To fix laptop screen vertical line by working on its EDP cable
  • almarhum
    • May 2024
    • Indonesia
    Has one here really gone through fixing laptop screen vertical line(s) by repairing/replacing its Embedded DisplayPort (EDP) cable, so would recount and share the complete steps of the process here now?
    As most, if not all, believe the laptop screen vertical line(s) caused by defective Embedded DisplayPort (EDP) cable which slipped and passed through either laptop screen hinge but post here is asking help to elaborate definitively the useful, real knowledge of repairing in the most complete, correct way, esp. can decide/determine whether the cable can still be fixed or must be replaced​
  • Diah
    • Feb 2013
    • 6557
    this is common with DELL laptop ... and being fixed for long time specialty model from years 2005--2011 large size screen
    • howardc64
      by howardc64
      Problem
      08-04-2024, 10:36 PM
    • VcemPzd
      Black screen Lenovo legion 5 pro 16ACH6H gaming laptop
      by VcemPzd
      Hello everyone !
      My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappeared I bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
      04-28-2025, 10:14 AM
    • Stunt
      Hp Laptop Stuck on Hp protected by hp sure start screen
      by Stunt
      Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
      I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
      I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
      Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
      screen that's it and stuck there. I left it until the following day and i still...
      09-02-2025, 01:51 PM
    • jean luc ferre
      laptop hp g72 b52sf screen problems
      by jean luc ferre
      on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
      the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
      i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
      i don't understand the reasons of the white stripe at the bottom of the screen below the task...
      06-07-2025, 03:27 PM
    • Stanley1843
      by Stanley1843
      06-29-2024, 11:54 AM
