philips 65PUS6162/05 dead no sby led
  • Maalobs
    replied
    Re: philips 65PUS6162/05 dead no sby led
    To capture the serial-output of the boot log you need a serial-adapter tool like this:
    https://thepihut.com/products/usb-to...r-raspberry-pi
    When you plug in this device into your computer, it shows up as a new serial-port and you can then connect to the serial-port in the computer with a terminal-emulator like Tera Term or Putty.
    You then hook up the headers of the serial-adapter to the correct pins on the device under test.
    USB GND - to - DUT GND, obviously. (black)
    USB RX - to - DUT TX, this is how you receive data from the DUT to your terminal window. (white)
    USB TX - to - DUT RX, this allows you to transmit typed commands into the DUT. (green)
    The red header you can ignore, it's for powering IoT devices.
    This product with the blue case appears to be the real deal from Adafruit so it should have a brand controller in it which means the Windows driver will work with it.
    If you find some alternative that's cheaper than this one, then it's probably built on a pirated controller chip and the Windows driver will detect that and refuse to work.
    The pirated versions still work fine in Linux, though.
    You will still have to mess around a bit with the speed setting in the terminal software, if you get garbage characters or just a single garbage character then you are probably set to the wrong speed and you should try some other speeds.
    115200 and 57600 are a couple of likely choices, and keep the other settings at "8N1", meaning "8-bit, no parity, 1 stop bit", you will find this all under "port settings" or similar in the terminal software.
    Just passively catching the boot log only requires hooking up the black and the white headers (GND and RX), but it sounds from Diah that you need to type some command, that means that you need to hook up the green header too (TX).
  • jimbofz
    replied
    i will have to learn how to do boot capture
    once i have this i will reply,
    i tried to research regarding your earlier post on:
    "stuck on half boot"
    but could not find much information on this,
    every day is a learning day
  • Diah
    replied
    if you do boot log capture we can tell how to reset with command... but if there are no log its wasting time.
  • jimbofz
    replied
    update :finally mosfet MTN127 KN3 arrived fitted replacement and sadly no change in symptoms dooh!!!
    ive been trying to buy correct main board that matches the screen numbers:
    :715g-8709 MOE B00 005N
    SCREEN PANEL TPT650UA-QVN06U
    none available so i thaught i would replace the scaler ic MT5802-VGET
    but this ic is not listed anywhere
    can anyone advise where i can buy this MT ic?
    these chinese made boards have many versions,its so frustrating .
    like a needle in a haystack.
    after a lot of thaught
    just wondered if theres a way of doing a hard reset to the scaler ic ,
    as theres a 3 pin plug on main board
    this reset may bring the micro back to life ? any ideas please
  • jimbofz
    replied
    thanks will order today
  • jimbofz
    replied
    Originally posted by dskall
    sadly this links to ali ex out of stock thanks for trying
  • lotas
    replied
    https://www.transistorfet.com/transi...N127KN3-0-T1-G
  • dskall
    replied
    https://alltransistors.com/
  • jimbofz
    replied
    thaught i would try again with fresh head
    i found the reason the backlight is not turned on
    q8611 mosfet type MTN127 KN3 is oc
    this allows u8601 the backlight driver ic to start when LVC-VSEN is fed to its gate
    the bad news i cant source this mosfet anywhere not even the usual chinese suppliers
    its a sot23 with built in prot diode 600v n chan cant find equivalent
    has anybody any ideas where i may buy one please?
  • jimbofz
    replied
    thanks for trying so hard to help
    i dont know how to capture start log from UART on SM
    ive been looking for correct board but at the moment only the smaller screen MB are available and im not sure if they will work as the screen panel type are different
  • Diah
    replied
    Originally posted by jimbofz
    heres the results;
    it means Analog power circuit on MB are fine... but the digital are fault
    2 ways u have now..
    capture start log from UART port on S.M you have the sign of TX & RX to see where are the script stooped and give error..
    or go direct reflew urs MTK chips before u are going to replace MB
  • jimbofz
    replied
    heres the results;
    pin1= .18v pin2=earth pin3=3.3v pin4 = 0v( on enable pin) pin 5=5v
    without enable pin active no o/p to hdmi skt
    surely the processor needs to turn on this ic with enable pin4? so no enable means no o/p?
    i tried with usb stick and without
  • Diah
    replied
    heres the jpg
    i traced the 5v from u713 to u108 ic 54B3R
    this lives in corner of board near to usb skt this ic i suspect is not turned on so no volts on usb skt
    sorry image upside down even though it was uploaded correct way up
    you need to plug in USB stick and do the messurments..
