Very ugly capacitors... or fake? (Panasonic FR)
  • Uranium-235
    Comrade Glimmer
    • Aug 2007
    • 5042
    • US
    #41
    Re: Very ugly capacitors... or fake? (Panasonic FR)
    really? I would figure there would be a greater difference between lytics and polys
    • PCBONEZ
      Grumpy Old Fart
      • Aug 2005
      • 10661
      Not sure what you are commenting on.
      Greater difference in what respect?
      Mann-Made Global Warming.
      - Dr Seuss
      • Rulycat
        • Apr 2010
        • 724
        • United Kingdom
        #43
        Originally posted by PCBONEZ
        CH and TW brands will still be around.
        I don't see Suncon dropping out soon. [Formerly aka Sanyo.]
        Panny and Nichicon aren't droppong out afaik.
        So in 10 years time we'll all be recapping with Teapo?
        • goodpsusearch
          • Oct 2009
          • 2850
          • Greece
          #44
          I have done it already at some power supplies
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            Actually there's another good brand w/Low ESR caps but I've never seen them for sale.
            Illinois Capacitor...
            Their JZM series has ESR/Ripple in between MBZ and MCZ.
            Their KXM series has ESR/Ripple comparible to ZL, WX, KZE
            They have two series with specs down around the LXY, LZY range too,,,
            ,,, those are KBM and RZM.
            It's possible they are ugly like FR too! Woo Hoo!
            Their data sheets are a PITA to read because they don't sort the list by voltage..
            - Dr Seuss
            • mockingbird
              • Dec 2008
              • 5484
              #46
              PCBONEZ - you have a tendency to discover treasure often...
              I actually emailed NIC Components' Montreal Office to try and source their low ESR stuff, I didn't get an aswer (Typical lazy Frenchmen). I should try to get in touch with Illinois, to see if I can get my hands on their old stock of these series, if they have any that is. (I have a feeling that they probably only did very short production runs of these series).
              • PCBONEZ
                Grumpy Old Fart
                • Aug 2005
                • 10661
                Those are current series, I just never see anyone stocking them.
                With all of Japan's problems IC might end up with a bigger chunk of the market and these caps just might start showing up in places.
                - Dr Seuss
                • PCBONEZ
                  Grumpy Old Fart
                  • Aug 2005
                  • 10661
                  The factory sales reps [I think] get paid in part on commission so if you aren't placing a large order [or just get lucky and ping one having a slow day] they will just point you to some other company that buys from them in bulk.
                  I hadn't thought about buying old stock direct though.
                  If they don't have some arrangement with a liquidator that might work.
                  - Dr Seuss
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 4970
                    • New Zealand
                    #49
                    I purchased some of those Illinois Capacitors from Farnell once, not Low ESR though.
                    -David VanHorn
                    • PCBONEZ
                      Grumpy Old Fart
                      • Aug 2005
                      • 10661
                      The series I mentioned are low ESR.
                      IC makes good caps, just not many of the low ESR types.
                      IC caps often show up in better brands of test equipment. [BK, Fluke]
                      - Dr Seuss
                      • Agent24
                        I see dead caps
                        • Oct 2007
                        • 4970
                        • New Zealand
                        #51
                        Yeah I know, I just meant that I bought the general purpose ones, I wasn't looking for Low ESR at the time.
                        But if Fluke uses them, then I am happy I bought them
                        -David VanHorn
                        • PCBONEZ
                          Grumpy Old Fart
                          • Aug 2005
                          • 10661
                          LZY is a typo, meant LXZ.
                          - Dr Seuss
                          • Ssound
                            • Jan 2011
                            • 5
                            #53
                            Old thread but just wanted to comment on something. First, the IC capacitors are an old brand, they were used a lot in the 70s, AFAIK they got re-issued or they gave them a major bump back into commercial business. They are good and cheap capacitors, im into audio and these caps were used a lot in audio.
                            Most of you guys are thinking that electrolytics will be extinct because you are only looking at them from the computer motherboard perspective, there are a lot of different industries which require electrloytics, for instance, pro audio.
                            Pro-audio, specially pro-audio enthusiasts like vintage gear, etc.. Audio is NOT the same without electrolytics, sure, polypropilene caps, or polyester film caps may sound better in some cases, (havent really tried polymer in audio) but in audio is not uncommon to see stuff like 1000uf or 2200uf at 63V low impedance cap, aand i have yet to see a polymer that big.
                            So in short, dont worry, Low-esr capacitors will still be around...
                              by sam_sam_sam
                              After all of...
                              07-13-2024, 08:14 PM
                            • Olkus
                              Elna capacitors - fake?
                              by Olkus
                              I have capacitors like this one in the photo. There are differences between other Elna series, I attach foto of Elna RE3. On this green capacitors series is not specified! Fake?...
                              09-01-2023, 02:45 AM
                            • dragon3x
                              After updating motherboard capacitors, what to do next (Asrock K7VT2, SOLTEK SL-75FRN2L)
                              by dragon3x
                              Hi, I have some 32 bits computer motherboards that need repair, as they fail to
                              power on.
                              Here are some examples :
                              (N.B. "capacitors" indicated here are electrolytic capacitors located in the onboard
                              switching supply area).
                              (N.B. #2 : I could not find a 3300 microF aluminum-polymer with a higher voltage
                              than 6.3 V.)
                              1 - Motherboard #1 : this is an Asrock K7VT2 (socket A) that still works well. To put it on test
                              I replaced capacitors with aluminum-polymer.
                              3300 microF/6.3 V. x 4 replaced by 3300 microF/6.3 V. (KYOCERA...
                              03-21-2025, 02:46 PM
                            • Andre Gilbert
                              by Andre Gilbert
                              Hello! yes I know there is already lots of information about this issue. I have a Panasonic TC-P55ST50 that originally displayed an 8-blink error code. Following the troubleshooting flowchart, I ended up replacing the SS board. However, even after replacing it, the issue persists. The TV turns on and stays on without displaying an image, and continuity is confirmed on all connectors. What am I missing here🤔?
                              Ok Im a mechanical engineer ...but I thought I was able to follow a rather simple flowchart for electric troubleshooting 😂.
                              11-20-2024, 08:52 PM
                            • slybunda
                              AA and AAA battery charger capacitors?
                              by slybunda
                              hey all, iv got my favourite battery charger here which iv had for many years probably 15 years now or maybe even more. it still works good but thought id open it up to clean the dust out of it, lots of dust inside but now its clean and noticed 4 capacitors inside it and wondered if i should replace them.
                              it has inside:
                              2 x 47uf 16v caps 105c branded as Su'scon (lol sounds sus to me)
                              2 x 470uf 16v LZ105c branded as G.Luxon
                              not heard of these brands are they any good?
                              iv attached photos of the charger and the board inside for an idea on the type of...
                              12-24-2023, 04:41 AM
