Kdl-70w850b Possible Lightning Strike
  • Pontgta
    • Jan 2016
    • 14
    • Us
    I have a SONY TV KDL-70W850B, i believe was struck by lightning. I turn on , and all i see( with Flash light ) are checkered board pattern on the display. any suggestions? I am new to the TV repair world, but have a very basic electrical/ electronics background.
  • dskall
    • Oct 2016
    • 2905
    • usa
    Re: Kdl-70w850b Possible Lightning Strike
    First thing after posting good pictures of boards will be sorting out backlight problem.
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4367
      • Italy - Milan
      Does the set makes a standby led blinking error code?
      • nomoresonys
        • 12206
        • U.S.
        maybe try a firmware update, in case the strike messed up the firmware, more likely to work if your indicator light is a steady green.
        • Pontgta
          • Jan 2016
          • 14
          • Us
          Thanks for all the replies, unfortunately i had to leave after the storm due to work. I am working out of town all week , so i will post pictures on Friday afternoon or Saturday morning of the board layout. .
          The storm took out my cable modem, and Direct Tv receivers as well. I disconnected them, hoping the screen would come back , but no luck, definitely problem with the TV.
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4367
            • Italy - Milan
            Anyway the back leds are much probably hit by strike and must be changed, the chess image is due probably to tcon firmware/settings eprom messed up... if you haven't got a dump and/or programming ability must be changed board.
            • BubbaW
              • Aug 2022
              • 9
              Had same thing happen a few weeks back. Fortunately via assistance from this forum and other online assistant/Youtubes, my problem was main board but only the HDMI inputs. Was able to score a Main board from a TV repair guy in Houston and am awaiting a usb he is mailing me with Firmware update since Sony Terminated updates for my model Jan this year.
              https://www.badcaps.net/forum/showthread.php?t=109404
              It appears you'll have to find someone also that can get you an update since Sony has terminated your model updates also Jan this year.
              https://www.sony.com/electronics/sup...850b/downloads
              If you indeed have to do a firmware update and can find the update, suggest following Nicks's TV repair video !
              https://www.youtube.com/watch?v=3kYPjIHt8Lc
              • Pontgta
                • Jan 2016
                • 14
                • Us
                I have the Firmware, if you need it. It was provided to me from a SONY authorized repair shop.
                • BubbaW
                  • Aug 2022
                  • 9
                  Thanks but I would not know if it is the same for my TV....KDL-55HX800.
                  The fellow I bought main board from is sending update via snail mail on USB and should be here Thur. Did your guy give you a download link or on a USB drive ?
                  • Pontgta
                    • Jan 2016
                    • 14
                    • Us
                    The Firmware is for the Kdl-70w850b. I received it Via DropBox Because its not available through the regular Sony site. I then used my own USB drive.
                    • Pontgta
                      • Jan 2016
                      • 14
                      • Us
                      Can you explain this some more.. I am unsure what the "dump and/or programming ability" Does this require a special tool, and or special programing skill? Would it be easier to replace the board? Are we talking about the Main board or the TCON ?
                      • nomoresonys
                        • 12206
                        • U.S.
                        so did you try the update?
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4367
                          • Italy - Milan
                          requires an hardware programmer even of super low cost and some skill, i clearly refer to tcon
                          but you have 2 faults by the appearance, also bad leds
                          • Pontgta
                            • Jan 2016
                            • 14
                            • Us
                            I am out of town , but will definitely try it when i get home. I wanted to be prepared when i get there.
                            • nomoresonys
                              • 12206
                              • U.S.
                              Ok, yes try the update first, I DOUBT very much that you have a backlight problem.
                              • Pontgta
                                • Jan 2016
                                • 14
                                • Us
                                Back at it.
                                I have 5 red blinking lights with the Tcon connected. If i inplug the Tcon the light do come on on the panel, i can see them in the dark. No image on the screen
                                • dskall
                                  • Oct 2016
                                  • 2905
                                  • usa
                                  So backlights are good. Maybe a firmware or t-con problem.
                                  • Pontgta
                                    • Jan 2016
                                    • 14
                                    • Us
                                    I tried the firmware, but does not load. Only blue flashing light on the led. I need to see about getting a tcon board. I only get the “chess board display when : I power off , disconnect the Tcon from the main board, and “hot plug it in”. If i power on the display with Tcon connected , only 5 red blinking lights, no chess/ checkered board display.
