Kdl-70w850b Possible Lightning Strike
  • Pontgta
    • Jan 2016
    • 14
    • Us
    Re: Kdl-70w850b Possible Lightning Strike
    Originally posted by Davi.p
    Something not clear here, the first post tells that chekered image with no b.light, now b.l. is present and also checkered image when tcon hot plug, this is very strange so my diagnosis confirmed, bad tcon surely (tcon memory), and maybe a faulty b.l.
    Yes , seems like i get a couple of different things every time i plug in. Now i getting the 5 blinking lights , unless i “hot” plug in the Tcon. If i unplug the Tv and unplug the TCON , i will get a blue / white light. If i then pug in the TCON while the TV IS POWERED ON, i get the flashing chess , red blue and white( test pattern). I decided to plug in my laptop to hdmi 1 , and i can hear sound , and me choosing inputs, but only the “test” pattern is displayed.
    • Davi.p
      Hobbist Tech
      • Sep 2009
      • 4286
      • Italy - Milan
      ok no mess around, the diagnosis is already been done, now it"s up to you..
      • lotas
        • Jan 2016
        • 4528
        • Russia
        Sony has a T-con and a panel attached to the motherboard, that is, when it is turned on (self-diagnostics occurs), the processor verifies (as if serial numbers) and if it detects someone else's T-con or panel, it will give an error, in this case only an update helps or EEPROM transplant.
        Error code "5" is a problem with T-CON.
        • nomoresonys
          • 12094
          • U.S.
          Originally posted by lotas
          sony has a t-con and a panel attached to the motherboard, that is, when it is turned on (self-diagnostics occurs), the processor verifies (as if serial numbers) and if it detects someone else's t-con or panel, it will give an error, in this case only an update helps or eeprom transplant.
          Error code "5" is a problem with t-con.
          +1000
          • nomoresonys
            • 12094
            • U.S.
            Post #23, there's your solution, Lotas knows what he's talking about, backlights are fine.
            • Pontgta
              • Jan 2016
              • 14
              • Us
              #26
              Thanks for the reply , i am awaiting parts
              • Pontgta
                • Jan 2016
                • 14
                • Us
                #27
                I installed the Tcon board , along with new cable. I get orange and green flashing lights. I can not get the main board to update . If i disconnect the Tcon board from the main board, power on the tv, power off the Tv, then plug in the Tcon, i get a clear and perfect picture and sound( hooked up computer as test).
                When i disconnected the power from the wall , and power the TV back on, goes back to the orange and green flash.
                What are my next steps, i feel like i am getting closer..
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4286
                  • Italy - Milan
                  #28
                  how is exactly the flashing led? Is it 1orange 1 green alternated?
                  • Pontgta
                    • Jan 2016
                    • 14
                    • Us
                    #29
                    Was 1 orange/amber. , 1 green , but since last post finally got it to update. I cannnot thank everyone enough! The fix was to make sure the file on the usb drive was correctly unzipped.
                    These are the instructions.
                    File information:
                    Download file: sony_tvupdate_2014_3004_aaa_auth.zip
                    Folder on USB: sony_dtv0FA40A06A0A6_00003301
                    File in folder: 00003301_041e0000.bin
                    Note: For Main Board Replacements, must do below:
                    1.Install the software
                    a.Insert the USB device with the latest software.
                    b.Connect TV to AC power.
                    c.Wait at least 20 seconds.
                    d.Press POWER on the TV to turn ON the TV. ( even though the green and amber lights were flashing). I left the TV alone , ate dinner , and when i came back i had a “update complete message”.
                    e.Wait until the Software update is completed
                    The TV is Alive! Thank you again everyone.
                    • nomoresonys
                      • 12094
                      • U.S.
                      #30
                      Well davi ***********************************
                        • 20561
                        You and Davi.P stop it off right now or you`ll both get banned, we are fed up with your childish nonsense.
                        • nomoresonys
                          • 12094
                          • U.S.
                          #32
                          Thanks mod, glad to see someone is awake.
                          • nomoresonys
                            • 12094
                            • U.S.
                            #33
                            As to the ban threat, ban away I really could care less.
