Can i use i to recap psu? I have one that i took out of a dead printer. Im not home right now iirc its a 330u 35v
Is samxon gr suitable for psu use?
Re: Is samxon gr suitable for psu use?
"I" is always spelled in uppercase.
Samxon "GR" is always spelled in uppercase.
"PSU" is always spelled in uppercase.
"Can i use i to recap psu?" is not a proper sentence.
"I am" is shortened as "I'm", not "Im".
There is no such thing as a 330u capacitor, it is a "330uF" capacitor.
There, anything else I can help you with?
"The one who says it cannot be done should never interrupt the one who is doing it." -
Does Samxon ever capitalize the X, I think that is only CapXon. J/K :PMy Computer: AMD Ryzen 9 3900X, Asrock X370 Killer SLI/AC, 32GB G.SKILL TRIDENT Z RGB DDR4 3200, 500GB WD Black NVME and 2TB Toshiba HD,Geforce RTX 3080 FOUNDERS Edition, In-Win 303 White, EVGA SuperNova 750 G3, Windows 10 ProComment
"That's".
Have you looked up the spec sheets for the GR series? While I don't know the answer to your question, you'd probably need to know the specs for the series as well as the location (which circuit) in the power supply you will be using it in.Comment
Unless I'm blind (which isn't totally out of the question), I don't see a GR series from Samxon:
http://samxon.com/samxon_series_chart.htmlComment
Come on, everyone, stop annoying shovenose over the typos. We all make them.I love putting bad caps and flat batteries in fire and watching them explode!!
Office PC: HP ProLiant ML150 G3, 2x Xeon E5335 2GHz, 4GB DDR2 RAM, 120GB Intel 530 SSD, 2x 250GB HDD, 2x 450GB 15K SAS HDD in RAID 1, 1x 2TB HDD, nVidia 8400GS, Delta DPS-650BB 650W PSU, Windows 7 ProComment
There is such thing as a CapXon GR (). It looks like CapXon GR = CapXon GS.
CapXon and Samxon sometimes share series names (I have a feeling that they are somehow related). If CapXon GS = SamXon GS, then it is an 85*C cap. These are always general purpose and not for PSU use.
My theory could be worng, though, so wait for someone more experienced like PCBONEZ or Toasty to chime in.
Also, shovenose, could you post a picture of the cap?Last edited by c_hegge; 10-07-2010, 05:35 PM.I love putting bad caps and flat batteries in fire and watching them explode!!
I cant post pictrures. Sorry. But. Have some more caps to get info on wheher theyre ok for psu use.
Rubycon yk, rubycon zl, samxon gr, sanyo ca, nichicon vr, ost rls. Taicon hf, lelon rga. I need to know if these have low esr, and are good for psu, mobo , tv, etc.
Thanks!Comment
https://www.badcaps.net/store/produc...roducts_id=110
That will be fine. Most PSU caps in the secondary aren't ultra low ESR and they don't need to be. Most are typically a more 'general purpose' 105* cap. Using ultra low ESR caps in some PSU's can cause strange behavior. Samxon GT and RS series I've found to be ideal for PSU's.<--- Badcaps.net Founder
Badcaps.net Services:
Motherboard Repair Services
http://folding.stanford.edu/
Team : 49813
Join in!!
Team StatsComment
The only way you'll know is by tracking down the spec sheet for the original cap that has failed. Not knowing that, I wouldnt have any idea.....but of the many many hundreds of PSU's I've recapped, I don't foresee it being a problem.<--- Badcaps.net Founder
Team : 49813
Join in!!
Team StatsComment
no.<--- Badcaps.net Founder
Team : 49813
Join in!!
Team StatsComment
This specification for the Acer Aspire A315-51-330U Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A315-51-330U boardview and A315-51-330U schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-06-2024, 06:00 AM
by chth96Hello.
I have 29inch LG CRT TV,And Yesterday,Whenever I connect AC power cord to power outlet without switch on, I heard a sound like white noise, And When I switched on this CRT TV, It sometime displayed correctly But usually It won't last more than 20 minute and The screen begin to dark and It finally did not display at all for hours..
Today,I dismantled its plastic case and discharged the biggest capacitor(400wv 470uf) which still holds 250 voltage,and I finally detached PCB from cathode-ray tube.
I measured ESR value of most of caps in PCB with MESR-100 and I found that KME(25v...-
by ezeniaHello,
I am not sure where exactly to put this thread, so hopefully this is the best place.
I have a USB fan that has suddenly been unable to increase its speed. It's just stuck on the first speed. This fan has 3 speed settings. Each time you press the power button, the speed of the fan should increase.
The way the button works with each press is: Speed 1 > Speed 2 > Speed 3 > OFF
Speed 2 and 3 don't currently work any more.
I suspect the issue might be with what looks to be some kind of driver IC. It is a 16-pin... -
I need your advice.
-SAMXON 2200uf 50V tested 0.00 esr on Dick Smith Blue Esr meter and 2027 ohm on FLUKE 179 multimeter.
-Is this esr reading realistic?
Thank you-
by bembenowhat is the suitable alternative for transistor A1941
- Loading...
