Grundig 48 VLX 8582 BP, Possible T-CON issue?
  • Gjackson
    • Aug 2021
    • 134
    • Malta
    Re: Grundig 48 VLX 8582 BP, Possible T-CON issue?
    I'll go ahead and order a new t-con, as nomoresonys said it's not worth the headache of component level, could I buy a t-con with the same model number that came from a different brand TV? as the cheapest I found on ebay came from a panasonic not a grundig.. Thank you all for helping me
    • Gjackson
      • Aug 2021
      • 134
      • Malta
      was looking at something like this:
      https://www.ebay.de/itm/265207476678...MAAOSwpHZg1aCI
        • 12328
        • U.S.
        you want to match up the numbers on the white stickers.
        • Gjackson
          • Aug 2021
          • 134
          • Malta
          Closest I was able to find was this after searching eBay and aliexpress:
          pic1 is my board.
            • 12328
            • U.S.
            some info there on part matching, can also check and see if it's match for your panel number, meaning compatible, not that the panel # and board # will be the same: https://www.shopjimmy.com/finding-the-right-tv-part/
            • markolino
              • Mar 2020
              • 109
              • Slovenia
              #26
              Hi..
              News of this tv ???
              You buy a new T-Con ?
              You need exactli same T-Con whit sam model
              Because firmware of tcon of Aliexpress not compatible of your TV
              • kca
                by kca
                Hello all ~
                08-31-2025, 06:38 AM
              • x_orange90_x
                TCL 50S535 bad tcon or panel issue?
                by x_orange90_x
                Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                03-29-2025, 11:02 PM
              • Chrissygizmo
                by Chrissygizmo
                02-10-2025, 12:33 AM
              • Daren87
                Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                by Daren87
                I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                08-13-2023, 03:25 PM
              • wizard13
                Dynabook Satellite Pro C50D-B-100 - BIOS Issue, Black Screen
                by wizard13
                I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
                I have checked the forum and the available documentation but could not find a solution specific to my issue.
                • Brand & Model: Dynabook Satellite Pro C50D-B-100
                • Part Number (P/N): PYU13E-00C00PFR
                • Serial Number (S/N): 22028896H
                • System Configuration (SC): A1PYU13E1127
                • Motherboard Model: IP3_ACN16_MB_V21_20211222A
                • Power Input: DC 19V –
                02-28-2025, 02:43 AM