                            • Topcat
                              The Boss Stooge
                              • Oct 2003
                              • 16956
                              We're not in fugging junior high school. The bickering will stop; one way or another. This forum has an 'ignore member' function; those whom can not get along, I suggest use it!
                              <--- Badcaps.net Founder
                              Badcaps.net Services:
                              Motherboard Repair Services
                              http://folding.stanford.edu/
                              Team : 49813
                              Join in!!
                              Team Stats
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4286
                                • Italy - Milan
                                #35
                                i have found the ignore command, hope that will work .. now stop nomoresonys 4 ever..
                                • Bardou Kari
                                  HP EliteBook 840 G6 – no power after lightning strike
                                  by Bardou Kari
                                  I’m trying to fix an HP EliteBook 840 G6 that stopped working after a lightning storm.
                                  – Charger is OK and 19V is present at the motherboard.
                                  – No charging LED, no fan, no reaction.
                                  – I don’t see any 3.3V or 5V near the coils.
                                  – Battery is unplugged.
                                  – I’m new to board repair but can use a multimeter.
                                  I added a clear photo of the board.
                                  Any idea where to start or what to check next?
                                  Thanks a lot for your help!...
                                  07-01-2025, 10:45 AM
                                • SluggerB
                                  Panasonic TH-50PX80 killed by lightning strike, help me save her!
                                  by SluggerB
                                  Yes it's a 17 year old Panasonic plasma!
                                  I was watching TV when there was a huge lighting strike nearby my house that shook the house. When that happened, the picture on the TV froze and the TV wouldn't turn off except by pulling the power cable. Now if you plug in the TV, it seems to turn on (it makes the turn on "clikcs" it always does, the red power light comes on but there is no picture, although I can see the back light around the edges. And the TV doesn't respond to the power button on the remote to turn off, and doesn't respond to the manual power button on the front...
                                  06-04-2025, 07:02 PM
                                • karthur
                                  Samsung UN60EH6000 wont come on after lightning strike.
                                  by karthur
                                  We had a lightning strike a few days ago really close to my house. My Samsung UN60EH6000 was on when it hit. Afterwards, the TV would not come back on.
                                  I had repaired this TV a few years back by replacing the T-Con board. (The post I had on this is repair is here.)
                                  When I turn on the TV, I don't get any start-up melody. The screen just dimly flickers around the edges.
                                  Here is what I have checked.
                                  On the power supply board, 14pin connector:
                                  1 :12.7 Vdc
                                  3 :12.7
                                  5 :12.7
                                  7 :12.7
                                  9 :0
                                  11 :5.
                                  13 :5....
                                  11-01-2023, 06:18 PM
                                • MrCreosote
                                  Lightning Strike: 55" TV dead: is display panel OK?
                                  by MrCreosote
                                  THE LIGHTNING:
                                  This was a very close strike, blew a 15 amp breaker for all ceiling lights in home AND could smell ozone for a few minutes after strike.
                                  Very close and probably a very strong EMP.
                                  THE TV:
                                  No standby LED. Some voltage from PSB (not totally dead).
                                  But found a kit of ALL 4 circuit boards for $55.
                                  At first thought, this will fix my TV.
                                  But then lightning has the ability to totally fry semiconductors. Which would include any or all of the PCBs. However, the display is one big semiconductor and given...
                                  08-16-2021, 10:27 PM
                                • pbig
                                  advices for repairing Sony Bravia 32EX600 after lightning strike
                                  by pbig
                                  hi everyone,
                                  my parents in law have seen their Bravia Sony LED 32EX600 TV set stop after a lightning strike. After being plugged to mains, it shows nothing no power LED on bottom left shines.
                                  On the power PCB (GE3b, attached pic), I chacked the fuses and the only roasted one is R6536 : 0.47 ohms, 1/2W. After replacing it, I made some voltage measurement with ref to the chassis :
                                  - the 450V/150uF capacitor voltage when plugged is normal at 394V
                                  - from connector CN6150 (15 poles)
                                  STBY normal 3.3V -> I shunted it to 3 (POWER ON) and 11 (BL ON) and unplugged...
                                  06-28-2023, 02:43 AM
