Toshiba Satelite C850 - No Power, Flashing LEDs
  • ninadpurohit
    • Oct 2021
    • 8
    • India
    I am trying to fix this DK10FG board for a friend. It is not powering up.
    When I plug-in power adapter, its DC IN led and Caps lock start flashing. Even cpu fan gets on/off kick like flashing leds. No battery attached. Nothing happens on pressing power button. I checked the charger IC and it seems fine. (ACOK - 3.3v). Re-programmed the bios but no luck.
    I checked SIO chip NPCE885LA0DX and here's the reading
    19,46,76,88,115 | P3V3AL_R --> 3.3v
    102 | P3V3AL_EC --> 3.3v
    4 | P3V3S --> Fluctuates from 0.2v to 1.2v
    104 | P3V3AL_EC(VD) --> 3.3v
    82 | EC_PW_ON# --> Fluctuates from 0v to 3.18v
    83 | EC_CTL1 --> 0v
    110 | EC_CTL1 / DNBSWON --> 0.9v
    14 | ACPRESENT --> 0v
    101 | EC_CTL3 --> 0.9v
    95 | ACPRES --> 3.3v
    16 | PWR_WLED# --> 0v
    66 | CAPS_LED#_3 --> Flashing led
    85 | VCC_POR --> 2v to 3v
    64 | SA_PG / ACIN --> 0v
    63 | FAN_TACH1 --> 0.6v to 1.2v
    65 | DCIN_WLED --> Flashing led
    80 | LOW_BAT#_3 --> Fluctuates from 0v to 1.3v
    81 | FAN1_PWM --> Fluctuates from 0v to 1.3v
    99 | BATT_IN --> 2.3v
    108 | EC_BKLTEN --> 1.84v
    I suspect that the SIO is faulty because it is giving fluctauting EC_PW_ON. However I am not sure as I am not experienced at this.
    Any idea? What should I check next?
  • crea2k
    pioneer A-307R flashing leds on front panel, possible short
    by crea2k
    I have a pioneer A-307R here and what it does is flash all of the leds on the front and nothing more.
    I got the thermal camera out on it and saw that Q451 was getting hot, so I removed it and the lights now come on as normal, but obviously that part of the amp doesn't work.
    I tried replacing it, but it goes back to its flashing lights thing again.
    I noticed too that on the back of the board R465 - R467 - R 469 are all getting red hot (over 100 degrees C)
    Im guessing I have a short here somewhere, but so far I have not managed to find...
    10-05-2023, 03:51 PM
  • pb1911nt
    MacBook Pro A2251 - 820-01949 Voltage Drop and unkown issues.
    by pb1911nt
    Hello forum,
    I'm still relatively new to the world of electrical repairs.
    I have a Macbook here that I can't figure out
    When the battery is gone, the USB input consumption goes up to 20 V and 0.06A. But it breaks down after about 2-3 seconds and you can also hear a small ticking on the logic board. But I can't pinpoint it exactly.
    I removed the logic board and took a few measurements.
    But I can't really figure it out.
    At first I thought the infamous CD chip was defective - but then of course you read more on the internet...
    09-07-2025, 11:35 AM
  • Pipolups
    Corsair K70 LUX RGB dying LEDs
    by Pipolups
    Hi there !
    I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
    Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
    10-08-2024, 11:58 AM
  • learnmore
    Samsung QE55Q60TAUXXU - flashing backlight and flashing standy light--no image
    by learnmore
    Hello Community!
    CASE DETAILS
    Promblem Signs: Backlight on 1 sec off 7sec > repeat && Red standby light: 1blink, off 3 sec, 2 blinks, off 5 secs, 2 blinks, off 3 sec, restart cycle
    13V present on powerboard output. Backlight continues flashing after removing cables to pannel one at a time and even with both disconnected. NOTE: backlight STOPs flashing and remains on when connector between powerboard and mainboard (note Tcon built in) is disconnected.
    Tried inserting firmware on USB and left it in for a few hours, but no change
    03-03-2024, 09:49 AM
  • STKR123
    Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
    by STKR123
    As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
    I wonder if re-flashing the BIOS might be of any use here.
    As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
    There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
    11-03-2024, 06:58 AM
