Sony XBR-65X930D No screen
  • yankys
    yanky
    • Feb 2012
    • 139
    HI, everyone I want to say thanks for the help on the samsung. now it's my sons Sony XBR-65x930D I am trying to fix I've replaced the dps and main board did the firmware update, now I have the white light on bottom of the tv and it seem to turn on and off but no picture not sure how to precede could some possibly point me in the right direction.
  • nomoresonys
    • 12331
    • U.S.
    Re: Sony XBR-65X930D No screen
    while powered up, see if theres about 12 volts on each side of the tcon fuse, neg. probe on chassis ground, pos. probe on each side of fuse.
    • yankys
      yanky
      • Feb 2012
      • 139
      I will check this as soon as I get back to the house and post my findings thank you.
      • yankys
        yanky
        • Feb 2012
        • 139
        @ fp1 fuse it only shows 0.6mv on both ends of the fuse.
        • nomoresonys
          • 12331
          • U.S.
          ok, and fuse tests ok, it shows continuity?
          • yankys
            yanky
            • Feb 2012
            • 139
            Yes fuse show continuity
            • Diah
              • Feb 2013
              • 6599
              micom didnt send signal to power boards to turn on T-CON 12V.
              as you replaced Main boards and did firmware update.. and now it turn on and off.. so need to do reset..
              while its on / white LED on ) plug it out from wall socket... press the middle joystick and pull it down... keep it at this position while you plug it in wall socket again... untill you have the while led turn to green keep press 3 second then release your finger.... leave it it could restart 2 time.
              • yankys
                yanky
                • Feb 2012
                • 139
                This maybe a dumb question what do you mean by middle joy stick?
                • Diah
                  • Feb 2013
                  • 6599
                  you don't have at the back side of the TV Joystick for controlling !!!!!
                  • yankys
                    yanky
                    • Feb 2012
                    • 139
                    There button on side power/volume/channels
                    • Diah
                      • Feb 2013
                      • 6599
                      its android right!!!. so use power and volume -
                      • yankys
                        yanky
                        • Feb 2012
                        • 139
                        I’ll do this and post the what happens Thank you
                        • yankys
                          yanky
                          • Feb 2012
                          • 139
                          Had white light unplugged tv while on did the power volume - and it turned green let buttons go it went off came back on amber green went off came back to amber green and that is we're it staying.
                          • nomoresonys
                            • 12331
                            • U.S.
                            maybe a dead emmc chip.
                            • yankys
                              yanky
                              • Feb 2012
                              • 139
                              Is this one of the ic chips on the main board?
                              • Diah
                                • Feb 2013
                                • 6599
                                it tell only one story..
                                the update you did after you replaced the main boards was not successful. or wrong file.
                                you need to ready USB stick with correct firmware.. and try again the reset while the usb inserted at the TV.
                                • nomoresonys
                                  • 12331
                                  • U.S.
                                  Yes, if it will not update after all proper attempts and trying different usb drives because sonys can be fussy, then emmc is my guess.
                                  • yankys
                                    yanky
                                    • Feb 2012
                                    • 139
                                    Thank you for the reply's I have tried all kinds of ways to get this tv to turn on, but same results and I have three mainboards, and they all act the same could it possibly be the t-con board or something else causing this issue?
                                    • nomoresonys
                                      • 12331
                                      • U.S.
                                      did you try it with one ribbon cable at a time hooked up from tcon to panel driver board, see if theres anything on display or any change, don't let the end of the loose cable touch anything such as metal chassis, don't want to short anything out. Best to do all connect and disconnect of cables with tv unplugged from power to avoid any errant surges and such.
                                      • nomoresonys
                                        • 12331
                                        • U.S.
                                        so with all three mainboards you are getting no voltage on the tcon fuse?
                                        • Ryan.man
                                          by Ryan.man
                                          02-04-2025, 12:23 PM
                                        • reformatt
                                          by reformatt
                                          07-31-2025, 08:37 PM
                                        • misterhaus
                                          Sony XBR65x930D - left half screen is grainy
                                          by misterhaus
                                          Hi, this is my first post - so thanks in advance for any assistance.
                                          I have a Sony XBR 65x930D (manufactured in July-2016), which was initially showing a black screen, faint backlight glow, and played musical sounds when powered up. After some experimenting (mostly unplugging cable and re-plugging), including attempting hard-reset and firmware update, it is now showing video, but the left side of the screen is fuzzy/grainy. (See attached pic)
                                          I am trying to decide if this could be the T-CON board, or the DPS board.
                                          When I press on the upper right of the DPS...
                                          03-16-2020, 04:33 PM
                                        • Chrissygizmo
                                          Sony KD-55XG9505 lines on screen problem
                                          by Chrissygizmo
                                          Hello again everyone,
                                          This is my latest mission, to try getting this Sony tv back to normal working order…
                                          I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
                                          02-19-2025, 11:31 AM
                                        • smic717394
                                          by smic717394
                                          07-25-2024, 10:16 AM
