Samsung QE55Q85RAT bootloop
  • tehmatix
    • Nov 2012
    • 180
    Hi, I got this Samsung with One Connect box Q7, start to reboot after show on display the logo. I tried with another One connect box and still has bootloop.
    Now I took of the back cover of tv and inspected the boards and connectors.
    I did a reheat of the processor with hot air but still has same problem.
    What can I do to test the backlight ? It is a way to remove the protection?
  • Storyteller12
    • Jun 2020
    • 625
    Re: Samsung QE55Q85RAT bootloop
    Try unplugging the cables going to the panel and see if the tv stays on. It won’t show a picture but if it stays on and doesn’t reboot its a problem with the panel.
    You can try the tape cutoff method if so
    • dskall
      • Oct 2016
      • 2905
      • usa
      I believe unplugging power cable to main board should turn on backlights.
      • tehmatix
        • Nov 2012
        • 180
        Thank you so much for your help, I disconnected the panel and tv is starting with the welcome sound, the backlight staying on.
        So, I have a bad panel? What can I do ? Start to check for a bad cap on T-con board ?
          • 12330
          • U.S.
          what side of tcon did you unhook? if panel side, then probably start checking small caps on panel driver board/s.
            • 12330
            • U.S.
            looks like you need to take some crap off to get to them.
            • tehmatix
              • Nov 2012
              • 180
              Tv is on when half of panel is connected, no matter which ribbon cable , left or right, is connected with mainboard . When both ribbons are attached to the mainboard the tv is on bootloop and a strange sound, like a “buzzz” it's coming from the mainboard.
              • dskall
                • Oct 2016
                • 2905
                • usa
                Appears you have a voltage problem. Looks like t-con and mainboard all in one.
                • Diah
                  • Feb 2013
                  • 6560
                  upload please high resolution focused photos of the LVDS socket left and right side on the Mainboards to reed to assignment of the pins
                  • Storyteller12
                    • Jun 2020
                    • 625
                    Can we get good clear pictures of the buffer boards.
                    • tehmatix
                      • Nov 2012
                      • 180
                      Pictures
                      • Diah
                        • Feb 2013
                        • 6560
                        try to mask the exact pins on this socket and turn on.. notice if it stay on and display picture... if yes.. you have panel fault... if no result your issue on Main boards. good luck
                        • tehmatix
                          • Nov 2012
                          • 180
                          Thank you Diah , I managed to mask the pins. Nothing is changed, still making the problem, restarting after displaying the logo
                          • Diah
                            • Feb 2013
                            • 6560
                            yours TV with external connect box ! did you try to disconnect it and turn on..
                            did you check if BL come on when you disconnect the socket between MB and PSU
                            • tehmatix
                              • Nov 2012
                              • 180
                              First time I unplugged the cable link between one connect box and tv for one day, and disconnect the box from the mains, 240v .
                              Backlight inverter is powered by mainboard
                              • Diah
                                • Feb 2013
                                • 6560
                                no way MB are involved with BL inverter VCC.. its only send dimm and BL on.
                                inverter VCC for BL recieved from PSU
                                • Diah
                                  • Feb 2013
                                  • 6560
                                  so testting by disconnect the Ribbon cable between MB and LED inverter... and disconnect the socket between MB and PSB and turn on notice if the BL lit dimm
                                  • Diah
                                    • Feb 2013
                                    • 6560
                                    we approved Panel Ok. and thought on MB. but now you need to consider on BL circuit starting from LEDs units,
                                    as your TV full array LED. so when it first boot there will be only about 12LED at the middle lighting up. after the boot of logo all LED should be lighting up. but here you have issue. so tv reboot.
                                    same case when you force the MB to turn on by disconnect one LVDS you hear buzzer.. this buzzer i do think it come from PCB or the inverter not MB.
                                    if you feel your self confident by take the panel self will be good start to be sure all LED are fine before you going to replace boards.
                                      • 12330
                                      • U.S.
                                      I would not own a tv with that damn box, just another way for lousy samsung to rake people for more money.
                                        • 12330
                                        • U.S.
                                        is the other one box the very same? also remember reading something was fishy with a lot of the cables that connect the box to the tv.
                                          09-07-2024, 05:50 AM
                                        • KYBOSH
                                          Trying to Save - Samsung 65" The Frame (QN65LS03B) with no signs of life (One Connect Box)
                                          by KYBOSH
                                          I picked this one up today.
                                          Previous owner says no signs of life.
                                          TV looks immaculate and its a 2022 model year so I thought maybe the one connect cable was damaged.
                                          Got it home and put it on the Kill-A-Watt power meter and it was completely dead.
                                          The TV model is QN65LS03BAFXZA - version: CB06
                                          The One Connect Box BN44-01066D / BN96-54788Q / BN39-02470A.
                                          I immediately remembered EazyBone's Samsung The Frame TV no power....One Connect thread and am preparing myself to tear the One Connect open and hunt for dead parts.
                                          Will keep you all...
                                          04-05-2025, 08:32 PM
                                        • atkallu
                                          Samsung One Connect Box SOC1001N vs SOC1004N
                                          by atkallu
                                          I am asking have somebody information about Samsung one Connect boxes compatibility ?
                                          So, can I use SOC1001N box on the TV which have SOC1004N box, is it compatible ?
                                          SOC1001N box has been worked with Samsung QE55Q8 and the SOC1004N box has been used with Samsung QE55Q9.
                                          Boxes part numbers are the same: BN68-08730A-00.
                                          07-09-2025, 01:54 PM
                                        • An-klamm
                                          Samsung 55HU8590 UE55HU8590 maybe one connect box ocb
                                          by An-klamm
                                          Hello!
                                          I have a TV that I can't get any further with.
                                          It is a Samsung UE 55HU8590 with one connect box.
                                          When I turn on the TV without the one connect box, the animation on the TV tells me to connect the ocb.
                                          As soon as I connect it, the TV restarts (panel goes dark) and the TV tries to start continuously (relay on the SMPS clicks about every 3 seconds).
                                          Since the TV works without ocb, I assume that it can't be the PSU?!
                                          I have measured all contacts of the one connect cable against GND on the ocb board and there is no short circuit anywhere.
                                          Is there...
                                          12-04-2023, 01:35 AM
                                        • AlexVG
                                          SAMSUNG UE65HU8500 ONE CONNECT pinout connector request
                                          by AlexVG
                                          I came across with
                                          SAMSUNG UE65HU8500
                                          ONE CONNECT BN41-02135
                                          Chassis GOLF_UHD_1MP_JACK
                                          TV can not recognise ONE CONNECT box, so I need to know the pinout of the CN 3301 connector.
                                          Moreover, on the main is written A5V. However, cable connected this pin to the GND.
                                          Maybe somebody have an experience with the same issues?
                                          I need your help.
                                          Thank you....
                                          06-08-2025, 06:49 AM
