LG55UB850V no picture or audio - flashing LED's help please?
  • Scoff
    • Jul 2017
    • 101
    • Uk
    #161
    Re: LG55UB850V no picture or audio - flashing LED's help please?
    No difference with 3D turned off. Same behaviour with 3D on and off. Does this question relate to R13006 which is for 3D_EN_LGD_120Hz? This resistor is not present on by board, yet the service manual does NOT say it is optional?
    Another resistor that the service manual says should be present, but it is not, is R13005 - If I am reading the board numbers correctly? This says Non-LGD 60 Hz T120 module UB85 so perhaps doesn't apply to my board as I do have the T120?
    I found a picture online of another EAX65684604 Main Board which also is missing R13018 and R13019
    so perhaps some configurations of this board are not supposed to have these 2 resistors, but the service manual has an error and should show OPT next to them...
    Either way, they aren't there on my board and never were. I will continue with the freeze test next and see if that reveals anything.
    • Diah
      • Feb 2013
      • 6354
      Originally posted by Scoff
      Red arrow side of R13018 and R13019 = 3.272v STABLE
      Yellow arrow side of R13018 and R13019 = Fluctuates in time with buzzing, between 3.299v and 3.304v. During each 2 second 'buzz' the voltage climbs from 3.299 up to 3.304v, and when the buzz stops, the voltage falls back down to 3.299v.
      we do know S.M are internal documents delivered with other sheets of suggestion and repair steps which we don't have and just we guess issue on MB.
      so yes R13018 and R13019 not at MB but they exist at S.M. mean its could be solution or too test way if one of source or gate tap IC pull abnormal currents at panel ( you said ribbon cable contact pins are good. and when you disconnect one a time or both of ribbon the buzzer stop )
      so i would put 2 SMD 4.7K in place and see if this rail became stable easy cheep way to try.... if not just remove them.
      • Scoff
        • Jul 2017
        • 101
        • Uk
        #163
        I just want to say thanks for all the help on this thread. I've learnt a lot about circuit boards and the general workings of LCD TVs. Unfortunately due to other commitments, I can't spend any more time on this, so will have to store the tv and hope that the correct main board comes up for sale at some point in the future.
        • Diah
          • Feb 2013
          • 6354
          sorry MAN. if you were disappointed some how.. the service manual some time issued after the TV in production one years or more.. and we can find MB different version too over all brands. this mean any we find on SM. it could be correction of later version on MB. this i do used before at my work.. its not only TV. this happened always after any new issue appears after using product at end customer . so need to change some parts or add some to solve problem.
          if we do know the issued time stamp of S.M will explain its years after 2016.
          wish you good luck.
          • toke lahti
            • Jun 2022
            • Finland
            #165
            WOW,
            this was a long thread.
            I'm in similiar situation with just entry level skills and equipment.
            So maybe this 55UB850V-ZD goes to recycling center...
            BUT,
            what I'm still curious is, what does those FIVE FLASHES mean?
            (Just registered to ask this...)
            • toke lahti
              • Jun 2022
              • Finland
              #166
              I made a standard bake to my main board 10min 200°C.
              And the backlight started to glow!
              But, no picture, only vertical magenta lines with constant space between each other.
              Anybody recognises this malfunction?
              What next?
              https://drive.google.com/open?id=16Y...m&usp=drive_fs
              • peterkos2
                • Nov 2020
                • 40
                • Slovensko
                #167
                Hello everyone.
                This is a great forum, it always helps me.
                This topic also helped me with exactly the same problem. I also lacked 12V power supply to the panel and after warming up the TV started up.
                Thanks to everyone
                • peterkos2
                  • Nov 2020
                  • 40
                  • Slovensko
                  #168
                  Hello. The same TV was returned to me again with the same error, but after warming up the LED LD1900 lights up, but not fully. 12V is missing again on the panel. Didn't anyone solve it already?
