Sony KDL-40EX403 Stuck on Standby Fixed
  • Ukdigger
    • May 2020
    • 121
    • England
    This TV was stuck on standby, all the voltages tested ok. I Googled the problem
    and found that the ambient sensor could be causing the problem. I disconnected the two leads going to the ambient sensor (on the infra red remote sensor board) and the TV worked with no problems.
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    Re: Sony KDL-40EX403 Stuck on Standby Fixed
    Nice fix thanks for sharing.
    • Ukdigger
      • May 2020
      • 121
      • England
      Just found my notes, I disconnect wires (11,12) on the connector to the HLR board. I just used a pin to pop out the wires from the connector block
      • brithepi2k
        Sony KD-65XE8596 no standby light
        by brithepi2k
        I’ve got a Sony KD-65XE8596 here that has no standby light coming on. I’ve tested the power board with the test meter, the TV needs 3.4 for the standby but only getting 2.4. Anything that I can change/check on the board to get it working? Pictures of the board are included.
        cheers...
        09-06-2025, 02:22 PM
      • sigmeyer
        Sony KDL40R470A Stuck on standby , red light
        by sigmeyer
        So this is the second tv this week that comes in with the same problem. The power supply looks good , There is a solid 3.3v stand by voltage. The tv doesnt react to button presses or from the remote. The Processor gets slightly warm and thats about it.
        My question to other veterans on this forum is , what is more likely to be bad , the processor , or the memory chip. in this case there is a toshiba tsop48 fk4924 , tc58dvm92astaj0 . At the moment i do not have my hands on the programer but i will be buying it in the following weeks. i Can see that on 90% of tv boards there is a jack for...
        06-13-2023, 07:21 AM
      • lepak06
        TV LED 4K Selecline 65S18 ( T.MS3458.U801) stuck in Standby mode
        by lepak06
        Hello
        I have an TV Led 4K Selecline 65s18 with mainboard T.MS3458.U801
        The TV is faulty with stuck in Standby RED LED. Can't power the TV.
        Before this problem , the TV stuck the picture with artefact , i unplug the AC cable and since the tv is stuck in standby .
        All voltage are OK on PSU and main board for regulator. I tried flash firmware 25Q64 with many dumps
        But the voltage on power button is 0.6V not 3.3V. When i press power button the voltage up to 0V. I tried to add 5V with Power Supply on 5V_STB and 3.3V on Power...
        01-12-2023, 01:43 AM
      • rabbituk
        Sony HCD BX7700dbi CMT flashing standby
        by rabbituk
        I have got a Sony HCD-BX7700dbi that isn't worth a lot but I'm keen to learn how to repair and would appreciate some help with my train of thought. The protection circuit is kicking in and the standby light is blinking. It goes into protection mode within a second of powering it on.
        So far the relay on the power board that enables the main transformer clicks on and then off when powering on the unit. Looking at the schematics, the permanently enabled power rail called 'unreg sub' provides about 13.5VDC. Where the power comes into the main board on connector CN303, there is a diode...
        02-11-2025, 05:05 PM
      • toty79
        Hisense LTDN50K220WSEU stuck in standby
        by toty79
        Hello to all friends of the forum and well found, here I am asking for your help and sorry for my translated English.
        As per Hisense tv title LTDN50K220WSEU stuck in standby
        PSU rsag.820.5687 HLL 4855WF
        Main rsag 7.820.5842
        I enclose the psu diagram, after the first routine checks I find myself with a regular standby voltage of 3.3v blue light on steady when the power button is pressed nothing happens, psu disassembled and bench checked ... forced ignition by sending a signal 3 , 3v on the SW and PWM2 pins the psu turns on and delivers all the voltages...
        05-01-2022, 04:39 PM
