Sharp LED TV flashing green 2x per second - LC-70LE735X, DPS-222BP, RUNTKA857WJQZ
  • beetle1303
    • Jul 2019
    • 279
    • Singapore
    Sharp TV flashing green light 2x per second at constant rate. Various reset methods do not have any effect on it. Search here and found flashing green 2x per second indicate bad power supply, which I am quite certain now.
    I am seeking help with basic trouble shooting to find the short-circuit on the secondary side that I believe is the cause:
    The main PD connector:
    PD-1 (PNL12V) : 0.02V
    PD-2 (PNL12V) : 0.02V (fluctuating)
    PD-3 (SGRN) : 0V
    PD-4 (SGRN) : 0V
    PD-5 (UR13.2V) : 0.05V (fluctuating)
    PD-6 (UR13.2V) : 0.05V (fluctuating)
    PD-7 (UR13.2V) : 0.05V (fluctuating)
    PD-8 (UR13.2V) : 0.05V (fluctuating)
    PD-9 (SGRN) : 0V
    PD-10 (SGRN) : 0V
    PD-11 (SGRN) : 0V
    PD-12 (SGRN) : 0V
    PD-13 (AC_DET) : 2.5V (fluctuating widely)
    PD-14 (PS_ON) : 2.5V (fluctuating)
    PD-15 (BU5V) : 3V (fluctuating widely)
    PD-16 (PNL_POW) : 0.1V
    PD-17 (NC) : 0V
    PD-18 (NC) : 0V
    PD-19 (DIMMER) : 0V
    PD-20 (NC) : 0V
    PD-21 (OFL) : 0V
    PD-22 (ERROR) : 0.05V (fluctuating)
    PD-23 (NC) : 0V
    PD-24 (SBY) : 0V
    3x Opto-couplers input: 2.5V (fluctuating widely)
    3x Opto-couplers output: 2.5V (fluctuating widely)
    Searched here and learned that fluctuating output voltages and feedback circuitry generally means shorted components causing PWM chip to power-cycling up and down..
    If this is the case - need help to find the short(s).
    I have tested all the capacitors, diode and resistors around the PD connector, all seems to be normal reading on and off circuit.
    What else and where else do I start?
  • Diah
    • Feb 2013
    • 6449
    Re: Sharp LED TV flashing green 2x per second - LC-70LE735X, DPS-222BP, RUNTKA857WJQZ
    [QUOTE=beetle1303;
    [/QUOTE]
    run the PCB as stand alone... with out any connect to it... it sound the short outside the PCB
    • beetle1303
      • Jul 2019
      • 279
      • Singapore
      Originally tested with mainboard connected, LED strips not connected.
      Wow @Diah!!
      This is power supply stand-alone:
      PD-1 (PNL12V) : 0V
      PD-2 (PNL12V) : 0V
      PD-3 (SGRN) : 0V
      PD-4 (SGRN) : 0V
      PD-5 (UR13.2V) : 0V
      PD-6 (UR13.2V) : 0V
      PD-7 (UR13.2V) : 0V
      PD-8 (UR13.2V) : 0V
      PD-9 (SGRN) : 0V
      PD-10 (SGRN) : 0V
      PD-11 (SGRN) : 0V
      PD-12 (SGRN) : 0V
      PD-13 (AC_DET) : 0V
      PD-14 (PS_ON) : 0V
      PD-15 (BU5V) : 4.95V
      PD-17 (NC) : 0V
      PD-18 (NC) : 0V
      PD-19 (DIMMER) : 0V
      PD-20 (NC) : 0V
      PD-21 (OFL) : 0V
      PD-22 (ERROR) : 0.08V
      PD-23 (NC) : 0V
      PD-24 (SBY) : 0V
      Opto-couplers 1: input: 1.03V / output: 0.38-042V
      Opto-couplers 2: input: 0V / output: 11.05V
      Opto-couplers 1: input: 0V / output: 0.14V
      So confirmed the short(s) in the mainboard? If so is it possible to attempt tracing it on the mainboard?
      • Diah
        • Feb 2013
        • 6449
        Wow @Diah!!
        you need feed the PCB PS_ON pin from the V. you have at the socket present as STB ( (BU5V) : 4.95V ) then this will be stand alone. runing the PCB with out LED BL and MB
        • beetle1303
          • Jul 2019
          • 279
          • Singapore
          Is it safe to just jump PD15 to PD-14? or must have a ??ohm resistor in between?
          • Diah
            • Feb 2013
            • 6449
            R considered just in case people missed the pin No. so ab to you.