    U108 recieve 5V on Pin5 and V out 5V on Pin1 if Pin1 <0 and the IC get warm mean you have short at some USB sockets. if its not geting warm mean IC are Open
  • jimbofz
    replied
    heres the jpg
  • jimbofz
    replied
    there is 12.4v on d702
    it feeds u713 8pin ic
    that produces 5v on pin 1 u713
  • Diah
    replied
    i understand the principle of testing psu stand alone,
    but with this test all six pins on the 12v psu socket surely will read the same as they are connected together
    should this test reveal 18v ?
    ie with no load on psu?
    you are right ,that on the MB the pins are separate 3,4,5,6, and 7,8
    no, dont do the test of stand alone..when you have all 6 pins take same 12V even with PFC on.
    locate D702 on MB we need to know why there are no 5V on USB ports
  • jimbofz
    replied
  • Diah
    replied
    PIN 7/8 AU 12V this is always remain 12V like STB
    PIN 3/4/5/6 PW18V_12V this go high after the PSU PFC goes high ( after PSU recieve PS_ON .
  • Diah
    replied
    read my post #46 first.. and open page 48 onS.M to take look on MB socket ( system Power ) , on this socket 3-4-5-6 should have PW18V_12V after TV turn on.
    PW18v_12V dosnt mean exactly shoild be 18V . but its range of main power DC will be bossted as much the MB need forexample speaker run on high vloume..etc,
    we dont care now on howmuch... but we need to know if the PSU produce this PW18V_12V or not..
    if not then you need to work on the PSU as stand alone to touble shooting it. if there are PW18V_12V on the MB socket 3-6 mean your PSU OK.
  • jimbofz
    replied
    thank you Diah for your patience
    just so im clear ,i should unplug MB and feed from 12v supply via a 2k resistor to ps -on
    then measure voltage on 12v supply
    all 6 pins of 12v supply are connected together so are you saying the 12v supply should rise up to 18v?
  • kew1701
    Philips taw6205 ambilight speaker STM32 mcu dead
    by kew1701
    Resolved dead cap which burned mcu(stm32f091rct6) ,between vss and vdd on desoldered mcu is short 5.8oh,is there a way to obtain firmware from it.i have firmware,but i thing this is for wifi/bt board phorus 5 which is on top of amp board(here lies dead mcu)...my stm32 flasher is on the way....
    04-09-2025, 03:59 AM
  • Rubenlily
    Philips 50PUS6503 - dead panel? Picture
    by Rubenlily
    Hey,
    I gave up on my last TV and got a new one to try.
    Only vertical lines. Sound is OK. Screen is black with a few white lines until I change channel, then these colors gradually starts filling up the screen.
    Is this fixable in any way or should I just give up on this one too?...
    08-21-2023, 01:07 PM
  • double_DD
    How can I be sure that my EC chip is dead?
    by double_DD
    As the title suggests, how can I be sure that my EC chip is really dead?
    I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
    Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
    03-12-2025, 07:47 AM
  • G33RT
    Philips 8200 series 65PUS8204/12 stuck at Philips Logo
    by G33RT
    Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
    It does power up when pressing the power button.
    I already try the power button while plugin the plug with no result.
    Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
    Could this be an PSU or eMMC issue ?
    07-19-2025, 03:43 AM
  • vikivng
    PHILIPS 40PFL7007 TV DEAD. D501 testing SHORT on DMM
    by vikivng
    Hi guys pls can someone help with this set..
    Tv doesnt not power on.
    No standby light.
    There is a burn mark by the leg of D501 diode.
    The diode tests short in both directions.
    I have been reading this usually means the diode is faulty? As normally would be open.
    I have not yet taken voltages since this is obviously short I would like to replace it.
    Can someone help me with a substitute for this diode since it seems not to be the standard type?...
    08-22-2022, 10:51 AM
