Sharp LED TV flashing green 2x per second - LC-70LE735X, DPS-222BP, RUNTKA857WJQZ
  • Diah
    • Feb 2013
    • 6449
    Re: Sharp LED TV flashing green 2x per second - LC-70LE735X, DPS-222BP, RUNTKA857WJQZ
    well it was working, then you messed with the mainboard connector, I think you tried to over-fix it, not good, maybe same as before re-check your work.
    No, he did BGA work of the MB main CPU using GAS Flame .. thought the BBQ smell reached me from Singapore..
    • nomoresonys
      • 12284
      • U.S.
      #122
      ok, I thought he meant there was something messed up after mainboard connector reflow.
      • beetle1303
        • Jul 2019
        • 279
        • Singapore
        #123
        According to @Tiah the MB never worked, and we try reviving it by backing in oven, and then with a butane torch since I don't have a heat gun... This might have killed it more than curing it.
        So re-soldering the PD connector on MB is just trying luck, and, no luck obvoiusly..
        • nomoresonys
          • 12284
          • U.S.
          #124
          ok, i get it now, lol, I like to verify powerboard and backlights first.
          • beetle1303
            • Jul 2019
            • 279
            • Singapore
            #125
            Hello again! Sourced a closest MB I can find without costing an arm..
            Plugged and powered up - red led flashing 1x, slowly.
            Tried all the forced restart procedures:
            1) CHN- n VOL- : no effect
            2) CHN+ n VOL- : no effect
            3) CHN- n VOL+ : no effect
            4) CHN+ n VOL+ : no effect
            5) INPUT n VOL- : no effect
            6) INPUT n VOL+ : no effect
            Red led remains slow flashing 1x.
            PD15 (BU+5) : 4.95V
            The rests (odd number pins) all 0V.
            Not sure if the new old MB faulty or not compatible, or is there other procedure after replacing the MB?
            • Diah
              • Feb 2013
              • 6449
              start with compare the wiring chart of the replament MB and original at the socket which connect to PCB from down side. to be sure PS_ON line and other are the same. also you have one socket more on the replacment & - one IC..
              at the end it sound the replament not related to yours Model.
              • beetle1303
                • Jul 2019
                • 279
                • Singapore
                #127
                Noted this MB is not the exact same model as mine, and didn't notice the one big IC missing.. It's was S$20+ vs the exact model that cost S$200+, so ya, no luck..
                The resale prices of this T is S$200-$500, so not planning to invest S$200+ for a MB..
                So, unless or until an exactly model MB comes along, this will be the end of road for this expedition.
                Thank you, Diah, Nomoresonys, and everyone for your coaching all the way.
                Have a pleasant time here in the forum.
                • Cemal Odabasioglu
                  MacBook Pro A1707 Motherboard Diagnostic Help – CD3215 heating and Fluctuating Rails
                  by Cemal Odabasioglu
                  I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
                  Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
                  Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
                  Observations...
                  01-14-2025, 03:54 PM
                • triplefour
                  ONN 100012588 Has fluctuating Voltage on PSU 12v
                  by triplefour
                  Hello all got another TV here im puzzled by. why cant they all be easy fixes that just need a little love and some tape???
                  anyway i go to this guys house to look at an ONN 100012588
                  this is my first time looking at one of these brand of TV's.
                  TBH i have low expectations because i see ONN as the cheap walmart brand that suddenly popped up selling the cheapest version of all kinds of tech things. and someone sent me a ONN flash drive with some data on it with some recordings they wanted me to check out and it immediately broke and corrupted the data and i was unable to...
                  09-14-2022, 07:41 PM
                • beetle1303
                  Wine Chiller - SMPS issue - fluctuating voltages
                  by beetle1303
                  My wine chiller, TECNO SW-126LCD, is semi-functional - it powers up, can set temperature, and chilled to the set temperature, and cuts off compressor, etc. It however runs very hot.
                  Upon taken out the PSU and did some basic check - 5V output to LCD panel buttons and display is stable, but there is no 12V output to LED lights, and fans.
                  Further checks found the secondary side voltage is fluctuating around 8-15V range, but the 7805 regulator seems ok and producing the stable 5V output.
                  Checking further on the primary side: Incoming line input to bridge...
                  09-04-2023, 10:33 AM
                • koby058
                  yoga9 3v3 5v fluctuating
                  by koby058
                  Hi
                  board model: NM-D992
                  type c remains on 5v. when i connect it the 3.3VALW and 5VALW fluctuating. can someone please help understand why?
                  main power rail voltage 13v
                  till now i have tried:
                  measured all coils resistance looks ok
                  replaced RT6585CGQW to a brand new one
                  replaced all mosfets for 3.3v regulator and the dual mosfet for 5v regulator
                  happen both on DC power and on battery
                  issue remains
                  video
                  schematic attached...
                  08-03-2025, 09:06 AM
                • madan1
                  DALI SUB E-12F class D, fluctuating power rail
                  by madan1
                  Good day everyone.
                  I have on the bench an amp board from DALI SUB E-12F. It is class D amp with a smps on the same board.
                  The issue is that it powers off way before the rated power is reached (the protection circuit kicks in). It has an independent standby power supply, which stays on after the main power supply is turned off via a relay on the primary side (thus there is no reason to believe that the protection is triggered from the smps IC on the primary side).
                  The normal value of the positive and negative power rails is +/- 43V.
                  The positive rail stays...
                  Today, 10:33 AM
