Sony XBR-65X930D No screen
    replied
    Re: Sony XBR-65X930D No screen
    Kool.
  • yankys
    replied
    Glad to hear it Yankys, This might just be the answer to a lot of these ones with these same symptoms, which brand flash did you use?
    The flash drive is unbranded bought a board from Tvparts and the drive came with it, when you put the firmware on it shows 359MB left with 1.87 GB used so believe its only a 2GB drive but it said dont use anything bigger than 4GB or firmware wont work, i flashed my sony with the same mian board that i could not get work previously and it took first time.
  • yankys
    replied
    I also picked up another Sony Xbr65x850c with same symptoms previous owner replace mainboard got it to take update now it’s working.
    replied
  • yankys
    replied
    HI, everyone I have good news! I have the XBR-65x930D working, you won't believe how, it seems the firmware needs no bigger than a 4g flash drive, when I put it on a 4g the firmware updated now the tv is like new no issues at all. hope this helps someone with the same issue I was having.
  • zomi
    replied
    Does it respond to the remote
    turn on and off..
    I just had this problem on one.
    it turned out to be the flat cable coming from the led driver board to the dps board wasnt inserted correctly
    might be worth a check
  • yankys
    replied
    No I'm still having the same issues couple of different mother boards and DPS Boards
  • zomi
    replied
    Any progress on this
    replied
    I bet BudM could have figured this puzzle out.
    replied
    here's my thread on a xbr-65x900c piece of crap, no history available, worked fine for 3 days then just stopped, seems to be a ton of these with the same symptoms: https://www.badcaps.net/forum/showthread.php?t=102548
    replied
    I think these xbr-x900 series are some of the worst lemons sony has come out with, there has to be a common fault on these but I have not been able to figure it out, symptom always seems to be the same, andriod music, no picture no backlight, very low voltage at the tcon fuse, like 1 volt or less. Sometimes there is backlight but no picture and usually the amber/green blinking and doesn't seem to take an update no matter how you try it.
  • zomi
    replied
    Check the led driver board as advised by davi.p
    you should have 12v going from the led board to the tcon.
    if you don't you have some issue there ..
  • zomi
    replied
    On the red side you have 24v
    on the blue side 3v with a good dps.
    I disconnected the dps cables to the tcon and set will then flash red green
    but on the tcon you should still have 12v.
  • zomi
    replied
    been working on a couple of these myself this weekend.
    If it turns on, your dps is fine
    the cables that go from the dps to the tcon
    examine them check for any damage they are easy to damage.
    also on these if you power up without the tcon conencted up u end up with amber green lights flashing..
    when that happens just let it power on then connect usb and leave it for hour or so ..
    it mostly updates fine..
    some times if it on blinking white connect the usb then it starts the update..
    some time it takes longer..
    when update dated it should respond to the remote.. power on and off etc..
    also try menu commands to see if you have sound.
    v unlikely u have 3 dead boards..
    replied
    admittedly hard to decipher this, much harder with no obvious voltage legend on the dps board, I might be tempted to throw another dps board at it if they are reasonably priced. I wish I would have tried that before I fried my mainboard with overheating, might want to fully test the dps board first, I don't have enough dealing with them to know much about them but I bet some of these guys do.
  • yankys
    replied
  • yankys
    replied
    I rechecked the DPS volts and picture is the finding on each pin not sure if the voltage is correct and all there. Number 4 is 0
  • Davi.p
    replied
    On the led driver board (it does not only that) there are 2 coils in series, grey big square, i've read a problem in those coils in another thread, check their resistances
  • yankys
    replied
    I will re-check those voltages when I get home and post my results thank you for all your help.
    replied
    check second link down, post #29, see if that dps board is sending proper voltage to the mainboard if you have not.
  • Ryan.man
    by Ryan.man
    02-04-2025, 12:23 PM
  • reformatt
    by reformatt
    07-31-2025, 08:37 PM
  • misterhaus
    Sony XBR65x930D - left half screen is grainy
    by misterhaus
    Hi, this is my first post - so thanks in advance for any assistance.
    I have a Sony XBR 65x930D (manufactured in July-2016), which was initially showing a black screen, faint backlight glow, and played musical sounds when powered up. After some experimenting (mostly unplugging cable and re-plugging), including attempting hard-reset and firmware update, it is now showing video, but the left side of the screen is fuzzy/grainy. (See attached pic)
    I am trying to decide if this could be the T-CON board, or the DPS board.
    When I press on the upper right of the DPS...
    03-16-2020, 04:33 PM
  • Chrissygizmo
    Sony KD-55XG9505 lines on screen problem
    by Chrissygizmo
    Hello again everyone,
    This is my latest mission, to try getting this Sony tv back to normal working order…
    I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
    02-19-2025, 11:31 AM
  • smic717394
    by smic717394
    07-25-2024, 10:16 AM
