simple job.do a bit of reading here then go for it!
              • marinesman215
                • Feb 2011
                • 33
                #27
                Re: Heres the deal.
                Dude.. This is the first time I have ever looked inside of a TV, I appreciate the help but maybe try to scrape off a layer of attitude... I tried not to touch those things because I didnt know if it was okay too... I didnt know if they were all different sizes on purpose.. Thats why I'm here is cuz I dont know (as if it weren't obvious).
                • marinesman215
                  • Feb 2011
                  • 33
                  #28
                  Re: Heres the deal.
                  Deleted.
                  • bluto
                    • Oct 2007
                    • 560
                    #29
                    Re: Heres the deal.
                    I fixed a Samsung very similar to this with bad caps:
                    https://www.badcaps.net/forum/showthread.php?t=9651
                    Samsung seems to be the most plague ridden name brand in the last few years. Most of my threads I have started on BCN are about Samsung products! Which is a shame because their products seems well built. They just keep cutting corners on the caps.
                    • marinesman215
                      • Feb 2011
                      • 33
                      #30
                      Re: Heres the deal.
                      Yea, I was just looking.. it seems there are 5 caps I need to replace.. Should I replace them all.. I was looking at both the FC and FM series... does it matter which one I use.. I dont understand all the Related Voltage Range, and the Normal Cap range.. If I'm looking for similarity the FC series seems to be closest to the spec of the GL Capxon caps I have now....
                      • steve2
                        • 121
                        #31
                        Re: Heres the deal.
                        I've never been to geek squad. I just figured they had someone that soldered some things.
                        • marinesman215
                          • Feb 2011
                          • 33
                          #32
                          Re: Heres the deal.
                          Who needs geek squad when you can do it yourself? haha
                          • steve2
                            • 121
                            #33
                            Re: Heres the deal.
                            Haha. Well, the Navy taught me that as soon as I finished boot camp in 79. 20 + years repairing aircraft and the boxes that came out of em. Learn to use alot of test equipment.
                            • marinesman215
                              • Feb 2011
                              • 33
                              #34
                              Re: Heres the deal.
                              Thats even better I'm trying to get the NROTC scholarship for Marine Corps.
                              • bluto
                                • Oct 2007
                                • 560
                                #35
                                Re: Heres the deal.
                                I would replace them all with FC. The voltage on the replacement should be equal or higher than the one you are replacing. An easy way to search for them on digikey.com is to type in something like "FC 1000uf 16v" in their search box if you were looking for an FC series, 1000uf 16v cap. You should get 4 hits on that search. Ignore the 2 surface mount versions and you will see that there are two choices for FC series 1000uf, 16v. The only difference between the two is the size. Just substitute the uf and v numbers in the search with the ones that you read off of the bad caps and you can't lose.
                                • steve2
                                  • 121
                                  #36
                                  Re: Heres the deal.
                                  Like bluto says, replace them all. It's only a couple $ for the others also. Better than the tv messing up again in the future to see the other caps bloated. Good luck with the NROTC. The Marines are always looking for a few good men cause they haven't found any yet. haha. Just kidding. Navy and Marines always kidded each other, but worked well together.
                                  • marinesman215
                                    • Feb 2011
                                    • 33
                                    #37
                                    Re: Heres the deal.
                                    Navy, Navy I'm in doubt, at why your bellies are sticking out,
                                    Is it whiskey or is it wine?
                                    Or is it a lack of PT Time!
                                    Favorite Cadence...
                                    • steve2
                                      • 121
                                      #38
                                      Re: Heres the deal.
                                      We had too much work to do keeping the jets flying off the carriers to have time to PT. Never cared too much for whiskey or wine. I spent 90% of the money I made on beer and women. I wasted the rest. Port visits were great.
                                      • TheLaw
                                        • Jan 2011
                                        • 477
                                        #39
                                        Re: Heres the deal.
                                        Well....for a one time job, or maybe you'll want to do more of it, a $15 soldering iron from Radio Shack, a $3 spool of solder wick, and $3 in capacitor is good.
                                        Do you have to give the TV back? Or can you keep it....?
                                        • Th3_uN1Qu3
                                          Believe in
                                          • Jul 2010
                                          • 6031
                                          • Romania
                                          #40
                                          Re: Heres the deal.
                                          Important keywords have been mentioned in here before you asked this. You should have used them. If you looked for "bloated capacitors" on google you would have found lots of pictures showing things similar to what you have in your TV. That way you wouldn't have had a problem with my attitude.
                                          • xfreaksus@gmail.com
                                            Need schematic for Ayaneo Geek (black edition)
                                            by xfreaksus@gmail.com
                                            Hi, anyone here have information of ayaneo geek (black edition) schematic? thanks
                                            08-11-2025, 03:50 AM
                                          • capwizard
                                            How to deal with huge LCD screen when we are replacing the TV LED backlight?
                                            by capwizard
                                            Does anyone have a better way to deal with 70-inch TV or above LCD screens which are very easy to break when we change the LED backlight?
                                            I'd broken 10 TV screens already.
                                            One of my friend has 75 inch edge TV with one LED not working. I said : just leave it alone.
                                            Is there a better way to ensure that the LED TV screen will not break? I need 100%. I can't afford the Robot either.
                                            01-29-2019, 10:11 AM
                                          • reformatt
                                            Macbook display shortage in China?
                                            by reformatt
                                            Aftermarket screen prices have jumped for all Apple laptop display assemblies recently. I got something in Chinglish from a supplier on Whatsapp:
                                            Latest news on supply of Macbook screen with top covers
                                            1. Industry inside news: macbook screen with top covers with logo won't be restocked in the short term. The product selling now are all from the factories existing inventory. No factory will dare to produce new products in the short term. First come, first served.
                                            2. The supply of Macbook LCD only is normal and will not be affected by this goverment interview...
                                            11-04-2025, 06:11 PM
                                          • gleniu
                                            Lenovo IdeaPad Gaming 3 15ACH6 - no power
                                            by gleniu
                                            Hi, I have a problem with a Lenovo IdeaPad Gaming 3 15ACH6 laptop. My nephew asked me to replace the charging port because the laptop wasn't charging. This issue had happened in the past, so I knew that replacing the port was only a matter of time. Until now, my nephew managed to deal with the problem using a temporary solution: bending the positive metal tabs inside the port with a thin tool. However, this had stopped helping for a while. Today, I replaced the port – and to my surprise, after the replacement, nothing happens when I plug in the charger: the power LED doesn't light up, the laptop...
                                            10-27-2025, 01:13 PM
                                          • AustinCER
                                            Dell XPS 8940 | Manufacturing Mode? | No Service Tag
                                            by AustinCER
                                            Hello, I currently have a Dell XPS 8940 in our office for repair.
                                            Service Tag: HG1Y673
                                            The most recent BIOS is pictured below -- being available as an .exe on Dell website.
                                            Needed a new motherboard due to power surge. The motherboard replacement was installed and upon power up it was booting to a display message - Manufacturing Mode Active -
                                            Have not dealt with this issue before or what the proper steps are. I booted to the BIOS and manually entered the Service Tag, but upon each reboot -- the service tag is wiped and shows the Manufacturing Mode display message,...
                                            07-15-2025, 05:28 PM
