Hisense 65H6570F Logo shows then turns off
  • USmechS
    • Apr 2022
    • 27
    Re: Hisense 65H6570F Logo shows then turns off
    If it is any help, The power LED light on the tv starts as ON when the TV os OFF, when I turn the TV ON, the power LED light turns OFF, then flashes 2 times before the TV turns off and the power LED light goes back to ON. It tries to do the 3rd flash, but in the middle of it it TV turns OFF and power LED light goes back to ON.
    • USmechS
      • Apr 2022
      • 27
      These are the pictures of the boards.
      • USmechS
        • Apr 2022
        • 27
        I do not have any instrument to check the voltages now, That need to be tomorrow. I appreciate it if you can walk me through how and where I need to check for various issues (BL, Logic board, Power board, etc.)
        • Diah
          • Feb 2013
          • 6550
          please don't do any things at this time.. could be dskall thought are correct... however hisense said up to 16Gb but use 4Gb or less will be better with format Fat32 MBR. and insert it at USB V2 (black ) port in the tv not the ( blue ) one V3.
          also because yours TV Android which you didn't mentioned about at yours first post... i went in method of vidaa system. so no need to rename.. and use the exact instruction the service send to you..
          if the tv didn't accept the firmware after this change.. it could be yours android version the last one.. just contact service and they will send you another recovery firmware.
          this why we encourage all when the post to write full information on the tv. as small hiding info will drive us to wrong direction.
          • Diah
            • Feb 2013
            • 6550
            for recovery try TV plunged out from wall.. press and keep press power on the TV after first 5 second plug the tv in wall and keep pressing power on TV 15-20 second until you have recovery on screen.. this method used for android TV which it had only power button on it.
            you may try it several time
            • USmechS
              • Apr 2022
              • 27
              I apologize for not mentioning the android TV part.
              I tried a 2GB fresh formated FAT32 MBR mode. Same results. BL on one power LED flash no picture, restart, BL on one power LED flash, restart, BL on some purple line sections flashing and moving up and down one power LED flash, repeat.
              • USmechS
                • Apr 2022
                • 27
                This did not work, no picture or BL or power LED flash or anything. tried multiple times, both with the TV power button (remote batteries out) and with remote. Tried holding the TV power button after plugging the TV too, the original issue of logo happens. Tried holding the remote power button after turning the TV on, same issue.
                • USmechS
                  • Apr 2022
                  • 27
                  Last night when I took the cover off, I unplugged the BL from power board, no change in the power LED flashes. Later I unplugged the lcd ribbon cables, no difference either.
                  • Diah
                    • Feb 2013
                    • 6550
                    at this point dont do SW with USB untill we be sure we dont have HW problem.
                    lets try to remove load from the MB, disconnect the wifi/BT module socket from it and turn on see any different, if no change
                    we need to see the print chart of the BL socket wiring.. on the top are not clear just they put P1 N1/ P2 N2. look from the downside of the powerboardss and show me here the circuit of the BL. also be sure the socket solder are fine and tell howmany wires you have on the socket.
                    • USmechS
                      • Apr 2022
                      • 27
                      1. I removed both the BT/wifi module and the speakers, no difference.
                      2. I only removed the BT/wifi module, no difference
                      3. There is no voltage charts. Pictures of the top and bottom of the powerboard is attached. There are 4 wires in the BL socket.
                      • USmechS
                        • Apr 2022
                        • 27
                        I think each positive is 120 V 900mA based on the output of the board written in the middle picture.
                        • Diah
                          • Feb 2013
                          • 6550
                          good then its easy for you to measure the voltage at start up.
                          put your DMM on 200V DC or more. P1 N1 are one groupe of P Positive ( DMM red color probe) N Negative (DMM black color probe )
                          same way to P2 N2 write down the voltage your DMM register at starting up the tv.
                          • USmechS
                            • Apr 2022
                            • 27
                            Without the BL socket on:
                            XP905 (the one on top) :197V
                            XP902 (the one on bottom): 197V
                            Both reduce when the TV turns itself off
                            With the BL socket ON:
                            XP905 (the one on top) :136V
                            XP902 (the one on bottom): 87V
                            • Diah
                              • Feb 2013
                              • 6550
                              as i stated at post #10 you have LED BL fault..
                              • USmechS
                                • Apr 2022
                                • 27
                                Thank you for all the help Diah. If it is BL LED issue, I am not comfortable removing all the panels to get to the LEDs. Is there anything I can do short of removing panels?
                                • dskall
                                  • Oct 2016
                                  • 2905
                                  • usa
                                  #36
                                  I guess you could drill a big hole through the back and put a spotlight in.
