Sharp 50bj2ke horizontal lines
  • jaco2d
    • Oct 2022
    • 7
    • scotland
    This is only my seond post and so far i am very impressed with the forums.
    I have a Sharp 50bj2ke which is 6 month out of gaurantee and has devoloped horizontal lines, i have tried to research as much as possible but i am no further is diagnosing the issue. When i turn the tv on it works good with only a thin line right at the top of the screen which i could live with but after a couple hours of use the lines start to appear in the middle of the screen and now the bottom.
    The small white box thing in the pics is not the tv its a reflection from the window
    Any suggestions to which may be causing this would be appreciated.
    • 12199
    • U.S.
    Re: Sharp 50bj2ke horizontal lines
    try turning your backlights not brightness down and see if it makes a difference in the lines.
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4333
      • Italy - Milan
      i think model is not complete. Is this plasma, lcd or oled?
        • 12199
        • U.S.
        maybe you are covered by that European 6 year guarantee, may have to deal with the place of purchase rather than the manufacturer.
        • jaco2d
          • Oct 2022
          • 7
          • scotland
          Hi sorry i should of metioned, its a Lcd, i was using a display test app to try and show the lines better, they are still there on normal broadcast and streaming
          • jaco2d
            • Oct 2022
            • 7
            • scotland
            I will have to look into that as i didnt have a clue about it. It came with a year guarantee from Sharp which i thought was a bit poor.
            • jaco2d
              • Oct 2022
              • 7
              • scotland
              Hi thanks for reply.....i turned the backlight setting right down but the lines stayed the same, they actually stood our more, I thought its maybe a heat issue as the lines only appear when the tv has been on for a few hours, i tried turning it off for 30 mins and turned it back on the lines had gone but appeared again after the tv had been on for a bit.
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4333
                • Italy - Milan
                it sounds like a common problem to the panel,.not recoverable fully, it's strange the way it appears, because a faulty line usually affect the rest of the screen.. i can't see well if the lines are precisely 1 pixel high and starts and ends from beginning/ end of the screen width..
                • diif
                  • Feb 2014
                  • 6978
                  • England
                  It's the Consumer Rights Act 2015 that covers this TV, see this thread.
                  https://www.badcaps.net/forum/showthread.php?t=110218
                  Also, Richer Sounds gives 6 years warranty as standard on their TVs.
                  • jaco2d
                    • Oct 2022
                    • 7
                    • scotland
                    Thanks for this, i have looked into it and i am currently in contact with the retailer , im just waiting to hear back from them.
                    • howardc64
                      by howardc64
                      07-24-2025, 05:17 PM
                    • Ihandyrepair
                      Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
                      by Ihandyrepair
                      Hi guys
                      I just started fixing 4k TV few months ago. so I am still learning a lot
                      I got this tv from friend complaint is ghosting or horizontal lines on image.
                      never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
                      then it started to show the ghosting white image.
                      I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
                      it has 3 thin small boards at the bottom of the...
                      12-05-2022, 04:18 PM
                    • ggil44
                      Sony XBR-65X750D Horizontal lines bottom of screen
                      by ggil44
                      Hi, I have a Sony XBR-65X750D that has horizontal lines at the bottom 6 inches of the screen. These lines appear to be every other line because the picture is still quite visible behind those lines. The lines appear all the time with a few other lines above and below the 6 inch level blinking on and off at about 2 second intervals. I'm not sure if this is a panel issue or power supply/main board problem. I did replace the T-Con board without any change in the problem. Any suggestions you might have would be greatly appreciated. Thanks,
                      05-30-2023, 07:51 PM
                    • noisykid
                      Sony XBR-85X950G Gray horizontal lines and vertical picture shift diagnosis?
                      by noisykid
                      5.5 year old 85 inch Sony Bravia X950G started showing gray horizontal lines across the bottom of the screen and the picture shifts slightly vertically when it happens. The lines sometimes get bigger/smaller vertically and bounce back. See the video for the problem. It seems to be happening after it warms up after an hour or so. Happens regardless of source. Right now there's nothing but power cable connected and it's happening. We did hook up a new Nintendo Switch to our HDMI switching receiver today, and played for a while with no issues, but this problem didn't occur til a few hours later while...
                      12-30-2024, 07:15 PM
                    • x_orange90_x
                      Samsung UN46C8000XFXZA Horizontal lines
                      by x_orange90_x
                      I just acquired this 3D LED yesterday and it has horizontal lines on a little more than half of the screen. When I first turn it on it has thin black lines going across that makes the image look serrated, and then shortly after patterns of thicker red lines fade in. If I turn it off and right back on it will reset to just the black lines and the red will again fade onto the screen.
                      I initially thought tab bonds, but flexing the bezel makes no difference, and the fact the image sort of resets after cycling power is different. I haven't opened it up yet to actually test applying...
                      07-15-2023, 05:06 AM