                  • peterkos2
                    • Nov 2020
                    • 40
                    • Slovensko
                    #169
                    I also have no voltage on DRV_ON
                    • krissie
                      • Apr 2023
                      • Nederland
                      #170
                      Hello All, I have a simelar problem. Does anyone have a replacement board for sale or is there an equivalent that will work in this tv?
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        #171
                        From my experience with similar boards, seems more like a ceramic capacitor plague developing. In a few common areas they short.
                        • tjrudd1310@aol.com
                          • Dec 2023
                          • Uk
                          #172
                          Hi I have the same problem same tv , turned it off then went to turn it on and nothing , I have the same reading on the t-con F1 0.8volts only one led on the main board and the led on the power board flashing 5 times .
                          has anyone found any main boards or compatible boards yet ? Or a fix for the main board ?
                          • elviscen
                            • Apr 2022
                            • 8
                            • Slovenia
                            #173
                            Hi All,
                            I have the same problem and no main boards available on the internet.
                            Anyone have found any solution for this problem?
                            Maybe re-baling the CPU will work?
                            Thanks.
                            • STKR123
                              Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
                              by STKR123
                              As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
                              I wonder if re-flashing the BIOS might be of any use here.
                              As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
                              There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
                              11-03-2024, 06:58 AM
                            • rabbituk
                              Sony HCD BX7700dbi CMT flashing standby
                              by rabbituk
                              I have got a Sony HCD-BX7700dbi that isn't worth a lot but I'm keen to learn how to repair and would appreciate some help with my train of thought. The protection circuit is kicking in and the standby light is blinking. It goes into protection mode within a second of powering it on.
                              So far the relay on the power board that enables the main transformer clicks on and then off when powering on the unit. Looking at the schematics, the permanently enabled power rail called 'unreg sub' provides about 13.5VDC. Where the power comes into the main board on connector CN303, there is a diode...
                              02-11-2025, 05:05 PM
                            • ninadpurohit
                              Toshiba Satelite C850 - No Power, Flashing LEDs
                              by ninadpurohit
                              I am trying to fix this DK10FG board for a friend. It is not powering up.
                              When I plug-in power adapter, its DC IN led and Caps lock start flashing. Even cpu fan gets on/off kick like flashing leds. No battery attached. Nothing happens on pressing power button. I checked the charger IC and it seems fine. (ACOK - 3.3v). Re-programmed the bios but no luck.
                              I checked SIO chip NPCE885LA0DX and here's the reading
                              19,46,76,88,115 | P3V3AL_R --> 3.3v
                              102 | P3V3AL_EC --> 3.3v
                              4 | P3V3S --> Fluctuates from 0.2v to...
                              10-06-2021, 11:17 PM
                            • Bloopeta
                              Samsung UE43KU6400U Flashing Red Standby Light
                              by Bloopeta
                              Have a Samsung UE43KU6400U that will not turn on, just continuous flashing red standby light.
                              Power button does nothing
                              Have unplugged the mainboard, and backlights illuminate.
                              Have tried removing panel ribbon cables one at a time, and that makes no change.
                              With mainboard unplugged, all voltages from powerboard seem ok, but with mainboard connected, they never quite reach full voltage, and drop and raise in a constant loop (in time with click noise from mainboard.
                              Using backlight tester, I get 63.6v on both sides, so seems like no bulbs...
                              09-11-2023, 02:34 AM
                              Lift Master Garage Door wall switch display / motion sensor controller display disappeared no back light
                              by sam_sam_sam
                              This happened last Saturday and today I finally had time this morning before I went to work to replace two non brand capacitors
                              I will let you be the judge weather or not these are bad or not according to the blue ESR meter that I am using
                              I am comparing them to a brand new one that I installed
                              The display came back on and the programming was not lost which I was surprised by I would have thought that when the display went blank that so did the memory as well
                              I going to let it run for several days before I remount back on the wall next to the...
                              09-05-2024, 06:48 PM