                                  • USmechS
                                    • Apr 2022
                                    • 27
                                    If it would work I'd do it. LOL
                                    • USmechS
                                      • Apr 2022
                                      • 27
                                      Is it at all possible that the difference in voltage is due to lower port having less LEDs to drive? 86V is very close to being 2/3 of 136V. If the TV has 5 LED strips, and the top port driving 3 of them and the bottom 2 of them, 136-86 split is not awful.
                                      Again, I am wishing this not be a BL issue since I cannot realistically fix that.
                                      • dskall
                                        • Oct 2016
                                        • 2905
                                        • usa
                                        #39
                                        Both go to 197v. Wishing it weren't so won't change things. I don't know anyone who really likes change backlights on tv's, especially the big one's. I did 65" not to long ago. Held my breath and hoped cheap harbor freight suction cups would hold.
                                        You can always take it to repair shop.
                                        • USmechS
                                          • Apr 2022
                                          • 27
                                          The repair shop asks for around 200$ if it has to change backlight, which is not unfair. But I may get a new TV and sell this one as is and maybe spend in that ballpark.
                                          I have called the Hisense service again, The person I talked to was adamant it is not a BL issue, which I do not trust that much. He told me tier 2 may send me a new firmware or contact me. We'll see what happens.
                                          Can a LED tester give me readings that prove BL issue beyond doubt without opening up the panels?
                                          • taslan
                                            Surface 7 Pro wont boot, shows Logo and immediately turns off
                                            by taslan
                                            as stated in the title, my surface 7 pro wont boot anymore.
                                            When i press the power button it shows the square windows logo for a second and immediately turtns off again.
                                            I dont even have a chance to get into bios or boot from usb.
                                            While trying to find help online it was suggested to look for help/repair here on badcaps and it might be a ME Region corruption in bios.
                                            I dont know what that is exactly, but i never tinkered with the bios or windows in terms of hacking/patching etc.
                                            Bought it directly from microsoft and used it now and then and only...
                                            01-16-2025, 01:25 AM
                                          • frannyjunk
                                            Hisense 40H4F no backlight but turns off after splash screen
                                            by frannyjunk
                                            So I have this Hisense tv where the backlight does not come on. But when it is turned on, when I shine a flashlight on the screen, I can clearly see the splash screen then it turns off. I looked at the mainboard and was expecting to see bulged capacitors, but they all look fine. I unplugged the backlight from the mainboard, and get the same symptoms (i.e. no backlight, dark splash screen then just a black screen). Is this just a backlight issues? Do Hisense tvs turn off by itself if the backlights are unplugged or are bad? Or is this a mainboard issue?
                                            TIA.
                                            09-24-2025, 10:59 AM
                                          • m1ch43lzm
                                            Notice to users of XGecu TL866II Plus / T48 / T56 / T76 programmers regarding BIOS backup file size
                                            by m1ch43lzm
                                            Hi everyone
                                            I noticed on the Xgpro software the BIOS backup files have extra bytes at the end when reading some chips, this is because the Xgpro software also reads the OTP region of those flash chips, and by default will append that region to the saved file
                                            Programmer models: XGecu TL866II Plus / T48 / T56 / T76
                                            Example: GD25LQ128D (1.8V), IC size is listed as 0x1000000 Bytes (16777216 bytes) + 0xC00 bytes, those extra 0xC00 bytes will be appended to the end of the saved file by default, resulting in a file size of 16780288 bytes
                                            There's also an extra OTP Secu.R...
                                            09-06-2025, 05:47 PM
                                          • IIOSOH
                                            46PFL5507K/12 - Shows a "Hourglass" logo then turns off the backlight - No sound
                                            by IIOSOH
                                            I'm trying to fix a Philips TV [46PFL5507K/12] for a friend. A few seconds after turning it "ON" a hourglass appears and stays on the screen for around a second, then the screen goes black again, there is no picture nor sound when i connect via HDMI to my PC.
                                            I've opened it up and took a few measurements, but i can't seem to find the correct schematic for this exact model. The official service manual has detailed schematics and info for pretty much every other TV from the series but just some generic information about this exact part number so i measured...
                                            04-02-2022, 12:43 PM
                                          • dragometin
                                            Hitachi 40HYC42
                                            by dragometin
                                            TV Model: Hitachi 40HYC42
                                            Power Supply: 17IPS71
                                            MainBoard: 17MB95M
                                            Panel: VES400UNDS-2D-NO3
                                            When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
                                            I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
                                            Is there any variants on 17IPS71 power supply's?
                                            UART output pins 10 and 12 on scart connector:
                                            Code:
                                            12:24:04.595
                                            08-08-2024, 05:53 AM
