Hisense 65H6570F Logo shows then turns off
  • USmechS
    • Apr 2022
    • 27
    Hello everybody,
    I had this Hisense TV since November 2019 (Bestbuy Blackfriday special). Couple of nights ago my dad turned it off normally. In the morning it does turn on, shows the Hisense logo, then the LED light flashes and it turns off. It remains in the same state.
    Things I have done:
    A. Plug it off and on.
    B. Plug it off, pushing the power button for up to 2 minutes, plug it in.
    C. Contacted the customer service, They sent me a firmware update, with the file name:
    upgrade_loader_no_tvcertificate.pkg
    The zip file has this name, if it is of any value:
    65H6570F_65A6101EU_L0424
    and these instructions:
    1. Follow the link above and download the file, [ ].zip. The file will be compressed,
    so using a built-in or downloaded (i.e. Winzip) unzipping software, extract all files.
    2. Locate the file .pkg. Copy and paste this file into an EMPTY FAT32 formatted USB Stick.
    a. Please ensure that NOTHING ELSE is on the USB, ONLY the.pkg file.
    b. DO NOT CHANGE OR RENAME THE .pkg FILE!
    3. Safely Eject the USB from your PC by right clicking on the USB(on your Desktop or in your My Computer)
    and selecting Eject , then unplug the USB from your PC.
    4. Turn OFF the TV.
    5. Plug the USB in to the TV s top most USB port(located on the rear of the TV).
    6. Please unplug TV from wall and plug back in.
    7. Press and hold the POWER button on the TV Remote Control,
    once you see Software updating appear on the screen you may RELEASE the power button.
    8. Please wait and let the Software Update process finish.
    a. The Software Update Process will complete without any further user interaction.
    b. The Process should take between 5-8 minutes.
    c. Please DO NOT turn OFF the TV during this process.
    9. When the update is complete, the Software updating Screen will disappear
    and the TV will come up as it normally does.
    10. Remove the USB from the back of the TV.
    I have followed it, the stage 7 does not happen. The TV shows flashing purple line sections on the left of the screen. It turns off and on doing the same thing as long as I hold the power button.
    D. I have kept pushing the power button on the remote as I plug it in, no difference.
    E. Put the USB drive on the other port, no difference.
    F. Contacted customer service again, they said change both the power board and the logic board.
    I have access to a multimeter, soldering iron, and possibly an oscilloscope. I can do some electronics repairs but nothing too crazy. I appreciate any and all suggestions.
    Thank y'all,
    Manny
  • Diah
    • Feb 2013
    • 6541
    Re: Hisense 65H6570F Logo shows then turns off
    Originally posted by USmechS
    Hello everybody,
    rename the file from ( upgrade_loader_no_tvcertificate.pkg ) to upgrade_loader.pkg and start with point 7.
    be sure yours PC showing the file extension to avoid written double .pkg.pkg
    • USmechS
      • Apr 2022
      • 27
      Thanks Diah, I will try it tonight and report the outcome
      • dskall
        • Oct 2016
        • 2905
        • usa
        Also, I believe the usb needs to be 4g max.
        • USmechS
          • Apr 2022
          • 27
          It did not work Diah. It is the same as it was before.
          I do not have a 4GB USB drive to test your suggestion, dskall.
          • Diah
            • Feb 2013
            • 6541
            the rename supject of the file must be 100 done. what kind of stick you have ??? stick should be MBR mode
            shoe me the properties of yours usb stick and the file inside it
            • Diah
              • Feb 2013
              • 6541
              if the USB stick are MBR mode formasted FAT32 and the file on it in name upgrade_loader.pkg and it didnt work to have screen of upgrade prosees... mean yours TV went to shut down as it had HW issue 100% are led backlight, one or more are defect.
              with hisense vidaa no problem with the usb drive size, i have 64Gb MBR mode Fat32 many hisense firmware for diffrent model on it, the one i need just to rename it to upgrade_loader.pkg
              • USmechS
                • Apr 2022
                • 27
                It is in MBR mode. It is 8GB, I think it is USB 1.0, definitely not USB 3.0.
                • USmechS
                  • Apr 2022
                  • 27
                  The Hisense Logo shows up, and the backlight turns on (both for a few seconds), is it an LED backlight issue or logic board issue?
                  • Diah
                    • Feb 2013
                    • 6541
                    PQI what this mean ??? are you using windows
                    BL come for just 1-2 second didnt mean they are healthy. its BL issue not Mainboards at all.