                                    • Pontgta
                                      • Jan 2016
                                      • 14
                                      • Us
                                      Forgot to mention, with the TCON disconnect from the main board, i get a green light. The TCON connected to the main board and disconnected to from the panel, 5 red blinks.
                                      • Davi.p
                                        Hobbist Tech
                                        • Sep 2009
                                        • 4367
                                        • Italy - Milan
                                        Something not clear here, the first post tells that chekered image with no b.light, now b.l. is present and also checkered image when tcon hot plug, this is very strange so my diagnosis confirmed, bad tcon surely (tcon memory), and maybe a faulty b.l.
                                        • Bardou Kari
                                          HP EliteBook 840 G6 – no power after lightning strike
                                          by Bardou Kari
                                          I’m trying to fix an HP EliteBook 840 G6 that stopped working after a lightning storm.
                                          – Charger is OK and 19V is present at the motherboard.
                                          – No charging LED, no fan, no reaction.
                                          – I don’t see any 3.3V or 5V near the coils.
                                          – Battery is unplugged.
                                          – I’m new to board repair but can use a multimeter.
                                          I added a clear photo of the board.
                                          Any idea where to start or what to check next?
                                          Thanks a lot for your help!...
                                          07-01-2025, 10:45 AM
                                        • SluggerB
                                          Panasonic TH-50PX80 killed by lightning strike, help me save her!
                                          by SluggerB
                                          Yes it's a 17 year old Panasonic plasma!
                                          I was watching TV when there was a huge lighting strike nearby my house that shook the house. When that happened, the picture on the TV froze and the TV wouldn't turn off except by pulling the power cable. Now if you plug in the TV, it seems to turn on (it makes the turn on "clikcs" it always does, the red power light comes on but there is no picture, although I can see the back light around the edges. And the TV doesn't respond to the power button on the remote to turn off, and doesn't respond to the manual power button on the front...
                                          06-04-2025, 07:02 PM
                                        • karthur
                                          Samsung UN60EH6000 wont come on after lightning strike.
                                          by karthur
                                          We had a lightning strike a few days ago really close to my house. My Samsung UN60EH6000 was on when it hit. Afterwards, the TV would not come back on.
                                          I had repaired this TV a few years back by replacing the T-Con board. (The post I had on this is repair is here.)
                                          When I turn on the TV, I don't get any start-up melody. The screen just dimly flickers around the edges.
                                          Here is what I have checked.
                                          On the power supply board, 14pin connector:
                                          1 :12.7 Vdc
                                          3 :12.7
                                          5 :12.7
                                          7 :12.7
                                          9 :0
                                          11 :5.
                                          13 :5....
                                          11-01-2023, 06:18 PM
                                        • MrCreosote
                                          Lightning Strike: 55" TV dead: is display panel OK?
                                          by MrCreosote
                                          THE LIGHTNING:
                                          This was a very close strike, blew a 15 amp breaker for all ceiling lights in home AND could smell ozone for a few minutes after strike.
                                          Very close and probably a very strong EMP.
                                          THE TV:
                                          No standby LED. Some voltage from PSB (not totally dead).
                                          But found a kit of ALL 4 circuit boards for $55.
                                          At first thought, this will fix my TV.
                                          But then lightning has the ability to totally fry semiconductors. Which would include any or all of the PCBs. However, the display is one big semiconductor and given...
                                          08-16-2021, 10:27 PM
                                        • pbig
                                          advices for repairing Sony Bravia 32EX600 after lightning strike
                                          by pbig
                                          hi everyone,
                                          my parents in law have seen their Bravia Sony LED 32EX600 TV set stop after a lightning strike. After being plugged to mains, it shows nothing no power LED on bottom left shines.
                                          On the power PCB (GE3b, attached pic), I chacked the fuses and the only roasted one is R6536 : 0.47 ohms, 1/2W. After replacing it, I made some voltage measurement with ref to the chassis :
                                          - the 450V/150uF capacitor voltage when plugged is normal at 394V
                                          - from connector CN6150 (15 poles)
                                          STBY normal 3.3V -> I shunted it to 3 (POWER ON) and 11 (BL ON) and unplugged...
                                          06-28-2023, 02:43 AM
