Philips BDP5180/12 Blue-Ray "logo" in image. blocked
  • digitel
    • Apr 2013
    • 8
    • Alicante
    hi
    The device is connected via HDMI to a TV. It turns on with the power key and the "Logo" appears in the image; but the device does not respond to any order from the control and/or keyboard.
    Does not open tray.
    Not even the front display lights up.
    Voltages in the connector from the source to the main are correct, according to serigraphy.
    Voltage from the connector to the front display, they are fine.
    Display filament powered.
    BGA memory ICs have a temperature between 36 and 39 degrees Celsius.
    I have not tried to update software via USB.
    I think of a possible boot failure in the BIOS... Has anyone had this problem; any opinion, please...?
    Thank you
    • 12156
    • U.S.
    Re: Philips BDP5180/12 Blue-Ray "logo" in image. blocked
    I will assume that you have not seen this unit working correctly, will also assume you tried all the usual, different cable, another disc, one of the other hdmi on tv.
      • 12156
      • U.S.
      could be needs an update, look here, note you can see the step by step procedure by clicking installation instructions, note--you can change from greece to espana there at upper right: https://www.p4c.philips.com/cgi-bin/...scy=GR&slg=ENG
      • digitel
        • Apr 2013
        • 8
        • Alicante
        Obviously, it is tested with another HDMI cable. And also the RCA output gives the same problem
        • digitel
          • Apr 2013
          • 8
          • Alicante
          As I mentioned, it did not update via USB.
          We will try; but I doubt very much that if the boot does not detect the USB
          Thanks for your opinion
            • 12156
            • U.S.
            NO, what you mentioned was "I have not tried to update software via USB" if you can not even comprehend what YOU write then you are not going to get too far.
            • digitel
              • Apr 2013
              • 8
              • Alicante
              Yes friend; I still know what I write.
                • 12156
                • U.S.
                QUOTE post #1: "I have not tried to update software via USB" AND QUOTE post #5: "As I mentioned, it did not update via USB"
                • G33RT
                  Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                  by G33RT
                  Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                  It does power up when pressing the power button.
                  I already try the power button while plugin the plug with no result.
                  Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                  Could this be an PSU or eMMC issue ?
                  07-19-2025, 03:43 AM
                • tuner2000i
                  Philips 65PUS8518/12 distorted image after main board replacement
                  by tuner2000i
                  hello everyone,
                  I don't normally do tv repairs but this is a case with my personal TV which got fried together with many other electronics in my house after a thunderstorm.
                  The TV is a Philips 65PUS8518/12 which had no power. I measured and concluded that the main board was probably fried through ethernet or hdmi. I found a board with same number 715GD328-M0F-B00-005Y (I had G) but from a 55PUS8518. The TV starts but the image is doubled, distorted. I need to set the panel code which is 016 according to the sticker on the back but I can not seem to do it.
                  07-15-2025, 01:15 PM
                • malekservis
                  Philips 58PUS8536/12 Backlight ok, no image
                  by malekservis
                  the TV turns on fine, seems to be working, but shows no image outside of a thick white vertical line as it turns on that also disappears almost instantly, and then it's just backlight. I've tried unplugging either side, but still can't get an image. I suspect it's a panel issue, but thought i'd ask some smarter people to confirm. I haven't found any weird readings, but then again i'm just randomly poking around with a multimeter.
                  Any information would be appreciated....
                  08-07-2024, 07:48 AM
                  HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                  This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                  09-12-2024, 02:20 PM
                • Kartowl
                  philips 47pfl6158k/12 image faded away, sound still coming from TV
                  by Kartowl
                  Hi, my TV image started showing those lines and the image faded away, but sound is still coming from it, what could be the cause and is it fixable? I thought it could be the tcon board but I red on the internet that it could be a failing panel
                  04-23-2024, 12:57 AM