                    • USmechS
                      • Apr 2022
                      • 27
                      PQI is the name of the manufacturer. I am using Windows.
                      How do I check if the BL is the problem?
                      • USmechS
                        • Apr 2022
                        • 27
                        I had a Samsung TV where BL LEDs died. It shows picture but no backlight at all. If I put a flash light to it I can see picture. That has been my experience with BL. This is why I am asking.
                        • Diah
                          • Feb 2013
                          • 6541
                          hold on.... yours Hisense are android system.. not vidaa one... try inter recovery mode if you did and it show on the screen mean urs BL ok. then you need to clear cashe and then do factory reset
                          • USmechS
                            • Apr 2022
                            • 27
                            Yes, it is android TV. How do I do inter recovery mode ?
                            BTW, there is no reset pin or hole or anything.
                            • USmechS
                              • Apr 2022
                              • 27
                              There is only a physical power button
                              • Diah
                                • Feb 2013
                                • 6541
                                every sytem of TV has had his own way to handel HW failure.
                                if all what i worte didnt help you need to open the cover and provide good pictures focused high res on the power boards and the BL socket, and any voltage print layot u could fine on PCB
                                • Diah
                                  • Feb 2013
                                  • 6541
                                  you should have joystik not only one button.. mean it can be pressed and push down or up or to side..
                                  • USmechS
                                    • Apr 2022
                                    • 27
                                    You are helping immensely. How do I do inter recovery mode ?
                                    • USmechS
                                      • Apr 2022
                                      • 27
                                      It just does not have any joystick, or any other button. I have checked all parts of it.
                                        • 12328
                                        • U.S.
                                        yep, time to take the back cover off and give it a good looking over and voltage testing, seems like backlight issue.
                                        • taslan
                                          Surface 7 Pro wont boot, shows Logo and immediately turns off
                                          by taslan
                                          as stated in the title, my surface 7 pro wont boot anymore.
                                          When i press the power button it shows the square windows logo for a second and immediately turtns off again.
                                          I dont even have a chance to get into bios or boot from usb.
                                          While trying to find help online it was suggested to look for help/repair here on badcaps and it might be a ME Region corruption in bios.
                                          I dont know what that is exactly, but i never tinkered with the bios or windows in terms of hacking/patching etc.
                                          Bought it directly from microsoft and used it now and then and only...
                                          01-16-2025, 01:25 AM
                                        • frannyjunk
                                          Hisense 40H4F no backlight but turns off after splash screen
                                          by frannyjunk
                                          So I have this Hisense tv where the backlight does not come on. But when it is turned on, when I shine a flashlight on the screen, I can clearly see the splash screen then it turns off. I looked at the mainboard and was expecting to see bulged capacitors, but they all look fine. I unplugged the backlight from the mainboard, and get the same symptoms (i.e. no backlight, dark splash screen then just a black screen). Is this just a backlight issues? Do Hisense tvs turn off by itself if the backlights are unplugged or are bad? Or is this a mainboard issue?
                                          TIA.
                                          09-24-2025, 10:59 AM
                                        • m1ch43lzm
                                          Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
                                          by m1ch43lzm
                                          Hi everyone
                                          I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
                                          Programmer models: XGecu TL866II Plus / T48 / T56 / T76
                                          Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
                                          There's also an extra OTP Secu.R...
                                          09-06-2025, 05:47 PM
                                        • IIOSOH
                                          46PFL5507K/12 - Shows a "Hourglass" logo then turns off the backlight - No sound
                                          by IIOSOH
                                          I'm trying to fix a Philips TV [46PFL5507K/12] for a friend. A few seconds after turning it "ON" a hourglass appears and stays on the screen for around a second, then the screen goes black again, there is no picture nor sound when i connect via HDMI to my PC.
                                          I've opened it up and took a few measurements, but i can't seem to find the correct schematic for this exact model. The official service manual has detailed schematics and info for pretty much every other TV from the series but just some generic information about this exact part number so i measured...
                                          04-02-2022, 12:43 PM
                                        • dragometin
                                          Hitachi 40HYC42
                                          by dragometin
                                          TV Model: Hitachi 40HYC42
                                          Power Supply: 17IPS71
                                          MainBoard: 17MB95M
                                          Panel: VES400UNDS-2D-NO3
                                          When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
                                          I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
                                          Is there any variants on 17IPS71 power supply's?
                                          UART output pins 10 and 12 on scart connector:
                                          Code:
                                          12:24:04.595
                                          08-08-2024, 05:53 AM
