Sharp LED TV flashing green 2x per second - LC-70LE735X, DPS-222BP, RUNTKA857WJQZ
Re: Sharp LED TV flashing green 2x per second - LC-70LE735X, DPS-222BP, RUNTKA857WJQZ
ok, I thought he meant there was something messed up after mainboard connector reflow.Comment
According to @Tiah the MB never worked, and we try reviving it by backing in oven, and then with a butane torch since I don't have a heat gun... This might have killed it more than curing it.
So re-soldering the PD connector on MB is just trying luck, and, no luck obvoiusly..Comment
ok, i get it now, lol, I like to verify powerboard and backlights first.Comment
Hello again! Sourced a closest MB I can find without costing an arm..
Plugged and powered up - red led flashing 1x, slowly.
Tried all the forced restart procedures:
1) CHN- n VOL- : no effect
2) CHN+ n VOL- : no effect
3) CHN- n VOL+ : no effect
4) CHN+ n VOL+ : no effect
5) INPUT n VOL- : no effect
6) INPUT n VOL+ : no effect
Red led remains slow flashing 1x.
PD15 (BU+5) : 4.95V
The rests (odd number pins) all 0V.
Not sure if the new old MB faulty or not compatible, or is there other procedure after replacing the MB?Last edited by beetle1303; 05-20-2022, 02:03 AM.Comment
start with compare the wiring chart of the replament MB and original at the socket which connect to PCB from down side. to be sure PS_ON line and other are the same. also you have one socket more on the replacment & - one IC..
at the end it sound the replament not related to yours Model.Comment
Noted this MB is not the exact same model as mine, and didn't notice the one big IC missing.. It's was S$20+ vs the exact model that cost S$200+, so ya, no luck..
The resale prices of this T is S$200-$500, so not planning to invest S$200+ for a MB..
So, unless or until an exactly model MB comes along, this will be the end of road for this expedition.
Thank you, Diah, Nomoresonys, and everyone for your coaching all the way.
Have a pleasant time here in the forum.Comment
I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
Observations... -
by triplefourHello all
got another TV here im puzzled by. why cant they all be easy fixes that just need a little love and some tape???
anyway i go to this guys house to look at an ONN 100012588
this is my first time looking at one of these brand of TV's.
TBH i have low expectations because i see ONN as the cheap walmart brand that suddenly popped up selling the cheapest version of all kinds of tech things. and someone sent me a ONN flash drive with some data on it with some recordings they wanted me to check out and it immediately broke and corrupted the data and i was unable to... -
by beetle1303My wine chiller, TECNO SW-126LCD, is semi-functional - it powers up, can set temperature, and chilled to the set temperature, and cuts off compressor, etc. It however runs very hot.
Upon taken out the PSU and did some basic check - 5V output to LCD panel buttons and display is stable, but there is no 12V output to LED lights, and fans.
Further checks found the secondary side voltage is fluctuating around 8-15V range, but the 7805 regulator seems ok and producing the stable 5V output.
Checking further on the primary side: Incoming line input to bridge... -
by koby058Hi
board model: NM-D992
type c remains on 5v. when i connect it the 3.3VALW and 5VALW fluctuating. can someone please help understand why?
main power rail voltage 13v
till now i have tried:
measured all coils resistance looks ok
replaced RT6585CGQW to a brand new one
replaced all mosfets for 3.3v regulator and the dual mosfet for 5v regulator
happen both on DC power and on battery
issue remains
video
schematic attached... -
by madan1Good day everyone.
I have on the bench an amp board from DALI SUB E-12F. It is class D amp with a smps on the same board.
The issue is that it powers off way before the rated power is reached (the protection circuit kicks in). It has an independent standby power supply, which stays on after the main power supply is turned off via a relay on the primary side (thus there is no reason to believe that the protection is triggered from the smps IC on the primary side).
The normal value of the positive and negative power rails is +/- 43V.
The positive rail stays...-
- Loading...
