Testing VRMs
    master hoarder
    • May 2008
    • 12175
    #81
    Re: Testing VRMs
    Originally posted by bianchi77
    I removed CPU resistance to ground = 34.5 ohm...do you mean northbridge sharing the same Vcore ?
    Yes. *Possibly*
    Is this for the A7S333 motherboard from your other thread? Or a different motherboard?
    When I tried to measure one of the chip capacitor with my LCR45....I got value >20000uF
    That's because of the low resistance of the circuit. It will make your meter think it is filling up a big cap.
    That's why it's never reliable to measure anything in circuit, especially if you don't understand the circuit well.
    One test that I can do...is, unsolder all the capacitors about 16 small smd capacitors and test the resistance again....
    Yes, do that.
    This is by far the best way to isolate a short-circuit: keep removing parts until the short-circuit is gone. Unfortunately, this is also the hardest way. But the reward is the certainty you get.
    • bianchi77
      • Jun 2016
      • 1121
      Re: Testing VRMs
      Any thick traces going from CPU V_core to Northbridge? If yes, that means the NB is powered by CPU V_core as well, and that's what would be giving you the still-fairly-low resistance of 34.6 Ohms.
      I didn't see any thick traces going from CPU V_core to NB....
      I saw northbridge has its own FET....
      so CPU is using V_core itself....
        Re: Testing VRMs
        One info that is still missing is the Output Voltage reading from the power supply. i myself never seen the Vcore pin of the CPU with that <10 Ohms.
        I was going to tell him to get something like 100uF cap in parallel with 100 Ohms resistor and have him test the capacitance to see what reading he will get to proof that reading cap in the circuit is never be reliable, but some people still insist on doing that.
          Re: Testing VRMs
          BTW, without the real diagram that matches the board you are working on then you really do not know what point 'A' is really connected to.
          • bianchi77
            • Jun 2016
            • 1121
            Re: Testing VRMs
            Where can we find Asus A7S333 motherboard schematic ? In there, we can see where are those capacitors located,
            My thinking, they are V_core filter capacitor in each Vcc pins on CPU....
            • bianchi77
              • Jun 2016
              • 1121
              Re: Testing VRMs
              I got this one :
              https://cdn.badcaps-static.com/pdfs/...3a1aafd023.pdf
                master hoarder
                • May 2008
                • 12175
                #87
                Re: Testing VRMs
                It's usually not that complicated for a *desktop* PC motherboard.
                Typically the CPU VRM powers the... CPU (surprise, surprise ) and occasionally the NB on a few motherboards. The fact that bianchi77 got a low-resistance after removing the CPU strongly suggests that the NB is powered from the CPU VRM as well. I'm not saying that it can't be shorted ceramic capacitors, but it seems unlikely to me in this case, since the motherboard does turn ON for a few seconds. If any shorted ceramic capacitor was to take that much energy from the CPU VRM for a few seconds, it would have burned for sure.
                Yes, the NB does have its own MOSFET, but your motherboard doesn't have a separate SB, so that means the NB and SB are both in one chip... hence you could have 2 or even 3 different voltage rails going to that chip.
                On a typical motherboard with separate NB and SB, the SB usually has two rails: a stand-by rail (usually 3.3V or less) and an active-ON rail that comes ON only when the motherboard is turned ON (and it's usually 1.2-2.5V, depending on motherboard's vintage).
                • cind12
                  GTX 1080 TI Gigabyte Aorus low resistance on vmem
                  by cind12
                  Hi guys, i was wondering, i've got 9Ohms on Vmem, one of the mosfet was shortet to ground, so i've desoldered hi and low mosfets nad still low res, then i removed all of the memory chips, and the resistance is still low, so did you had maybe a card with that low res on memories, and the card was working fine ?
                  Removed the U1866Q and still without result, i dont have thermal cam so can't see where is hot spot when incjeting voltage.
                  The resistance on core is ok 0.1Ohm ((Power 0.8V when on)
                  Resistance on 12V 4K ohms (Power present when on)
                  Resistance on 12V PEX 4K ohms...
                  12-08-2023, 09:09 AM
                  FNIRSI HRM-10 Internal Resistance Detector AC Lead Acid Lithium Battery Tester Review on some testing of device
                  https://www.ebay.com/itm/405035016711
                  I got this device yesterday and did some testing on some tabbing and some incandescent light bulbs and it seems to work very well from what I can tell but how do I know how accurate the m-ohms section is what can I use to verify it accurately I also tested some li-ion battery cells and this seems to be fairly accurate because I have another tester and they seem to agree with each other
                  I also checked some capacitors with it that were brand new and seem to show about what I expected to see with my blue capacitor tester so I think it...
                  04-13-2025, 08:17 PM
                • Nagy Daniel
                  Lowest possible resistance on laptop motherboard rail - Guide Table request
                  by Nagy Daniel
                  Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
                  I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
                  I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
                  So, I generated a table with AI so I can...
                  03-04-2025, 08:24 AM
                • jkucukov
                  PS3 FAT NEC/TOKIN Resistance Testing, need help interpreting values
                  by jkucukov
                  I'm in process of diagnosing the yellow light of death symptom on my PS3 FAT console CECHG01, in process of getting the Arduino gadget to be able to access Syscon and be able to read fault codes. In the meantime, I'm trying to measure resistance of the NEC/Tokins while still attached to the board. I took the Ohm readings from each of the NEC/Tokins from front and back of the board (4 from the RSX and 4 from the CPU chips).
                  What I gathered in the attached pictures are values from the CPU NEC/Tokins are consistently measuring 1.6 Ohms while on the RSX they measure 3.4 Ohms except for...
                  10-03-2025, 03:20 PM
                • Jane
                  How do you test MOSFET in laptops ?
                  by Jane
                  I tried to use this method:
                  Testing an N-channel MOSFET:
                  Step 1: Discharge the Gate (turn off the MOSFET)
                  Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                  Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                  Step 2: Charge the Gate (turn on the MOSFET)
                  Now, place the red probe on the Gate (G) and the black probe on the
                  09-27-2024, 03:31 AM
