Philips LCD 42PFL5432D/37 - Bad PSU
    master hoarder
    • May 2008
    • 12175
    #41
    Re: Philips LCD 42PFL5432D/37 - Bad PSU
    Originally posted by nuklear
    and this is what i seen in the "spare parts list" IC907 9965 000 43345 TEA1507P/N1.
    Perfect! I got IC907 down as TEA1507P (this is the PWM controller for the standby circuit).
    Now the only thing I couldn't read from the schematic is the output voltages. It looks like it says 21 volts for the top and 12 volts for the bottom one - these voltage are all the way on the right on the schematic. Please verify that the values I read are correct.
    So, it looks like the external standby PSU mod will work. Just need to get the value of the standby voltage, remove a few jumpers, wire the external PSU, and it will be good to go.
    As for trying to fix the PSU by reusing a transformer from another PSU, it probably won't be possible, unfortunately. The old transformer has 2 auxiliary windings while most computer PSUs only have 1. Save the old transformer in your junk box, though, just in case you run into another transformer with a similar core.
    • thelmores
      • Feb 2011
      • 17
      #42
      And ALWAYS make sure you get 105c (or higher) rated caps......
      Some manufacturers will try to get away with 85c caps, and they will not last nearly as long as a good 105c rated caps.
      105c caps are also rated for lifetime, whether it be 1000hrs, 2000hrs, 3000hrs, etc.
      You want to choose the best caps you can, while at the same time keeping the price reasonable.
      • nuklear
        • Feb 2011
        • 15
        #43
        it looks to me likke 24 and 12 if I am reading it right.
        • PlainBill
          • Feb 2009
          • 7034
          Probably not. That appears to be the output of the main section of the supply, you need the standby section.
          PlainBill
          • nuklear
            • Feb 2011
            • 15
            #45
            ok this might be it.
            • PlainBill
              • Feb 2009
              • 7034
              It's hard to tell when working with fragments of schematics, but there are clues. Notice that the defective transformer is T904. T904 is the transformer for the 12V output. The STANDBY line is coming from the main board, and controls the SMPS controller for the 24V supply. So the Standby supply is 12V.
              PlainBill
                master hoarder
                • May 2008
                • 12175
                #47
                I concur.
                The other clue that gives this away is that there's only 2 transformers in this power supply (one of them being the broken one you mentioned) and each has a single output only.
                So what's next?...
                Remove J5 and R974. This will disable the primary side of the standby circuit. Then finally wire in 12v from an external power supply (see attached image below). Note that ground (GND) from the external PSU also needs to be connected.
                I suggest a PSU capable of at least 2A. Also if there's any loose solder like in the pictures you posted, make sure to clean it up.
                • nuklear
                  • Feb 2011
                  • 15
                  #48
                  so where do I get this psu to put onto this board? Is this something I can do with having no experience in doing this kind of repair?
                    master hoarder
                    • May 2008
                    • 12175
                    #49
                    Most likely yes.
                    The wiring part is pretty straightforward - it's like putting new batteries in your remote. The only difference is there is some soldering involved (think of it as if the batteries had wires that you needed to connect). If you've never done any soldering before, that's the only part of this job that might make it a bit more challenging. But soldering is not all that hard. I've seen a quite a few people here come with no experience and recap their monitors. Just read the FAQs or see some videos on YouTube on how to solder.
                    Also:
                    1) make sure your soldering iron nice and hot before you solder/desolder
                    2) put a little solder on the tip of the iron before soldering/desodering components - this will allow for better heat transfer
                    3) don't be afraid that you might "burn" the board - keeping the iron on the board for up to 5-8 seconds is acceptable. It's much worse to try to remove or solder a component when you're not heating it enough.
                    What you need to do for this repair is:
                    1) desolder/remove jumper wire J5 and resistor R974 from the board.
                    2) take the (+) wire from the 12v external PSU and connect it to any of the two pins circled in red in the picture above.
                    3) take the (-) wire from the 12v external PSU and connect it to any of the two pins circled in black (this is also the ground of the power supply).
                    4) remove any loose solder from the board
                    Now the question is, have you found a 12v adapter/power supply yet?
                    If you want, you can just temporarily use a computer PSU to see if the TV will come on. On a computer PSU, 12v is carried by the yellow wires. The black wires are ground.
                    Again, the only downside of this mod is that it won't look too pretty, mainly because you will need to have both the external power supply and the TV plugged in order for the TV to work. And if you don't have an external power supply yet, it's probably a better idea to buy a new PSU for the monitor than to waste money on buying an external power supply.
                    • nuklear
                      • Feb 2011
                      • 15
                      #50
                      It worked! Thanks alot! Only thing now is I get a blinking/flashing from the tv. just to make sure, I used a power cord that had a 12v output is that ok to use? any ideas of why it would be flashing mybe every second would be great. Ok it stopped flashing mybe had to warm up? But again Thanks alot!!! saved alot of money and I appreciate it and so does my son!
