M&B KB-432706F LED tv
  • 6BW6
    • Jan 2015
    • 55
    Anyone come across one of these brands that uses a Vestel 17IPS12 power supply?
    After main board info or firmware update. 'No stations found' after a tuning search, I suspect the front end is 'kaputt', thanks, Dave.
  • alltvrepairs
    Vestel 17IPS12 using IC U101 BM1Q001 BM1Q001FJ pdf
    by alltvrepairs
    Hi
    Am after a schematif for 17IPS12 that uses the BM1Q001FJ-E2. I have pdf for the V3 version that uses FAN6300 but circuit is not the same.
    Any help appreciated!...
    02-01-2024, 07:46 AM
  • learnmore
    Recommended BGA Rework Stations
    by learnmore
    Hello Community,
    Based on your experiences and knowledge, which BGA Rework stations would you recommend for general use for an enthusiast at the low-mid-to-high price range? Based on what I've seen, £6000 may be considered high. I particularly like those with adjustable focus, built-in suction and ball alignment features, but I appreciate that they may be on the high end.
    Also any thoughts on the PUHUI T-862++ IR Rework Station, LY GXX models, WDS-XXX models?
    01-22-2024, 04:53 AM
  • An-klamm
    Vestel 17IPS12
    by An-klamm
    Hello!
    I am in despair with a Vestel 17IPS12 power supply.
    With the TV, the backlight just stays off.
    ( Backlight tested with backlight tester = IO)
    12V on the secondary side are there and constant. Voltage of the backlight is when switching on once briefly at about 60-70V and then drops slowly. (up to about 36V I have observed it whether it then drops further I do not know).
    But I am sure that the problem is on the primary side, because the DC high voltage is only at 295V. I expected about 330V (with an input of 230V 50Hz).
    I checked the mosfet in the component...
    10-18-2023, 01:13 AM
  • jason123
    Sony STR-DN1050 - No video, no BT, No WIFI, and FM is not changing stations
    by jason123
    Hello folks,
    New to Audio equipment - I got this receiver, I connected speakers and I tried to connect to Bluetooth. My phone would not see the receiver (Receiver flashes the BT as if it's trying to pair). Then I put it on FM radio, I get white noise on the speakers. I click the +/- Tuner button, and it moves from saved station 1 through 28, but the frequency is 87.x MHz not changing. At this point, thinking I may need to do a FW upgrade, I connected an HDMI cable to the TV and TV reports "No Signal" - TV "Kind of" sees the receiver (When connected to greyed out port,...
    05-27-2025, 07:26 AM
  • SolomonMan
    HP Docking Stations Power Supplies...?
    by SolomonMan
    All,
    I recently purchased for a colleague and myself two used HP Docking Stations. They are for home use and are exact model as the ones we use at work for our laptops. We are both Software Developers.
    Anyways these docks are HP Model 5TW10UT#ABA.
    Unfortunately they did not come with there Power supplies (PSU) and I got them reasonable from eBay.
    I purchased 2 new from Amazon After Market Power Supplies(PSU). Same Voltage and Same Amperage and in fact it mentions on the Amazon page they are supported for these docks as well.
    h...
    05-09-2023, 08:04 AM
