Sony KDL 55HX800 Lightning-HDMI's bad
  • BubbaW
    • Aug 2022
    • 9
    Last week our home was hit hard by lightning, so much so that 4 transformers on our street were blown out.
    Items lost....DirecTV box, Cable TV box and initially Sony 55"....all inputs hooked up via HDMI. We have since purchased new set but wanted to at least try and see if this TV can be fixed.
    Initially while T/S, found all inputs fine except T-Con_ON = 0VDC
    but front panel had 3 red blinks. Yesterday took Pwr Supply and Main Board out to check for any noticeable failures. Coincident or not, after replacing both boards the TV started working fine but only when hooked up to Cable TV or RCA inputs. All HDMI inputs bad.
    Voltages when ON....
    1 STBY 3.3V = 3.3
    2 AC_OFF_DET = 3.3
    3 PWR ON = 3.27
    4 Audio12V = 12.68
    5 GND
    6 GND
    7 GND
    8 REG12v = 12.68
    9 REG12v = 12.68
    10 T-CON.VCC.12V =12.68
    11 T-CON_ON = 3.33
    Is it indeed possible by removing/replacing CCA's that it caused things to be flushed and all is well....excluding HDMI inputs that don't work.
    If I can find a Main Board for this 10 year old TV, is there an update I'll have to apply to TV ?
    Main Board P/N 1-881-636-62....SHOPJIMMY says Out of Stock.
    Any comments/suggestions welcomed
    Thanks,
    Bubba
  • Diah
    • Feb 2013
    • 6359
    Re: Sony KDL 55HX800 Lightning-HDMI's bad
    All HDMI are bad tell me yours HDMI Cable cooked by lighting
    • BubbaW
      • Aug 2022
      • 9
      Yep, pretty much a given as I stated above but still debating getting a new Main Board !
      • Diah
        • Feb 2013
        • 6359
        don't call it new main boards LOL. and why you need to repair it if you bought it as defect.
        your lands are knowing by lighting and the chance to find MB with out such defect are low.
        • BubbaW
          • Aug 2022
          • 9
          Have no clue what you're talking about. I bought nothing that was a "defect". The Main board on the subject TV got hit by lightning and trashed the HDMI inputs. We have since bought new TV but want to try and fix bad TV to use upstairs. Perhaps your simply misunderstanding the problem or simply not reading what whole problem is.
          • nomoresonys
            • 12141
            • U.S.
            there are these, probably good for 1 connection, this one is for component out of tv to hdmi device, it doesn't do hdmi of tv out to component device as stated in the ad, that's just one, they have more at various prices: https://www.amazon.com/Component-Con...cs%2C94&sr=1-3
            • nomoresonys
              • 12141
              • U.S.
              could be it fried your hdmi chip, new chip might work or new mainboard.
              • Diah
                • Feb 2013
                • 6359
                you wrote replacing. or you just put them back again... !
                well Lighting always its damage the main Soc or Tuner.. qt your case i would think its BGA on the Soc related to HDMI. sony had diagnose service menu.. try to call it to see if there any error register at it.
                • nomoresonys
                  • 12141
                  • U.S.
                  you can also go with a vga to hdmi converter, will plug into vga input on tv where you would connect a computer to tv, if your vga still works. then put source on vga/pc and the hdmi device will work. probably would need to work out the sound tho, pretty sure vga doesnt carry sound like hdmi does.
                  • nomoresonys
                    • 12141
                    • U.S.
                    maybe try a firmware update if you can find one, might not work but you never know, I'm not possitive but this board may work for you, they do have a make offer option: https://www.ebay.com/itm/23465492813...MAAOSw3aNi9AF0
                    • BubbaW
                      • Aug 2022
                      • 9
                      Thanks....the board number matches but the part # A1754478A is different from mine on the last digit....A1754478B
                      Is there a way to find out if the boards are in actuality the same ?
                      My board....
                      • nomoresonys
                        • 12141
                        • U.S.
                        I think they are the same part, here's some info from shopjimmy: https://www.youtube.com/watch?v=Aodz2LHkzbY
                        • BubbaW
                          • Aug 2022
                          • 9
                          Received a Main Board replacement purchased from Davids TV repair in Houston TX.
                          After installing, rcvd green and amber blinking lights which supposedly denotes needing firmware update. Sony terminated my model updates Jan this year. TV repair guy thru his contacts is sending me Firmware update via USB. Will update further after applying update.
                          • nomoresonys
                            • 12141
                            • U.S.
                            good work, be sure to save that firmware in case you need it again.
                            • BubbaW
                              • Aug 2022
                              • 9
                              Applied firmware and after about 3rd try with lights still blinking green/amber, took a few minute break. On return, the update was surprisingly showing complete and all HDMI inputs now working.
                              Helpful video from Nick's TV Repair....
                              https://www.youtube.com/watch?v=3kYPjIHt8Lc
                              • Carlos#2003%
                                Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                by Carlos#2003%
                                Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                02-15-2024, 07:52 PM
                              • dkneyle
                                Sony KDL-46HX850 Can't upgrade/update firmware
                                by dkneyle
                                Diagnosed this TV as having a failed main board which I've replaced with one from a KDL 55HX850. They are (supposedly) the same board.
                                Being 'Smart TV' it requires a firmware reboot when you swap out boards such as T-Con or main board. It starts with a black screen and flashing yellow and green LEDS, indicating it needs that firmware boot. The procedure described all over the web is to put the software into the root directory of a FAT32 formatted USB drive and it should load that up once plugged into USB1 port. But not for me. I can see the LED on the USB chip flash for about...
                                09-25-2024, 10:44 PM
                                Sony VAIO SVF11N1L2E Hybrid (2-in-1) Fit multi-flip Specification for Upgrade or Repair
                                This specification for the Sony VAIO SVF11N1L2E Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the SVF11N1L2E boardview and SVF11N1L2E schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                09-06-2024, 05:27 AM
                                Sony VAIO Duo 11 Hybrid (2-in-1) Duo 11 Specification for Upgrade or Repair
                                This specification for the Sony VAIO Duo 11 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Duo 11 boardview and Duo 11 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
                                09-06-2024, 05:30 AM
                                Sony VAIO VGN-SR29VN/S S Specification for Upgrade or Repair
                                This specification for the Sony VAIO VGN-SR29VN/S can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the VGN-SR29VN/S boardview and VGN-SR29VN/S schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Sony VAIO...
