42LG50 no backlight
    Re: 42LG50 no backlight
    Nice work, I replaced these black fuses more than I can count with two hands, I use PICOII Axial lead fuses, none of the TV have come back after three years or more. You can easily measure the current draw using your DMM, if you have peak-hold, you will see the start up current is real close to the fuse rating which does not have any headroom at all.
    • Edm
      • Mar 2013
      Hi, I have this same tv and the same black fuse was burnt as mentioned here for other people.
      I replaced the fuse and now instead of no back light, it simply lights up for a few seconds but will not stay on.
      Does anyone have any idea what would cause it to not stay lit?
      • Seven5555
        • Dec 2015
        Mine also has the same bad fuse and now it turns on for a second and the shuts off. Does anyone have a suggestion on what to test next?
        • triplefour
          by triplefour
          09-13-2023, 10:43 PM
        • DanPoka
          by DanPoka
          02-15-2025, 05:05 AM
        • Comp_Pro
          No Backlight Macbook A1990 820-01041
          by Comp_Pro
          Hello all,
          Am trying to figure out this backlight issue with this A1990 Macbook Pro.
          Tests performed:
          There is no backlight even with a good screen.
          Backlight IC is receiving the correct support voltages.
          Fuse F8400 ok
          Current sense resistor R8400 ok
          Backlight IC is receiving 3.3V on enable pin.
          Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
          Backlight IC receiving 5V from PP5V_G3S
          Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
          I2C_BKLT_SCL and I2C_BKLT_SDA both measure...
          05-06-2024, 10:23 PM
        • jimbofz
          lg 32LC46 backlight inverter board fault
          by jimbofz
          Hi this oldie had no backlight .after replacing caps on 24v rail ,
          still no b/l this uses inverter type:1315 B1-16A,
          im sure ive come across the same inverter in a samsung possibly le32r88bd ?
          all t/x in board test ok ,so i fitted 15k and led to pin 4 of oz964gn ic
          this allows protect to be temporary overridden.
          b/l now comes on
          but the left hand side of pic is gradually darker than the right side
          i have the cct for the tv
          but it does not have inverter cct.
          i opened it up to inspect the ccfl tubes
          and they dont have any...
          12-19-2021, 06:58 AM
        • cheebster
          iPad Pro 12.9 5th Gen Backlight Issue
          by cheebster
          Hello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
          Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
          Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
          The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
          Anyone...
          05-20-2025, 09:17 AM
