Westinghouse TV WD48FAB100 Not Powering On – Burn Mark Found on Power Supply
    • 12206
    • U.S.
    Re: Westinghouse TV WD48FAB100 Not Powering On – Burn Mark Found on Power Supply
    be very careful on the hot/primary side of the board high voltage in places, the big filter cap can easily have enough voltage to kill.
    • angelos
      • Dec 2012
      • 571
      • South Africa
      Where did you measure off these readings?
      5V 5.15
      Red 3.30
      GRN 0.14
      IR 5.07
      GND 0
      K0/S 3.30
      K1/C+ 3.30
      K2/C- 3.30
      K3/V+ 3.29
      K4/V- 3.27
      K5/M 3.23
      K6/P 3.31
      K7/N 3.31
      GND 0
      • Seville
        • Oct 2022
        • 15
        I measured the voltage readings from the backside of the board. The pin markings were there.
        • Seville
          • Oct 2022
          • 15
          Thanks for the caution note, nomoresonys!
          • angelos
            • Dec 2012
            • 571
            • South Africa
            Can you take a photo of the markings where you took your measurements?
            Also i want to know if you have a standby light?
            • Seville
              • Oct 2022
              • 15
              Attached photo of the ports where the voltage readings were obtained and the lit red standby light.
              When I press the power on button on the tv, nothing happens. Also, when I try the remote control power button, nothing happens, red standby light stays lit.
              Would anyone know which ports to jump to force a turn on? Is that a good next step, or something else. Thank you for your questions and suggestions!
              • angelos
                • Dec 2012
                • 571
                • South Africa
                #27
                I have attached a photo for you to see. Take a clear photo of the area in red. As far as i can remember there is a low drop out voltage regulator. Something with a marking like "1118". Its a 8 pin surface mount ic.
                Pin 2 and 4 must have 5V on it but pin 5 needs to be 3.3V exactly
                Pin 8 is 1.8V
                With mine i always find out that the pin 5 (3.3V) is fluctuating around 3.1V and then the tv will not start up.
                Please measure there and get back to me.
                I have added the datasheet of the IC in question if you are not sure.
                • Seville
                  • Oct 2022
                  • 15
                  Thank you for the suggestion! Photo attached and here is what I measures at each pin for this 1118 component.
                  Pin 1 0v
                  Pin 2 5.15v
                  Pin 3 0v
                  Pin 4 5.16v
                  Pin 5 3.34v
                  Pin 6 3.34v
                  Pin 7 1.82v
                  Pin 8 1.82v
                  All seems to be good with this test. Keep the suggestions coming, please and thank you!
                  • angelos
                    • Dec 2012
                    • 571
                    • South Africa
                    #29
                    Ok, then you can switch on the unit and feel if anything is getting hot, like the processor etc. My bet is for now that your firmware is corrupt. To fix that you might need to get the firmware update from Westinghouse. If nothing then to the bin it goes.
                      • 12206
                      • U.S.
                      #30
                      dont know if you bought this tv or not, but good policy is avoid westinghouse.
                        • 12206
                        • U.S.
                        #31
                        https://www.consumeraffairs.com/home...o_reviews=true sure some give it 4 or 5 BUT theres a whole lot of 1's.
                        • lotas
                          • Jan 2016
                          • 4649
                          • Russia
                          #32
                          If you have a programmer, try to read the dump and put it here, I'll look at the contents, and if the problem is in the firmware, then I'll try to fix it.
                          • Seville
                            • Oct 2022
                            • 15
                            Wow, thanks for all of the support! Very impressive group willing to help here.
                            As an alternative, could I swap this ONN board currently on eBay with the Westinghouse board. It has the same footprint and connections.
                            ONN - ONC18TV-000 Mainboard TP-MS3553 - PB801 ROKU
                            • Seville
                              • Oct 2022
                              • 15
                              Thanks for the offer Lotas.
                              Not sure how I would do this, but interested in learning on how to read the dump.
                              "If you have a programmer, try to read the dump and put it here, I'll look at the contents, and if the problem is in the firmware, then I'll try to fix it."
                              • lotas
                                • Jan 2016
                                • 4649
                                • Russia
                                #35
                                There may be a different firmware, for a different panel, for a different remote control.
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  #36
                                  one of these programmers would probably work ok to read this chip
                                  https://www.ebay.co.uk/itm/203585702...3ABFBM_q306fxg
                                    • 12206
                                    • U.S.
                                    #37
                                    voltage adjustable one there: https://www.ebay.com/itm/40373082870...Bk9SR7Dpy_78YA
                                    • Seville
                                      • Oct 2022
                                      • 15
                                      Thanks for the suggestion and eBay links on the eeprom readers/programmers.
                                      You taught me something new about other various paths that could be taken.
                                      Unfortunately, this is a bit out of my technical league on performing the download/upload.
                                      Surfing the web tonight, I located a replacement board which I did not have any luck in finding over the last couple of weeks. It must have became newly available. I ordered it and will update when it arrives.
                                      A "Midwest Nice" thank you for all of your guidance!
                                      • firefighterfox
                                        Westinghouse L2410NM Power supply?
                                        by firefighterfox
                                        The symptoms are dead set. After looking into the circuits, there are 3 modules. A power supply, main board and a video board. I may or may not be using the right terms. The power supply is obvious. The board that all the LED strips attach to, I'm calling a video board. With the unit plugged into 110 vac and the video and main boards unplugged, I have 3 voltages coming from the power supply. 5vdc, 14vdc, 24vdc
                                        When I plug the two boards into the power supply, all 3 of those power supply voltages drop significantly. I have no schematic on this unit and the boards are not labeled as to where...
                                        06-16-2022, 04:03 PM
                                        by sam_sam_sam
                                        07-01-2024, 06:34 AM
                                      • jmandawg
                                        samsung ln46d630 power supply fuse blown and burn mark
                                        by jmandawg
                                        picked up this curb alert TV. Looks like the fuse is blown, i don't have a fuse to replace is with, is it safe to short with something just to test it? There is also a burn mark in the white glue near a transistor so maybe the transistor is gone as well. Attached is a picture with the burn circled as well as the fuse that is blown.
                                        Board is labeled as: BN44-00463A
                                        What's my next best steps?
                                        Thanks....
                                        07-05-2020, 03:10 PM
                                      • shamsudeen
                                        Hi, Can we use SMPS Bench Power Supply for Laptop troubleshooting?
                                        by shamsudeen
                                        Hi all, I just need to know that, can i use SMPS type power supply to test and short circuit detection on a laptop motherboard?
                                        I saw 95% of repair guys are using only Linear bench power supply. linear bench power supply is pricy, thats why i planned to get one SMPS supply.
                                        i know that in linear power supply the noise will be very low comparing to SMPS supply....
                                        07-19-2025, 07:14 AM
