Ps64e8000 powersupply troubleshoot
  • ant17
    • May 2020
    • 6
    hi i have bn44-00516a power supply out of a samsung ps64e8000 tv which transistor failures in the pfc circuit and the main switchmode supply ic failed taking some tracks with them and the tv has some missing smd caps which i do not know the value of cx814 and cx812 cx813
    and the smd cap cx826 which goes the across the switchmode ic is missing also but i need to know where the track that runs between it goes as it has partialiy missing peice where the red line is the track under cap to either one of those pins seen in the picture can anyone help
  • tvtimmy
    • Mar 2015
    • 1160
    • usa
    Re: Ps64e8000 powersupply troubleshoot
    You have to take closer, and clearer pictures of the board. Yours are to blurry when we zoom in.
    • ant17
      • May 2020
      • 6
      in this image i know where yellow trace goes to but trace going underneath the missing cap i don't know if it take the path of the blue line or the red line
      • diif
        • Feb 2014
        • 6978
        • England
        Go to shopjimmy.com and stick your power supply model number, they have a decent high res photo, albeit slightly obscured by glue.
        • ant17
          • May 2020
          • 6
          thanks have looked not much help thanks anyway
          • R_J
            • 9535
            The correct path is the red line, that is the vcc for pin4 of the ic
            What are you using for a solder iron?
            • lotas
              • Jan 2016
              • 4555
              • Russia
              Look at the datasheet, it has a wiring diagram.
              • ant17
                • May 2020
                • 6
                ok guys thanks i started this repair a few years and was using a yihua soldering iron which got me into trouble in the first place a forgot about until recently dough it out again i am now using a jbc dde soldering station
                • R_J
                  • 9535
                  Based on a similar schematic BN44-00445C, that uses a ICE3BR1065JF
                  CX814 = 474/16v (1608) pin3
                  CX812 = 104/50v (1608) pin4
                  CX813 = 103/50v (1608) pin6
                  There is an electrolytic cap (CM802?) on the vcc line, it should be replaced as well, and CM801 could be also be weak.
                  • ant17
                    • May 2020
                    • 6
                    thank you guys this most helpful
                    • ugamazing
                      820-02020 PPBUS_AON missing
                      by ugamazing
                      Board had no history of liquid; unsure of drop history, but no signs of damage of any kind worth noting.
                      Charger sitting at 5v/0a. PPBUS is at 1.9v-0.9v steady cycle (peaks, drains, loops). Confirmed CHGR_EN_MVR is missing, but DCIN was reaching ISL just fine, so replaced ISL--no change at all. Confirmed pp3v8_aon is also missing--and being unsure *exactly* which signal appears first (or if they are simultaneous), I inspected PMU/U8100 area and found no shorts, but also found PP3V8_AON_MPMU_ISNS_VIN missing (not shorted). Replaced U8100 just in case (have had them fail in weird ways),...
                      02-05-2025, 04:21 PM
                    • jpreza
                      Apple NVIDIA AGP GeForce 6800 GT Dual Link DVI+DVI outputs 603-6338 missing caps!
                      by jpreza
                      I recently acquired this card from a seller who was selling a PowerMac G5 for parts. He mentioned that the video card was probably broken too.
                      Upon closer inspection, I can tell the reason why it won't work: it's missing a bunch of CAPS! (it's also missing an inductor - 1.0uH).
                      It's a nice card as it's one of the few AGP cards that will support 2560 x 1600 resolution on a PowerMac G5 using a 30" Cinema Display.
                      Looking at the card, it appears to be missing the following:
                      1x 1.0uH inductor - orange square
                      2x...
                      11-01-2024, 10:54 PM
                    • gurj1979
                      Asus Zenbook UX431DA / UM431D - Ryzen - missing PWM Fan Signal.
                      by gurj1979
                      Hey guys.
                      Need help with this one.
                      Fan not spinning due to missing PWN Fan signal.
                      Also 5 seconds from powering up it freezes, unless in BIOS.
                      But as soon as Windows starts to load, it will freeze.
                      CPU is COLD / Room temp when it freezes.
                      I've replaced the CPU, same problem.
                      Replaced SIO/KBC IT8987e and reprogrammed - same problem.
                      Replaced fan - same problem.
                      Replaced flex cable from board to daughterboard (which has fan connector on it) - same problem.
                      Checked the Thermal sensors around CPU and Board to the SIO/KBC and...
                      08-19-2024, 05:22 PM
                    • salopian
                      Macbook Pro Retina 13” 820-3476-A (A1502) - missing PM_SLP_S4_L
                      by salopian
                      Hello. I would need some advice please.
                      My son's MBP suddenly stopped working and is now only getting the green-then-orange light on Magsafe and no fan spin.
                      He brought the MBP into the house (22 deg C) from a very cold conservatory (-3 deg C) and turned it on straight away. The Mac suddenly died a few minutes later.
                      I examined the logic board and couldn't find any signs of water damage, corrosion, blown up components etc. Nothing was ever spilt on it, and the logic board looks immaculate.
                      I have already replaced the logic board with another...
                      02-27-2021, 07:30 AM
                    • reessi
                      HP - CE Series - DAG7ALMB8C0 REV.C - MODEL - G7AL-2G - Missing MAINON & SUSON - Turns on power LED & Charges
                      by reessi
                      I have re-soldered the loose pins on the RAM slot which is a common fault on these models..
                      It charges and turns on the power LED but is missing several voltages like RAM and CPU do not come up which I believe is due to MAINON & SUSON being missing to turn these supplies on..
                      What I am un-sure of is what is the ITC chip waiting for to send out these signals, what are the requirements?
                      I have checked these lines in diode mode and they seam normal -> 600.
                      I have checked to see if they come on for even a fraction of a second...
                      07-15-2025, 09:14 AM
