Sharp LED TV flashing green 2x per second - LC-70LE735X, DPS-222BP, RUNTKA857WJQZ
  • Diah
    • Feb 2013
    • 6449
    Re: Sharp LED TV flashing green 2x per second - LC-70LE735X, DPS-222BP, RUNTKA857WJQZ
    Originally posted by beetle1303
    But I am tester each of the 14 strips individually - should be able to lit up the 30 leds in it as I have tested it on older 30-led strip.
    I will retry in total darkness and see if what happen.
    *the link to MB you provide is quite expensive... I am searching of cheaper ones from China but they seems to be of different models.
    from the PCB design of LED section. it sound LED are 5-6V. so 30x6 180V. beside the ampere, tester show you 174V. and i do know of sure its very limited with currents.
    • nomoresonys
      • 12284
      • U.S.
      #82
      worth a try, from what I gather the lc and le just might be interchangeable, if it don't work you could resell it I guess.
      • nomoresonys
        • 12284
        • U.S.
        #83
        so according to that, it's looking like maybe one bad led per string then?
        • Diah
          • Feb 2013
          • 6449
          i don't think so, because he had MB issue, and this sharp when you force it on as he did.. will clear error at LED if exist and light them up even for short time or long time with just few strips.
          • nomoresonys
            • 12284
            • U.S.
            #85
            ok, yeah I thought there should be some sort of flash but wasn't sure.
            • beetle1303
              • Jul 2019
              • 279
              • Singapore
              #86
              I went ahead to order a closest model MB for replacement, arriving in 10-20 days. Hopefully it will turn on the PD pins for backlight, and fire-up all the led strips.
              Figure crossed!
              • beetle1303
                • Jul 2019
                • 279
                • Singapore
                #87
                I found this page from one of the link provided interesting and will be very useful if the replacement MB doesn't fire-up the backlight.
                • Diah
                  • Feb 2013
                  • 6449
                  all these are working at your PCB other wise you will not have 13 / 12V. only we didnt test the BL circuit because for me i cant figure it out where are the signal to turn it on,,, so i wrote let the MB do the job first,
                  can you follow the pathof OFL line and dimming one too from downside the PCB?
                  • lotas
                    • Jan 2016
                    • 4765
                    • Russia
                    #89
                    OFL is DIM, Try to run a PSU with backlight without a motherboard, there are 3 or 4 signals for on, 1kΩ resistor and 5v duty. (OFL for backlight too)
                    • Diah
                      • Feb 2013
                      • 6449
                      so now it clear.
                      to complete pcb to run as standalone
                      PD-15 (BU5V) ----- 14 PS_ON ( turn on UR13.2V )
                      PD-15 (BU5V) ----- 16 PNL_POW (turn on PNL12V )
                      PD-15 (BU5V) ----- 24 (STB) ( turn on BL_ on ) IC7700
                      PD-21 (OFL) = DIM (low / high )
                      • beetle1303
                        • Jul 2019
                        • 279
                        • Singapore
                        #91
                        so now it clear.
                        With jumper wires on:
                        PD Connector:
                        PD-1 (PNL12V) : 11.92V
                        PD-2 (PNL12V) : 11.92V
                        PD-3 (SGRN) : 0V
                        PD-4 (SGRN) : 0V
                        PD-5 (UR13.2V) : 13.05V
                        PD-6 (UR13.2V) : 13.05V
                        PD-7 (UR13.2V) : 13.05V
                        PD-8 (UR13.2V) : 13.05V
                        PD-9 (SGRN) : 0V
                        PD-10 (SGRN) : 0V
                        PD-11 (SGRN) : 0V
                        PD-12 (SGRN) : 0V
                        PD-13 (AC_DET) : 3.27V
                        PD-14 (PS_ON) : 4.95V
                        PD-15 (BU5V) : 4.95V
                        PD-16 (PNL_POW) : 4.58V
                        PD-17 (NC) : 0.04V
                        PD-18 (NC) : 0.04V
                        PD-19 (DIMMER) : 0V
                        PD-20 (NC) : 0.04V
                        PD-21 (OFL) : 0.14V
                        PD-22 (ERROR) : 0V
                        PD-23 (NC) : 0.04V
                        PD-24 (SBY) : 4.3V
                        But, still no backlight on...
                        I measured again the big cap all has 400V, but the feed to the 2 big transformers input pins all still showing 0V..
                        I did a bit of guess tracing - is transformer T7703 input voltage coming from the secondary side to provide output voltage in the primary side to feed the gate of the transistor Q7700 & Q7701? I traced the 400V from caps to left pin of Q7700, but no voltage on its center pin.
                        • lotas
                          • Jan 2016
                          • 4765
                          • Russia
                          #92
                          The PD-21 (OFL) must also be fed through a 1 kOm 5v resistor.
                          Yes, and all command pins must be supplied with 5v (standbay) through 1 kOm resistors.
