Is samxon gr suitable for psu use?
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16959
    Re: Is samxon gr suitable for psu use?
    I didn't see it if they did post it.....and if they did, it's false.
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
    • shovenose
      Send Doge Memes
      • Aug 2010
      • 6575
      Ok.
      • c_hegge
        • Sep 2009
        • 5219
        It may very very slightly increase the ESR, but the difference will probably not be anywhere near enough to bring it up to what the PSU is designed for.
          Acer Aspire A315-51-330U Notebook 3 Specification for Upgrade or Repair
          This specification for the Acer Aspire A315-51-330U Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the A315-51-330U boardview and A315-51-330U schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
          09-06-2024, 06:00 AM
        • chth96
          Can I replace KME cap with Samxon GF cap?
          by chth96
          Hello.
          I have 29inch LG CRT TV,And Yesterday,Whenever I connect AC power cord to power outlet without switch on, I heard a sound like white noise, And When I switched on this CRT TV, It sometime displayed correctly But usually It won't last more than 20 minute and The screen begin to dark and It finally did not display at all for hours..
          Today,I dismantled its plastic case and discharged the biggest capacitor(400wv 470uf) which still holds 250 voltage,and I finally detached PCB from cathode-ray tube.
          I measured ESR value of most of caps in PCB with MESR-100 and I found that KME(25v...
          04-17-2024, 07:11 AM
        • ezenia
          Suitable replacement IC? .PCB - X_BFJSFANRE_RLED_V4
          by ezenia
          I am not sure where exactly to put this thread, so hopefully this is the best place.
          I have a USB fan that has suddenly been unable to increase its speed. It's just stuck on the first speed. This fan has 3 speed settings. Each time you press the power button, the speed of the fan should increase.
          The way the button works with each press is: Speed 1 > Speed 2 > Speed 3 > OFF
          Speed 2 and 3 don't currently work any more.
          I suspect the issue might be with what looks to be some kind of driver IC. It is a 16-pin...
          06-20-2023, 05:22 AM
        • GEARELECTRONICS
          Samxon capacitor esr
          by GEARELECTRONICS
          I need your advice.
          -SAMXON 2200uf 50V tested 0.00 esr on Dick Smith Blue Esr meter and 2027 ohm on FLUKE 179 multimeter.
          -Is this esr reading realistic?
          Thank you
          05-29-2023, 07:26 AM
        • bembeno
          what is the suitable alternative for transistor A1941
          by bembeno
          07-20-2022, 01:58 PM
