swapping bios and ec chip dell 5310 2 in 1
  • usundo
    • Nov 2025
    • 5
    • Atlantis
    will swapping ec and bios from a touchscreen laptop motherboard to non touchscreen laptoptpp motherboard make it touchscreen ?
    the motherboard 19752-1 touchscreen to 19842-1 non touchscreen dell 5310 2 in 1
    thnanks
  • reformatt
    • Feb 2020
    • 1534
    Is that a serious question? Short answer no. You need the hardware, like touch LCD, cable, in addition to the electronics on the motherboard for touch function.
    • usundo
      • Nov 2025
      • 5
      • Atlantis
      both board have same design and same cpu
        • 22109
        Are these the model numbers
        Northbay MLK Non-TBT MB 10L 19842-1
        Bandon MLK Non-TBT MB 10L 19752-1
        • usundo
          • Nov 2025
          • 5
          • Atlantis
          yes , thats the two motherboards do u have the the pdf scmatics for them?
          • usundo
            • Nov 2025
            • 5
            • Atlantis
            19842-1 i7 model because both motherboard have i3,i5and i7 design.
            • capoplays
              Help with BIOS update on Dell G15 5515 after chip replacement
              by capoplays
              Hey everyone,
              I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
              The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
              When I check the BIOS using the F12 menu Flash...
              10-24-2025, 06:53 AM
            • DynaxSC
              ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
              by DynaxSC
              Hi
              I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
              08-04-2025, 12:20 PM
              by SMDFlea
              Bad...
              09-02-2021, 04:40 PM
            • ezenia
              Dell G3 3579 BIOS chip ID
              by ezenia
              I bought a Dell G3 3579 eBay. The fault was not mentioned and it did not come with charger. Before trying to power off battery, I did some basic checks on the coils (in resistance mode) to see if there was any short. None were reading short. Decided to power the board to see if anything happened. The keyboard backlight came on. About 5 seconds later, the fans begin spinning at max speed. The white LED comes on at this time, stays solid for a bit and goes off. Fans continue to spin at max. Display is black (no backlight). If I hold down power button, board goes off. I did give...
              06-16-2025, 08:07 PM
            • JoWed
              Problems with reflashing BIOS Chip on omen by hp laptop 17 an104ng
              by JoWed
              Hello Community,
              I recently tried to change the Batterie on my Omen by HP Laptop 17 an104ng and after putting in the new batterie ([Batterie Link](https://www.amazon.de/7xinbox-17-AN0...&keywords=16%2...
              07-01-2025, 09:32 AM