            • beetle1303
              • Jul 2019
              • 279
              • Singapore
              Jumped PD-15 to PD-14:
              This is power supply stand-alone, without any connection:
              PD-1 (PNL12V) : 0.01V
              PD-2 (PNL12V) : 0.01V
              PD-3 (SGRN) : 0.01V
              PD-4 (SGRN) : 0.01V
              PD-5 (UR13.2V) : 13.05V
              PD-6 (UR13.2V) : 13.05V
              PD-7 (UR13.2V) : 13.05V
              PD-8 (UR13.2V) : 13.05V
              PD-9 (SGRN) : 0.01V
              PD-10 (SGRN) : 0.01V
              PD-11 (SGRN) : 0.01V
              PD-12 (SGRN) : 0.01V
              PD-13 (AC_DET) : 3.27V
              PD-14 (PS_ON) : 4.95V
              PD-16 (PNL_POW) : 0.11V
              PD-17 (NC) : 0V
              PD-18 (NC) : 0V
              PD-19 (DIMMER) : 0V
              PD-20 (NC) : 0V
              PD-21 (OFL) : 0V
              PD-22 (ERROR) : 0.12V
              PD-23 (NC) : 0V
              PD-24 (SBY) : 0.1V
              Opto-couplers 1: input: 0.99V / output: 2.78V
              Opto-couplers 2: input: 1.08V / output: 0.14V
              Opto-couplers 3: input: 0.15V / output: 0.84V
              • nomoresonys
                • 12284
                • U.S.
                check D7951 diode.
                • beetle1303
                  • Jul 2019
                  • 279
                  • Singapore
                  check D7951 diode.
                  D7951 diode:
                  In-circuit: forward: 318 reverse: 1568
                  Off-circuit: forward 310 reverse: open
                  • Diah
                    • Feb 2013
                    • 6449
                    PD-3 (SGRN) : 0.01V
                    PD-4 (SGRN) : 0.01V
                    PD-9 (SGRN) : 0.01V
                    PD-17 (NC) : 0V
                    PD-18 (NC) : 0V
                    PD-19 (DIMMER) : 0V
                    PD-20 (NC) : 0V
                    PD-21 (OFL) : 0V
                    PD-23 (NC) : 0V
                    PD-24 (SBY) : 0.1V
                    good so we do have 13V. ur PCB okay... now you add another jumper use R1K from pin 15 to pin 16 PNL_POW to turn on PNL12V.
                    • beetle1303
                      • Jul 2019
                      • 279
                      • Singapore
                      Alright!
                      But got to go scout for the R1K resistor from the stashed PCBs. It's passed midnight, will do this tomorrow morning and report back.
                      Thank you.
                      • nomoresonys
                        • 12284
                        • U.S.
                        better scout 2 more then, you will need to jump ps-on, pnl-pow, ofl and dimmer to bu5v, then you can see if the backlights come on and stay on, if they do then your backlights and powerboard are ok.
                        • beetle1303
                          • Jul 2019
                          • 279
                          • Singapore
                          Jumped PD-15 to PD-14; and PD-16, PD-19, and PD-21, each with a 800ohm resistor:
                          PD-1 (PNL12V) : 11.92V
                          PD-2 (PNL12V) : 11.92V
                          PD-3 (SGRN) : 0.02V
                          PD-4 (SGRN) : 0.02V
                          PD-9 (SGRN) : 0V
                          PD-10 (SGRN) : 0V
                          PD-11 (SGRN) : 0V
                          PD-12 (SGRN) : 0V
                          PD-16 (PNL_POW) : 4.58V
                          PD-17 (NC) : 0.04V
                          PD-18 (NC) : 0.04V
                          PD-19 (DIMMER) : 1.34V
                          PD-20 (NC) : 0.04V
                          PD-21 (OFL) : 1.64V
                          PD-23 (NC) : 0.04V
                          PD-24 (SBY) : 0.01V
                          Mounted PS back onto TV, connected LED backlights, powered-on, but nothing happens - no backlight on TV...
                          A quick checked - the big cap shows 403Vdv but all the transformers above it shows no voltages in all the output pins... With a LED tester - all the 14 led strips are mostly 175V, with 2-3 showing 173-174V.
                          What/where else to check?
                          • Diah
                            • Feb 2013
                            • 6449
                            yours PCB are fine dont touch it any more.. put it back and show us whole photo of TV back showing how boards connected and photos on your MB and it chassis lable.
                            • beetle1303
                              • Jul 2019
                              • 279
                              • Singapore
                              Please see attached - TV Back, MB, and Chasis Label.
