Swapping Panels from RCA to LG
  • tech9pc
    • Sep 2021
    • 49
    Would anyone here know if it would be possible to take the BOE HV550QUB-N4D out of a RCA RTU5540-B I have and put it in a cracked LG UN7000PUB with panel HV550QUB-N4E. I compared the 2 panels on panelbook.com and they are practically identical. Here is the link comparison
    https://www.panelook.com/modelcompar...ds=29797,39067
    I would like to save the LG as it is a way better tv than the RCA. Thanks for any help
  • nomoresonys
    • 12276
    • U.S.
    Re: Swapping Panels from RCA to LG
    If it's compatible, I would try fitting the LG boards to the rca, much easier, then if you see that it works, you can go to the extra effort to switch screens if you want, I suppose.
    • tech9pc
      • Sep 2021
      • 49
      Thanks nomoresonys ... ya that makes sense. I'll have to look and see if the led connector array connections are the same though ... or won't be able to light the panel up to see if working ... probly not though cause I notice each brand always wants to do their own thing ughhh.
      • nomoresonys
        • 12276
        • U.S.
        Maybe you can for a test put the mainboard from LG into RCA, see it it comes on. BE cautioned tho, I don't know if it will mess anything up.
        • nomoresonys
          • 12276
          • U.S.
          What makes the LG much better? if it's the features like more hdmi's or the like, that's on the mainboard so it could IF compatible transfer those features to the RCA.
          • tech9pc
            • Sep 2021
            • 49
            The LG is a newer 2020 4K UHD Smart webOS TV .. RCA is not smart and 2017 model. I checked the leds and the LG has 12 strips ... the RCA only 10 so might fry the leds if try LG boards in RCA vice versa. So looks like only option is to try swapping panel and see what happens lol.
            • neilc6
              • Nov 2015
              • 1550
              Changing boards between models typically doesn't work since the holes for connectors on the back panel won't match. If the tcon board is the same, it's the same panel though I would swap the tcon with the panel.
              • nomoresonys
                • 12276
                • U.S.
                They swap them out with universal mainboards, not a hard task to secure and ground them.
                • tech9pc
                  • Sep 2021
                  • 49
                  I ripped them apart today and not gonna work anyway because the tcon on the LG is integrated into the mainboard and not seperate like on the RCA. Damn lol guess will have to keep looking for a dead LG with good screen. Thanks for all the suggestions though.
                  • eccerr0r
                    Sell or Shim Solar panels?
                    by eccerr0r
                    Well, due to my grid tie inverter not accepting high voltages, and the fact that the lions in my solar panels are 36V (72-cell) I think I need to stick with 72-cell.
                    However I have a few smaller panels that are 36, 32, and two 30-cell. The 36 and 32 together run at 75% efficiency (and subtract more with additional inefficiencies) when running in parallel with the 72-cell panels. The kicker is that the two 30s... generate 0% power when connected in parallel(!)
                    So now what to do with these small panels?
                    I could sell them...
                    Or I could shim them....
                    03-29-2025, 01:07 AM
                  • zwect
                    RTX 4060 Gigabyte Aero / FBVDDQ not switching on despite compatible IC swapping
                    by zwect
                    I got this Gigabyte Aero RTX 4060 where it initially wouldn't get detected, after disassembly i found that U504 (12v to 5v) was corroded at pin 1 together with it's ADJ resistors, i swapped them for close enough ones (it goes to a 1.02k resistor > 340ohm then 0hm > GND), i installed a 1k and 300ohm one and got 5v properly, fans would spin fine but card still wouldn't get detected, i've measured PEX present then found out that FBVDDQ was missing entirely, analyzing further, U15 was shorted at it's VCC pin (7), at the time i didn't have another exact model but got a TPS51211 instead, i checked...
                    07-21-2025, 05:53 PM
                  • NolesFan
                    Can LED panels be used from different TV's ( or the internals to the panel )?
                    by NolesFan
                    I have a TV, ( example ) Sony XBR-75X80G that the LED panel is cracked, does anyone know if we can take the LED panel from a ( example ) Sony XBR-75X80H and plug it in and it will work? Or if the panel measurements is not exact, can we take the internals of the cracked panel 80G TV and mount into the good panel 80H TV? Thank you
                    06-23-2025, 09:19 AM
                  • japlytic
                    Psuedo-4K LCD panels
                    by japlytic
                    I have come across (and was burned by at least one) so called "4K" (claiming 3840 * 2160) LCD panels which have an actual resolution of Full HD (1920 * 1080) meaning that every second pixel in either direction is skipped.
                    For panels 19 inches (used in notebooks and tablets) and smaller with an Embedded DisplayPort (eDP) interface, do you know of any "4K" panels fitting into this category which do not have actual 4K resolution and the ones which have actual 4K resolution?
                    12-31-2020, 06:15 PM
                  • kuba2102
                    Medion Erazer beast x25 freezes and resets only at low CPU usage
                    by kuba2102
                    Medion Erazer beast x25 62307 MSN 30031969 GM5ZGXW AMD version
                    Hello. The laptop freezes and resets only at low CPU usage, practically at IDLE after a few minutes. There is no problem under a load, and I benchmarked it for over an hour. I noticed that one of the CPU coils was making whining noise at low CPU usage. I previously thought it was a BIOS problem, but updated BIOS and no change. I'm thinking of changing the CPU DrMos'es there are 5 of them all together. I have already swapped the DrMOSes first one with the last one (I desoldered them and soldered in swapping DrMos no.1 with...
                    01-06-2025, 09:14 PM
