Luxor TV board input board change but picture upside down
  • garrymc123
    • Apr 2010
    • 336
    • United Kingdom
    Looking for some advice changed over the video input board due to bad hdmi ports but now the picture is upside down tried the service menu but can't find anything to do with flip the picture..
    Is there anything I can do to flip the picture or do I need to change the board again..
    Garry
    Your never to old to learn
  • cheeky2
    • Dec 2012
    • 337
    Re: Luxor TV board input board change but picture upside down
    So I assume you have a VES550UNDS-2D-N11 screen inside your TV. If you do then if the board you have inside it is the one pictured, then you have a faulty board! As they only do one main board for that model of TV.
      • 12140
      • U.S.
      when you get into the service menu with 4725 what are all the choices? factory reset might work.
      • vinceroger69
        • Mar 2012
        • 6714
        i think with vestel you need a panel profile on a usb stick
        • yokoono
          • Apr 2010
          • 481
          I saw that the motherboard is 17mb97. If you also say the panel code (VESxxxxxxxxx), I will help you with a panel profile. In 3 minutes it is solved.
          • garrymc123
            • Apr 2010
            • 336
            • United Kingdom
            Yeah it is a ves panel
            • yokoono
              • Apr 2010
              • 481
              1. Format a stick with FAT32
              2. Put a folder called PQ on the stick
              3. Unzip and put the 2 files in the pq folder
              3. Turn on the TV and insert the USB stick
              4. Type MENU 4725
              5. Go to USB Operations and type OK on the remote control
              6. Wait 10 seconds and exit the menu with back/return
              7. Turn off the TV from the remote control and wait 10-20 seconds
              8. Unplug the TV and wait until the stby LED on the TV turns off
              9. Take out the stick, plug it in and turn on the TV.
              • garrymc123
                • Apr 2010
                • 336
                • United Kingdom
                Brilliant yokoono that it sorted thanks again to this forum.. Thanks
                • TvUser1234
                  • Oct 2023
                  • 9
                  • Ireland
                  Hey yokoono,
                  Any chance you have a profile for
                  VES43DUNDA-2D-N12
                  If you do that would be amazing
                  • yokoono
                    • Apr 2010
                    • 481
                    Cod main (17mbxxxxxx) ????.
                    • TvUser1234
                      • Oct 2023
                      • 9
                      • Ireland
                      17mb97
                      • yokoono
                        • Apr 2010
                        • 481
                        I don't have a profile for this panel. What problems does the image have?
                        • TvUser1234
                          • Oct 2023
                          • 9
                          • Ireland
                          The image is upside down, unfortunately.
                          I can order a new board I just thought I'd ask here first��
                          • yokoono
                            • Apr 2010
                            • 481
                            Save the TV profile on the stick.
                            1. Format the stick with fat 32
                            2. Create a folder called downloadpq.mb95 on the stick
                            3. MENU, 4725, go to USB Operations, OK.
                            4. Post the resulting profile from the stick and make the change
                            • TvUser1234
                              • Oct 2023
                              • 9
                              • Ireland
                              Hey I'm so sorry for the late reply I had a death in the family and its been a tough time. Are you still happy to try and help me?
                              • TvUser1234
                                • Oct 2023
                                • 9
                                • Ireland
                                I followed your steps but the downloadpq.mb95 folder is blank.
                                In the service menu It does have "Profile:File Not Found"
                                • yokoono
                                  • Apr 2010
                                  • 481
                                  Try with another stick of smaller capacity. Maximum 16Gb.
                                  • TvUser1234
                                    • Oct 2023
                                    • 9
                                    • Ireland
                                    I will go try now. I used a 16gb there but I have a 4gb
                                    • arizanotlari
                                      • Nov 2014
                                      • 158
                                      • Turkiye
                                      https://disk.yandex.com/d/-YdVftsdIffr6w
                                      https://www.badcaps.net
                                      • TvUser1234
                                        • Oct 2023
                                        • 9
                                        • Ireland
                                        This is all im getting
                                        • m1ch43lzm
                                          by m1ch43lzm
                                          05-12-2025, 08:37 PM
                                        • tvguy12012012120
                                          by tvguy12012012120
                                          02-07-2025, 05:13 PM
                                        • jb_Bak
                                          by jb_Bak
                                          CN6401
                                          Pin 01 NC
                                          Pin 02 NC
                                          Pin 03 "BL_ON": 0V
                                          Pin 04 "N/C"
                                          Pin 05 "STBY 3.3V": 3.5V
                                          Pin 06 "GND": N/C
                                          Pin 07 "AC_OFF"...
                                          09-27-2021, 04:52 PM
                                        • Dani_2024
                                          by Dani_2024
                                          10-28-2024, 05:06 PM