                              • Diah
                                • Feb 2013
                                • 6449
                                is this DIY TV ??? why the socket which it should be at MB go down and had DIY cable ..
                                you should put every things back as opriginal so you can troubleshooting the MB .
                                • beetle1303
                                  • Jul 2019
                                  • 279
                                  • Singapore
                                  This is the same PS board that we're working on to check if it is working, with all the jumped wires to measure the voltages of PD connector. When mounted back onto the TV, I kept the jumped wires to see if the TV backlight comes on when powered up.
                                  MB metal plate cover removed just to show how cables are connected.
                                  You want to see the PS to MB cable connected?
                                  • Diah
                                    • Feb 2013
                                    • 6449
                                    put every thimngs back as original. and remove load from the MB , mean speaker socket out wifi module if you have also out.. turn on and check if you have the 13V at start up.. if no you need MB in case your BL are 100% fine.
                                    • beetle1303
                                      • Jul 2019
                                      • 279
                                      • Singapore
                                      With only PD cable connected - now the power led indicator flashing 2x red, constantly.
                                      I connected the display & power cables to T-con board - same flashing 2x red light.
                                      I was curious about LED tester show mostly 175V per strip but I didn't see any led light at the back of TV. So I test again and watch the TV screen - no visible light also even though LED Tester show 175V. Possible to have all the led strips shorted?
                                      • beetle1303
                                        • Jul 2019
                                        • 279
                                        • Singapore
                                        With only PD connector on MB, only PD-15 showing 4.96V (and not fluctuating), the rests are 0V... I connected Display and power to T-Con, same readings on PD connector, and everything connected back to MB, still same readings - only PD-15 has 4.96V.
                                        Seems like not connect to MB at all? Or MB is dead?
                                        • Cemal Odabasioglu
                                          MacBook Pro A1707 Motherboard Diagnostic Help – CD3215 heating and Fluctuating Rails
                                          by Cemal Odabasioglu
                                          I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
                                          Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
                                          Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
                                          Observations...
                                          01-14-2025, 03:54 PM
                                        • triplefour
                                          ONN 100012588 Has fluctuating Voltage on PSU 12v
                                          by triplefour
                                          Hello all got another TV here im puzzled by. why cant they all be easy fixes that just need a little love and some tape???
                                          anyway i go to this guys house to look at an ONN 100012588
                                          this is my first time looking at one of these brand of TV's.
                                          TBH i have low expectations because i see ONN as the cheap walmart brand that suddenly popped up selling the cheapest version of all kinds of tech things. and someone sent me a ONN flash drive with some data on it with some recordings they wanted me to check out and it immediately broke and corrupted the data and i was unable to...
                                          09-14-2022, 07:41 PM
                                        • beetle1303
                                          Wine Chiller - SMPS issue - fluctuating voltages
                                          by beetle1303
                                          My wine chiller, TECNO SW-126LCD, is semi-functional - it powers up, can set temperature, and chilled to the set temperature, and cuts off compressor, etc. It however runs very hot.
                                          Upon taken out the PSU and did some basic check - 5V output to LCD panel buttons and display is stable, but there is no 12V output to LED lights, and fans.
                                          Further checks found the secondary side voltage is fluctuating around 8-15V range, but the 7805 regulator seems ok and producing the stable 5V output.
                                          Checking further on the primary side: Incoming line input to bridge...
                                          09-04-2023, 10:33 AM
                                        • koby058
                                          yoga9 3v3 5v fluctuating
                                          by koby058
                                          Hi
                                          board model: NM-D992
                                          type c remains on 5v. when i connect it the 3.3VALW and 5VALW fluctuating. can someone please help understand why?
                                          main power rail voltage 13v
                                          till now i have tried:
                                          measured all coils resistance looks ok
                                          replaced RT6585CGQW to a brand new one
                                          replaced all mosfets for 3.3v regulator and the dual mosfet for 5v regulator
                                          happen both on DC power and on battery
                                          issue remains
                                          video
                                          schematic attached...
                                          08-03-2025, 09:06 AM
                                        • madan1
                                          DALI SUB E-12F class D, fluctuating power rail
                                          by madan1
                                          Good day everyone.
                                          I have on the bench an amp board from DALI SUB E-12F. It is class D amp with a smps on the same board.
                                          The issue is that it powers off way before the rated power is reached (the protection circuit kicks in). It has an independent standby power supply, which stays on after the main power supply is turned off via a relay on the primary side (thus there is no reason to believe that the protection is triggered from the smps IC on the primary side).
                                          The normal value of the positive and negative power rails is +/- 43V.
                                          The positive rail stays...
                                          Today, 10:33 AM
