Testing VRMs
  • andlcs
    • Feb 2007
    • 22
    Re: Testing VRMs
    Originally posted by badman86
    Hi!
    It's an MSI K9A. I'd like to measure the resistance from the input and output of VRM to ground.
    I think you can measure the input at the toroid coil near the ATX+12V conector.
    And the output at the shielded inductor near the CPU socket. I'm not sure tho...
    power off your computer first
    • badman86
      • Jun 2008
      Re: Testing VRMs
      Thank you for your answers, I think i got it now!
      Now, what is not clear yet is this:
      a. Measure resistance from power supply pin (+3.3, +5, +12, -5, -12) to input of VRM. Resistance should be zero (too low to measure).
      Power supply pin means the ATX connector on the motherboard?
      • coolday
        • Jul 2008
        • 12
        Re: Testing VRMs
        Admins and moderators please try to start a section on motherboard repairing. it would be very helpful for newbies like us. Maybe this would be the first website to do so.
        • coolday
          • Jul 2008
          • 12
          Re: Testing VRMs
          so anyone can provide pictures .... it would help us a lot
          • closetonanak
            Re: Testing VRMs
            First You Should Know Where Is Vrm Section On Board And How It Works, Which One Is Positive Line And Negative Line Then Mosfets Of P And N Lines, Check The Voltages, If No Voltages Means May B Mfets Are Open Thn Take Them Out From There Place And Check Also Check On Pads If Still There Shorting Means May Be Another Mosd\fet Has To Take Out From Board And Chk It Like That Go Ahead If U C That Capacitor Is Leak So Fst U Hav To Repalce, And In Ths Case Pwm Ic Of Both Line ( +, _ ) Have To Replace And Chk, Buck Control Ic( For Power Good Signal) , Io All Thing Should Be In Lone To Replace
            • sam67
              • 256
              #26
              Re: Testing VRMs
              Would also like some pics if anyone has any or links ..This is really interesting and should be further explored ..
              • alexanderjohn
                • Dec 2007
                #27
                Re: Testing VRMs
                yes! especially laptop motherboards
                • Pyr0Beast
                  • Feb 2009
                  • 406
                  #28
                  Re: Testing VRMs
                  Laptop motherboards ... hmm.... if I have the time ...
                  //c. Measure voltage at the input to the VRM (+3.3, +5, +12, -5, -12). Anything less than the value obtained in step 6.b indicates a high resistance in the PC board traces to the VRM, and is probably not repairable, even with a schematic.//
                  Is repairable, by making a bridge with a wire. Usually from one capacitor to the next one. Never occurred to me unless it is a manufacturer design.
                  Basically, it is pretty simple. If mainboard does not POST, check voltages.
                  If PSU voltages are within range, check voltages on motherboard. Cpu has pretty much standard voltage. About 1.4V is fine for newer CPUs, 1.8V for athlons and P3's, 2V or greater for first celerons and P2 (Some early P3)
                  If there is no power (voltage) to the CPU, check if you placed capacitors the right way, observing the polarity. Same goes for other circuits, RAM, AGP etc. ..
                  If VRM IC is busted, it would be hard to find a new one. Sometimes (rarely) only one of the mosfets break, usually the upper one. When it does that, the lower one migh go 'poof' as well (protecting the CPU).
                  If one breaks, replace both. Check IC for damage, might be good to replace that one as well, sometimes it is the cause of this mess.
                  //VRMs (voltage regulator modules) are a specific class of MOSFETs; //
                  Far from being true. A VRM module consists of the controlling IC and MosFet's (if we focus only on semiconductors).
                  However, it is true that there are many type of FET's. Mosfet being the most common one. JFET is one of the other type.
                  • ivanlee05
                    TipidPC.com
                    • Nov 2009
                    • 6
                    #29
                    Re: Testing VRMs
                    Source = Input
                    Drain = Ground
                    Gate = Output
                    • Pyr0Beast
                      • Feb 2009
                      • 406
                      #30
                      Re: Testing VRMs
                      Source = Output
                      Drain = Input
                      Gate = Gate
                      Current flows from the Drain to the Source afaik. (When the gate is (ON))
                      Can also flow backwards once the gate is on, however, the body diode will conduct when the gate goes off, leading to rapid heating.