                          • nomoresonys
                            • 12284
                            • U.S.
                            #93
                            I think you need to hook up the dim too, try it both ways maybe.
                            • nomoresonys
                              • 12284
                              • U.S.
                              #94
                              so 14, 16, 24, ofl, if no joy hook up dimm also.
                              • Diah
                                • Feb 2013
                                • 6449
                                OFL and dimmer should be feed too from PD-15 (BU5V) .
                                use 1K R to avoid the mosfet of BL circuit overload.
                                • beetle1303
                                  • Jul 2019
                                  • 279
                                  • Singapore
                                  #96
                                  *PD-15 (BU5V) ----- 21 OFL*
                                  PD Connector:
                                  PD-3 (SGRN) : 0V
                                  PD-4 (SGRN) : 0V
                                  PD-9 (SGRN) : 0V
                                  PD-10 (SGRN) : 0V
                                  PD-11 (SGRN) : 0V
                                  PD-12 (SGRN) : 0V
                                  PD-17 (NC) : 0.04V
                                  PD-18 (NC) : 0.04V
                                  PD-19 (DIMMER) : 0V
                                  PD-20 (NC) : 0.04V
                                  *PD-21 (OFL) : 0V*
                                  PD-22 (ERROR) : 0V
                                  PD-23 (NC) : 0.04V
                                  PD-24 (SBY) : 4.3V
                                  Now the screen Flash in split second then off.
                                  *BTW all jump wire with ~850ohm resistor - it this OK?
                                  • nomoresonys
                                    • 12284
                                    • U.S.
                                    #97
                                    ok, then i think it is what was suspected bad led/s.
                                    • nomoresonys
                                      • 12284
                                      • U.S.
                                      #98
                                      850 should be fine.
                                      • Diah
                                        • Feb 2013
                                        • 6449
                                        you forget dimmer
                                        • nomoresonys
                                          • 12284
                                          • U.S.
                                          #100
                                          add one on dimmer and see what you get. You beat me by a second Diah, that's what I get for using too many words.
                                          • Cemal Odabasioglu
                                            MacBook Pro A1707 Motherboard Diagnostic Help – CD3215 heating and Fluctuating Rails
                                            by Cemal Odabasioglu
                                            I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
                                            Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
                                            Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
                                            Observations...
                                            01-14-2025, 03:54 PM
                                          • triplefour
                                            ONN 100012588 Has fluctuating Voltage on PSU 12v
                                            by triplefour
                                            Hello all got another TV here im puzzled by. why cant they all be easy fixes that just need a little love and some tape???
                                            anyway i go to this guys house to look at an ONN 100012588
                                            this is my first time looking at one of these brand of TV's.
                                            TBH i have low expectations because i see ONN as the cheap walmart brand that suddenly popped up selling the cheapest version of all kinds of tech things. and someone sent me a ONN flash drive with some data on it with some recordings they wanted me to check out and it immediately broke and corrupted the data and i was unable to...
                                            09-14-2022, 07:41 PM
                                          • beetle1303
                                            Wine Chiller - SMPS issue - fluctuating voltages
                                            by beetle1303
                                            My wine chiller, TECNO SW-126LCD, is semi-functional - it powers up, can set temperature, and chilled to the set temperature, and cuts off compressor, etc. It however runs very hot.
                                            Upon taken out the PSU and did some basic check - 5V output to LCD panel buttons and display is stable, but there is no 12V output to LED lights, and fans.
                                            Further checks found the secondary side voltage is fluctuating around 8-15V range, but the 7805 regulator seems ok and producing the stable 5V output.
                                            Checking further on the primary side: Incoming line input to bridge...
                                            09-04-2023, 10:33 AM
                                          • koby058
                                            yoga9 3v3 5v fluctuating
                                            by koby058
                                            Hi
                                            board model: NM-D992
                                            type c remains on 5v. when i connect it the 3.3VALW and 5VALW fluctuating. can someone please help understand why?
                                            main power rail voltage 13v
                                            till now i have tried:
                                            measured all coils resistance looks ok
                                            replaced RT6585CGQW to a brand new one
                                            replaced all mosfets for 3.3v regulator and the dual mosfet for 5v regulator
                                            happen both on DC power and on battery
                                            issue remains
                                            video
                                            schematic attached...
                                            08-03-2025, 09:06 AM
                                          • madan1
                                            DALI SUB E-12F class D, fluctuating power rail
                                            by madan1
                                            Good day everyone.
                                            I have on the bench an amp board from DALI SUB E-12F. It is class D amp with a smps on the same board.
                                            The issue is that it powers off way before the rated power is reached (the protection circuit kicks in). It has an independent standby power supply, which stays on after the main power supply is turned off via a relay on the primary side (thus there is no reason to believe that the protection is triggered from the smps IC on the primary side).
                                            The normal value of the positive and negative power rails is +/- 43V.
                                            The positive rail stays...
                                            Today, 10:33 AM
