#1 | |
My Dell 3008wfp screen shut off completely one day. I took it to an engineer who replaced some parts on the power supply, and it worked for a short time before it died again. He replaced some more parts, but the same thing happened again, twice. Unfortunately for me I had bought a refurb model which only had a 1 year warranty.
The engineer tells me Quote:
![]() Last edited by gajones; 04-13-2011 at 09:59 AM.. |
#2 |
o.O
City & State: Duisburg
My Country: Germany
Line Voltage: 230VAC 50Hz
would be odd for it to blow for no reason.
pics would help.. datasheet http://bambooz.pytalhost.net/badcaps..._datasheet.pdf
The USA have Barack Obama, Bob Hope, Stevie Wonder and Jonny Cash. We have Angela Merkel, no hope, no wonder, no cash.
#3 |
City & State: Canada
--- begin sig file --- If you are new to this forum, we can help a lot more if you please post clear focused pictures (max resolution 2000x2000 and 2MB) of your boards using the manage attachments button so they are hosted here. Information and picture clarity compositions should look like this post. We respectfully ask that you make some time and effort to read some of the guides available for basic troubleshooting. After you have read through them, then ask clarification questions or report your findings. Please do not post inline and offsite as they slow down the loading of pages. --- end sig file --- |
#4 |
hi my name is zen.just joined site.
i am the engineer currently working on this psu. as gajones has posted my findings,i will add a bit more info. i have about 20 years experience working in the electronics repair industry.mainly tv and audio. i'm normally quite good with power supplies,but this one is difficult to work on as the diode mentioned only seems to blow after unit has been re-assembled and then after working for a few days. i even managed to source the exact same diode from china as opposed to an equivalent i had replaced with originally. i have replaced a few other components on the 14 volt rail which diode D22 is the rectifier of. have also checked the electrolytic caps on that rail.they all have good esr readings and are high quality 125 degree ones aswell. as i'm not that familiar with dell psu's,i guess i need advice from someone use to working on them. will try and post some photo's when i have a chance to strip monitor down again. a schematic of the psu may also be useful. thanks |
#5 |
On my level
I think the 120v reverse voltage rating of the diode is a bit tight. If he lives in an area with high mains and the transformer has high leakage inductance then the voltage at the diode could spike higher than that. I would advise a 200 volt replacement.
#6 |
City & State: uk
My Country: uk
Line Voltage: 230v 50hz
I'm a: Hobbyist Tech
i would try first by checking the resistors linked to the shottky diode,it seems to me that one is gone higher value,thus pushing more current to the shottky ,you will need the schematic,for resistor type and value,also check for any reverse voltage,this will cause the shottky to blow,as it seems this monitor stays ok for a day or so,then pops,suggesting a small voltage that is creeping up and biting the diode on the ass,also if all checks out ok,then consider a higher amp diode that maybe will take more current,as sounds as if it could be a design issue with that power board with current boardering on the amperage of the diode,you can go higher on the amps for the diode,just the same as you can step up the voltage for a cap(higher not lower dont forget!),also double check on the main fuse it should read 1 on a dmm,if higher this will sugest a short somewhere.
#7 |
On my level
^^ Off topic. Totally.
The diode is 30A. The monitor draws 4A at 14v, if not lower. The high current rating is so that voltage drop can be kept low and they get away with a smaller heatsink. There are no resistors linked to the diode because it wouldn't make any sense, and the power supply only pushes as much current thru the diode as the controller tells it to. And if the controller tells it so it means the monitor needs that current. Your only pertinent observation is related to the diode reverse voltage. And that indeed could be the cause. |
#8 |
City & State: st.louis mo
An observation and a question.
The monitor apparently ran a year without problems, and now after running and getting totally warm the diode fails. Is there a possibility it could be as simple as re-soldering a transformer?
#9 |
thanks for the input guys
will have another go at it. |
#10 |
unfortunately it hasn't been possible to fix - it runs fine uncovered, but replace the casing and it heats up and blows again.
I've come to the conclusion that the only way to fix it will be to replace the whole power supply, but I just can't find anywhere that sells them. Any ideas where I could try? |
#11 | |
Hi bro...i have the same problem with you http://item.taobao.com/item.htm?id=6930940343 its from china i think..by the way becareful shopping..try find trusted middle men to handle the shopping for you since its chinese website hope u can fix ur 3008 wfp...i waiting for mine technician to fix mine. i did follow ur thread @ dell support page seems they are helpless! |
#12 | |
#13 | |
City & State: Seattle WA
Hopefully this one won't burn out after a couple of days. I'll let you know how it goes. Thanks for the suggestion. |
#14 | |
#15 |
On my level
Thanks for the report! We're always happy to hear success stories.
#16 |
My monitor as well just died the power supply is the issue, the problem is dell will not give them what they need to try and fix it. Any chance you would be ok if i share this information with them to try, and fix my issue. After this experience i am not sure i will buy from dell anymore.
#17 |
#18 |
City & State: Yeovil, Somerset
My Country: U.K.
Hi Guys. I'm new to this board having just found it, after having just had my Dell 3008 monitor fail 3 months outside it's 3 year warranty
I'm pretty certain my PSU has the same problem described here, and I've already bought some much higher rated diodes (STPS40170CT) to fix it. No-one's posted an image showing the D22 diode location (it isn't marked on my board), so I'm posting an attached image of where MY faulty diode is located and wonder if someone could confirm that this is the infamous D22 on the 14V rail? I also thought it would help others to know where to look after they'd managed to open up the Dell monitor (now that was one hell of a difficult job. How on earth do Dell repair them - maybe they just scrap and replace in-warranty items?). If anyone can confirm I'm looking at the right device then it would help enormously before I start dismantling the heatsinks to get at the failed device (which isn't all that easy even for an experienced elec. eng.). I have visually confirmed that the faulty device marked in my photo is a 30120S. Thx. Last edited by Jetset; 03-14-2012 at 08:37 PM.. Reason: Added info. |
#19 |
Is there a marking on the front side of the pcb for the red circled component?
#20 |
My Country: U.K.
Ahhh...Yes, I can just about read the silk screen using a bench magnifier. The component is definitely D22!
One other question if I may: Do you know if this diode blowing is likely go have damaged anything further down the 14V line (I can't see any fuse or fusible link that would normally be present in a SMPS to protect against such failure, and I'm using the old mains plug from the UPS to power the new 3011, so nothing has blown externally)? Thanks for your response. Colin |
| Thread Tools | |
| Display Modes | |