                      • ivanlee05
                        TipidPC.com
                        • Nov 2009
                        • 6
                        #31
                        Re: Testing VRMs
                        Originally posted by Pyr0Beast
                        Source = Output
                        Drain = Input
                        Gate = Gate
                        thanks sir for the explanation sir... i have a motherboard with no power here, i already check every parts like processor, memory and psu, they are good.. i'm suspecting dead vrm...
                        • Pyr0Beast
                          • Feb 2009
                          • 406
                          #32
                          Re: Testing VRMs
                          Check the output voltage then.
                          (With the component in place of course)
                          • ivanlee05
                            TipidPC.com
                            • Nov 2009
                            • 6
                            #33
                            Re: Testing VRMs
                            I am having problem with my neighbor's PC... His motherboard (Biostar GF7050V-M7 SE) could not boot... It has a power but theres no display or even beeps... I already check all of the VRM mounted in the Motherboard, all does have output voltage that range more or less what the input voltage is...
                            My first tought was a Failed BIOS updates... But He doesn't even know how identify a computer parts... I still had to recover the BIOS thru AMIBOOT.rom BootBlock Recovery... No, the problem is not the BIOS...
                            Other components like ram, psu, hdd, odd and the processor has been verified in my PC except for the video card... He doesn't have any, He uses the Onboard Video...
                            Thanks for those who will reply...
                            • ivanlee05
                              TipidPC.com
                              • Nov 2009
                              • 6
                              #34
                              Re: Testing VRMs
                              I think this is a chipset problem that I could not repair anymore... I went to test all the electrolytic capacitor, and all does have more or less same voltage as input voltage...
                              I have no time to check all the surfaced mount resistors, diode and capacitors... I'll just force him to buy another Motherboard...
                              His motherboard served him well for almost 3years...
                              R.I.P. Biostar "RedFox" GF7050V-M7 SE
                              Bought: 09/10/07
                              Died: 01/29/10
                              ^_ _^
                              • Pyr0Beast
                                • Feb 2009
                                • 406
                                #35
                                Re: Testing VRMs
                                Replace the board. Simplest and effective.
                                • Zero Hour
                                  Getting there
                                  • Oct 2009
                                  • 35
                                  #36
                                  Re: Testing VRMs
                                  I suggest sir as a last ditch effort before retiring it completely if it's not too late, baking the board. I have the problem as a common issue with geforce 6100/6150 chipsets. It's the closest I can get easily to a 'bga reflow' since I don't have a heat gun or a torch or patience. I know it's not a 'convenitonal' method, but for a board you've attempted everything else on and are set on pitching it, it can't hurt.
                                  My method, strip the board of any heatsinks and battery and cmos chips if possible, remove all thermal paste and thermal pads, preheat oven to 384F, elevate the motherboard off of a pan (i ball up aluminum foil and leave a little pointy end for 4 mounting holes to support the board) and bake for 5 minutes. I don't suggest pushing past 6 minutes, it's never been beneficial in my cases and stinks like hell >.< But so long as you can vent the house afterward hey it's fun :P
                                  Or if nothing else, I'd pay shipping on the board if you don't wanna go through the trouble of baking it
                                  • cmosbios
                                    • 12
                                    #37
                                    Re: Testing VRMs
                                    well you can use hot air rework station for reflow.
                                    • cmosbios
                                      • 12
                                      #38
                                      Re: Testing VRMs
                                      @Akor
                                      you mean if I test the VRM, test each mosfet(VR) inputs and outputs? I am not sure if you are referring to VRM block (2 mosfets, ic driver, pwm) input and output circuit tests. what i know about the VRM is NOT the mosfet itself but the circuit. please enlighten me.