                      • nuklear
                        • Feb 2011
                        • 15
                        #51
                        hmmm... Resoldered it and now tv wont turn on? I just re ran the wires so i could put the back on and now it doesnt even have the standby light on again lol
                        • nuklear
                          • Feb 2011
                          • 15
                          #52
                          well thanks to everyone that helped I figured out the wireing prob and broke the lcd screen while putting the back back on, so looks like its ment to stay broken
                          • Dizzer
                            • Mar 2011
                            #53
                            I too have the same exact problem as the TC. I have ordered the caps and will post my results upon installation of the new caps. For me, both caps B and D (based off the image in the first post) were bulging. I am replacing all of them just in case.
                            • trixter
                              • Mar 2011
                              • 13
                              #54
                              Working on the same case. Just opened the tv and the caps on psu were buldging. Same values as the ones posted in first thread. Once caps A,B,C, and D come in, I'll solder them in and see results. The tv is now doing that chirping sound with no screen. I've fixed quit a few things in my time. Hopefully I'll add this on to the list.
                              • trixter
                                • Mar 2011
                                • 13
                                #55
                                Just replaced ABCD and still chirps. Next I'll try all the small caps and see.
                                Does my T905 Transformer look bad. It sounds like the chirping is coming from this. It looks this way on both sides.
                                  master hoarder
                                  • May 2008
                                  • 12175
                                  #56
                                  Hard to say exactly. Looks fine to me. Check the solder joints on the other side - i.e. see if any of them look dry or cracked. Also, change the small electrolytic caps like you mentioned and let us know if the problem remains.
                                  • trixter
                                    • Mar 2011
                                    • 13
                                    #57
                                    Yes the transformer does look good. I meant the solder. Looks like they're kinda burnt. That's all.
                                      master hoarder
                                      • May 2008
                                      • 12175
                                      #58
                                      That's likely left over flux from when the transformer was soldered at the factory. Did you replace the small caps yet? Also did you try measuring the standby voltage at connector CN902 (the one next to capacitor C955)? There should be 12v there when the PSU is working properly.
                                      • trixter
                                        • Mar 2011
                                        • 13
                                        #59
                                        Can I test the voltage without the TV? I don't have the TV now. Just the powerboard. I can plug it into the power but I'm sure it won't turn on without something jumping certain pins.
                                        Attached is where I noticed some discoloration under two diodes. I took the diodes out and tested with DMM on diode mode. I get a reading both ways on both diodes. I believe that means they are bad. I'll get them replaced. They are part# P6KE120A. Data sheet says they are uni directional.
                                        Has anyone ever fixed their board? Seems no one has actually fixed their but just has advice.
                                        • Dgtech
                                          E. Technician
                                          • Apr 2009
                                          • 1462
                                          • Steeler
                                          #60
                                          What type of reading do you get both ways? Is it 0 ohms both ways? Using the diode test, what voltage reading do you get both ways, anode to cathode, cathode to anode?
                                          • ahmedtou
                                            HOW CAN I UPDATE HL-DT-ST BD-RE GGW-H20N XA02
                                            by ahmedtou
                                            help me please
                                            I have an HL-DT-ST BD-RE GGW-H20N with ROM version: XA02.
                                            When I tried to burn a 25GB Blu-ray disc using ImgBurn, I got an error.
                                            I will share all the details with you, including the disc information.
                                            Code:
                                            HL-DT-ST BD-RE  GGW-H20N XA02 (ATA)
                                            Current Profile: BD-R
                                            Disc Information:
                                            Status: Empty
                                            State of Last Session: Empty
                                            Erasable: No
                                            Free Sectors: 12,219,392
                                            Free Space: 25,025,314,816 bytes
                                            Free Time: 2715:27:17 (MM:SS:FF)
                                            Next
                                            08-27-2025, 08:49 AM
                                          • alro7779
                                            Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                                            by alro7779
                                            Hello, guys!
                                            The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                                            09-14-2025, 12:25 AM
                                          • G33RT
                                            Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                                            by G33RT
                                            Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                                            It does power up when pressing the power button.
                                            I already try the power button while plugin the plug with no result.
                                            Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                                            Could this be an PSU or eMMC issue ?
                                            07-19-2025, 03:43 AM
                                          • Ifixstuff9
                                            Philips 42PFL5432D/37 power supply issue no 12v
                                            by Ifixstuff9
                                            I have a Philips TV that shows no signs of life when plugged in - no standby LED, no response to buttons, no noises, nothing. This model is well known for having bad caps, so I started by replacing a few of them (3x 35v 1500uf and 1x 2200uf 16v). I don't know the history of the TV but it looks like someone's been at it before because some of the solder joints looked really bad, so I re soldered them as well.
                                            After swapping the caps I still got no signs of life so I started checking voltages, and found that the board is supplying 24v but not 12v. Here's what I measured on the connector...
                                            05-02-2021, 09:29 PM
                                          • double_DD
                                            Philips curling iron - is this a common AC cable?
                                            by double_DD
                                            Wife has 2 Philips hair curling irons half defective - after learning how they're supposed to work and testing them, it turned out that both have defective power cables, and both on the same place; broken wires due to wire bending.
                                            As they were both relatively easy to disassemble, and cables are plugged not soldered (as they can rotate in the handle), I was sure it would be easy to find replacements. But - NO! I'm unable to find anything similar on ebay or Aliexpress.
                                            Not sure if this is something Philips proprietary, or a standard, but the cable plug...
                                            08-18-2025, 10:04 AM
