If a screen does this...
  • el3ctroded
    • Nov 2008
    • 198
    Here are two images of screens and what they are doing. What commonly causes these two types of things? They are both LCDs.
    The one with the white vertical line works fine otherwise.
    I don't own either of these TVs, just doing research on common problems people are reporting.
    Seems to me the one with vertical and horizontal lines is going to be main board, tcon, or panel?
    And the vertical white line will be...?
    Thanks!
  • PlainBill
    • Feb 2009
    • 7034
    Re: If a screen does this...
    Thanks!
    I'm attempting to channel Wizard, but I recall he said the vertical line indicates a dead driver on the panel. These are bonded to the panel ribbon cables, and unreplaceable.
    PlainBill
    • el3ctroded
      • Nov 2008
      • 198
      You mean the vertical white line, right? That's a pity.
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        and the one on the right is busted.
        • el3ctroded
          • Nov 2008
          • 198
          Busted how? Broken panel? Is that what LCDs often do when broken?
          • kc8adu
            • Nov 2003
            • 8832
            • U.S.A!
            see the blotch at the top on the heavy vertical bar?that is where it was hit.
            • Wizard
              • Mar 2008
              • 2296
              These photos shown here is bad drivers or something hit the LCD panel and damaged it. Unfortunately.
              Cheers, Wizard
              • cadiman
                • Mar 2010
                • 397
                I have several broken lcd tvs( panels ) and none of them look like either of these. I think a little more info here is needed. Internal or external?
                • almarhum
                  To fix laptop screen vertical line by working on its EDP cable
                  by almarhum
                  Has one here really gone through fixing laptop screen vertical line(s) by repairing/replacing its Embedded DisplayPort (EDP) cable, so would recount and share the complete steps of the process here now?
                  As most, if not all, believe the laptop screen vertical line(s) caused by defective Embedded DisplayPort (EDP) cable which slipped and passed through either laptop screen hinge but post here is asking help to elaborate definitively the useful, real knowledge of repairing in the most complete, correct way, esp. can decide/determine whether the cable can still be fixed or must be re...
                  05-07-2024, 02:12 PM
                • Daren87
                  Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                  by Daren87
                  I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                  08-13-2023, 03:25 PM
                • harp
                  White screen repairs
                  by harp
                  To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
                  Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
                  On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
                  05-13-2024, 03:43 AM
                • kca
                  by kca
                  Hello all ~
                  08-31-2025, 06:38 AM
                • JohnML1975
                  Soniq S55V14B-AU White vertical bar middle of screen
                  by JohnML1975
                  Hello Forum Team
                  Have this issue
                  Found signs of burning or some sort of build up of something on the flex cables that go between T-CON and screen buffer boards
                  Tried cleaning the flex cables and the ports where they go in but the problem remains
                  Swapped the flex cables but problem remains
                  Cannot see anything burnt on the main board or the t-con board
                  Checked for shorted capacitors on the buffer board and did not find anything
                  Am going to try using sticky tape on one of the flex cables to and see if i can resolve
                  09-27-2025, 02:55 PM