                                      • styxbound
                                        • Aug 2010
                                        • 91
                                        #39
                                        Re: Testing VRMs
                                        Sorry, I'm old and senile. Can anyone simplify for me how to find the inputs and outputs on vrms? There seem to be any number of fets around the cpu on a lot of boards, and I can't figure out where the in and out is on the circuit.
                                        • Pyr0Beast
                                          • Feb 2009
                                          • 406
                                          #40
                                          Re: Testing VRMs
                                          Ouput is past the choke on output capacitors
                                          Input on input capacitors
                                          • cind12
                                            GTX 1080 TI Gigabyte Aorus low resistance on vmem
                                            by cind12
                                            Hi guys, i was wondering, i've got 9Ohms on Vmem, one of the mosfet was shortet to ground, so i've desoldered hi and low mosfets nad still low res, then i removed all of the memory chips, and the resistance is still low, so did you had maybe a card with that low res on memories, and the card was working fine ?
                                            Removed the U1866Q and still without result, i dont have thermal cam so can't see where is hot spot when incjeting voltage.
                                            The resistance on core is ok 0.1Ohm ((Power 0.8V when on)
                                            Resistance on 12V 4K ohms (Power present when on)
                                            Resistance on 12V PEX 4K ohms...
                                            12-08-2023, 09:09 AM
                                            FNIRSI HRM-10 Internal Resistance Detector AC Lead Acid Lithium Battery Tester Review on some testing of device
                                            https://www.ebay.com/itm/405035016711
                                            I got this device yesterday and did some testing on some tabbing and some incandescent light bulbs and it seems to work very well from what I can tell but how do I know how accurate the m-ohms section is what can I use to verify it accurately I also tested some li-ion battery cells and this seems to be fairly accurate because I have another tester and they seem to agree with each other
                                            I also checked some capacitors with it that were brand new and seem to show about what I expected to see with my blue capacitor tester so I think it...
                                            04-13-2025, 08:17 PM
                                          • Nagy Daniel
                                            Lowest possible resistance on laptop motherboard rail - Guide Table request
                                            by Nagy Daniel
                                            Hi, I'm Daniel, and I'm new to the world of repairing motherboards.
                                            I would like to create a table, or more likely a guideline about the voltage rails and their possible resistance rail.
                                            I know that the motherboard design has a very big depend on the rail's resistance, but I would like to know what is the smallest value for a rail that can be acceptable. For example, I heard that some new gaming motherboards can have 0,5 Ohm resistance on the GPU rail, but on an older type, it could be a sign of a shorted GPU rail.
                                            So, I generated a table with AI so I can...
                                            03-04-2025, 08:24 AM
                                          • jkucukov
                                            PS3 FAT NEC/TOKIN Resistance Testing, need help interpreting values
                                            by jkucukov
                                            I'm in process of diagnosing the yellow light of death symptom on my PS3 FAT console CECHG01, in process of getting the Arduino gadget to be able to access Syscon and be able to read fault codes. In the meantime, I'm trying to measure resistance of the NEC/Tokins while still attached to the board. I took the Ohm readings from each of the NEC/Tokins from front and back of the board (4 from the RSX and 4 from the CPU chips).
                                            What I gathered in the attached pictures are values from the CPU NEC/Tokins are consistently measuring 1.6 Ohms while on the RSX they measure 3.4 Ohms except for...
                                            10-03-2025, 03:20 PM
                                          • Jane
                                            How do you test MOSFET in laptops ?
                                            by Jane
                                            I tried to use this method:
                                            Testing an N-channel MOSFET:
                                            Step 1: Discharge the Gate (turn off the MOSFET)
                                            Place the black probe (COM) on the Source (S) and the red probe on the Drain (D). The multimeter should show no continuity (high resistance or "OL" – open line).
                                            Then, touch the black probe to the Source (S) and the red probe to the Gate (G). This discharges any stored charge in the Gate, turning the MOSFET off.
                                            Step 2: Charge the Gate (turn on the MOSFET)
                                            Now, place the red probe on the Gate (G) and the black probe on the
                                            09-27-2024, 03:31 AM
